Udown?
Discussion in 'Hawaii' started by siKjiTz, Feb 5, 2015.
  1. Feb 5, 2015 at 5:29 PM
    siKjiTz
    siKjiTz [OP] Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    Howzit gang,
    I will first say thanks for all the good info that you guys provide and also the laughs at some of the funny stuff you guys post. It seems like a pretty tight Ohana you all have here on Oahu. I see everyone gearing up for the peacock flats overnighter. I dig it. Here is my question for anyone who is down.
    I really need help installing some parts. I ain't about to pay $400 bucks to 4wheelparts to install cause I don't got it, I spent my money on the parts. I need to have my Bilstein 5100s front and rear along with a set of wheelers 1.5" 3 leaf progressive AAL installed. I have tools, jack stands, hydraulic jack, and beer....lots of beer. I want to learn too. I'm new to the game.
    Is anyone down to help a brotha out? It's a 2004 DC prerunner 2x4. I live in Mililani but will go wherever. Mahalo! Lmk gang, I know you can relate. I get parts but no can install. Ayesoos! Bumbai I goin learn!
  2. Feb 5, 2015 at 9:08 PM
    Opunui
    Opunui Member
    Honolulu
    2015 pre-runner
    We doing an install Sunday maybe we can do yours to. We have all the tools,knowlede and vehicles...no beer though.lol
  3. Feb 5, 2015 at 10:08 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    If you don't jump in on the above, I could possibly help you out... shocks and AAL is pretty standard... Sat is out for me.. I gotta change my own brake rotors and head to a b-day party by 12... swap (for my my brakes) "should" take like 1.5 hr. tops...
  4. Feb 6, 2015 at 12:16 AM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Sunday mod day! I'm down to drink beers
    k3v11n likes this.
  5. Feb 6, 2015 at 12:37 AM
    siKjiTz
    E
    Oahu, HI
    Right on guys! I am very appreciative of your help. I will take you up on your offers.
    I will PM you my info so we can coordinate the times. Much mahalo guys!
  6. Feb 6, 2015 at 12:58 AM
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    I down to help. Does anybody know how to change out brake lines while we're at it?
  7. Feb 6, 2015 at 8:47 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    brake lines are easy...unless the rears at the top are stuck...then it sucks.
    invest in some flare-nut wrenches. makes it easier-ish
    I'd be down to swing by Sunday, but working till 1500ish...I think all the heavy lifting will be done by then.
  8. Feb 8, 2015 at 1:19 AM
    siKjiTz
    E
    Oahu, HI
    Hey gang, I decided after talking with opunui that I should get new bushings and top hat for the struts. So maybe next weekend will work better.
    Also, does anyone know of coils other than eibach that I could possibly replace mine with? I don't necessarily need the full 3" lift that the eibachs have.
  9. Feb 8, 2015 at 9:41 AM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Ome 885
  10. Mar 6, 2015 at 12:25 AM
    siKjiTz
    E
    Oahu, HI
    Can anyone help with install during the week? Or would weekends work better?
  11. Mar 6, 2015 at 12:26 AM
    siKjiTz
    E
    Oahu, HI
    Also I have a noob question.
    What does the [OP] mean?
  12. Mar 6, 2015 at 12:29 AM
    bkiel311
    bkiel311 Well-Known Member
    Brian
    Bremerton, WA
    2024 Silver Tacoma DCLB TRD OffRoad 4x4
    Stock (for now)
    Over Powered!!!!!! Must be nerfed!
    Original Poster.
  13. Mar 6, 2015 at 12:34 AM
    siKjiTz
    E
    Oahu, HI
    Thanks B!
  14. Mar 6, 2015 at 12:40 AM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Im sure weekends work best for just about everyone. Im down if u need a hand.
  15. Mar 6, 2015 at 8:51 AM
    luka
    Kailua, HI
    my weekends are hit/miss till mid April.
  16. Jul 6, 2015 at 12:31 AM
    siKjiTz
    E
    Oahu, HI
    So I got new leaf spring bushings from Wheelers. I installed the 3 leaf add a leafs. It was a bitch to get out the old bushings from the leaf springs. I torched all 4 out. Then I had to sawzall the outer ring on the fronts. Then the new bushings went in smooth for the fronts but was too big for the rear. I had to modify and shave and grind the new rear bushings to fit in the back. I needed to used a vice to press and 3 guys to get it in. Took forever! Then when I went to install the shocks and struts, it was for the 05+ not my 04!!!!! FML!!!! Now I am waiting for Headstrong to send the correct parts so I can gitrdone. Hopefully by Tuesday. FuxkinA!!!!
  17. Jul 6, 2015 at 8:48 AM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    Me too. Although I have a frotn spacer kit that needs to be installed. Let me know. Shoots.
