Udr headers/check engine light.
Discussion in 'Performance and Tuning' started by Brianawd, Oct 10, 2015.
  1. Oct 12, 2015 at 9:22 AM
    #41
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    I did tighten from the center out. I think I'm just going to pull them off and go back to stock. Along with the leak I am also having a issue with my exhaust rubbing on the drive shaft carierr support. It does not rub when the exhaust is cold. Once the headers and ypipe get up to temp it starts to rub. Cold I have about 1/2in clearance. I will take some pics so people can see what I'm talking about.
    The passanger header is also rubbing on the shock/coil tower
  2. Oct 12, 2015 at 9:56 AM
    #42
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    I have the URD Rear Stimulator since I run Doug Thorley long tube headers. I only run one set of cats, I've never thrown a code...Thankfully
  3. Oct 12, 2015 at 10:17 AM
    #43
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Nothing worse than a exhaust leak...I ended up welding some flanges closed lol...
  4. Oct 12, 2015 at 10:24 AM
    #44
    Ninj
    Ninja
    New Hampshire
  5. Oct 12, 2015 at 11:03 AM
    #45
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I'm not saying don't go with UDR. Chances are that 95 out of 100 will be fine. You will always get the % that are flawed. I seem to just be the lucky one that got one of the flawed ones
    Here are a few pics.
    One showes the header on the passanger side where it rubs the shock/coil tower.
    The other pic shows the exhaust when it's cold. I will post a pic after work showing how the headers and ypipe once hot cause the exhaust to rub. This only started after installing the udr parts.
  6. Oct 12, 2015 at 11:05 AM
    #46
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Hmm gonna have to go look at my passenger header now to see if its rubbing :eek:
  7. Oct 13, 2015 at 5:51 AM
    #47
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If it was me, I'd loosen everything up and tighten back down, just as a sanity check and since I wouldn't want to go back to stock before I tried everything I could first.
    Torspd likes this.
  8. Oct 13, 2015 at 6:14 AM
    #48
    01MUD.TACO.SC.V6
    01MUD.TACO.SC.V6 Well-Known Member
    Clive
    MAXWELL AFB
    01 Tacoma 4WD SR5 Supercharged
    TRD Supercharger, URD 7th Injector Kit, 2" Body Lift, Rear Manual Air Bag Suspension, Marlin Crawler Rear Bumper
  9. Oct 13, 2015 at 6:40 AM
    #49
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Why do people just start posting links without reading the thread?
    SconnieHailer likes this.
  10. Oct 13, 2015 at 9:32 AM
    #50
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I got the headers off yesterday after work. Funny only took me about 2.5 hrs to get them off. My friend machined the flanges this morning. Said he had to take off 010 thousandths on the passenger side. The drivers side was fine. Its not a lot but I believe it was enough to cause the leak and trip the check engine light. Time will tell.
    In hind sight I should have just had the flanges machined before I put them on. I have done it with every manifold/header in the past. Don't know why I did not do it to this set.
    Also I don't want this to per-sway anyone away from UDR headers. This is just one of those things that happens some times with after market parts. I like to refer to them as nearly fit.
    SconnieHailer and Revelations like this.
  11. Oct 13, 2015 at 12:39 PM
    #51
    Revelations
    2014 MGM DCSB
    I think I read before that URD uses mild steel flanges. Their reasoning was a bit suspect imo.
  12. Oct 13, 2015 at 3:32 PM
    #52
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I got every think back together and running. I can't hear any leaks. I drove it around for a about 50miles. So far 2 check engine lights. Both PO420 :notsure: it's not doing as bad as last time. But still doing it.
    I have yet to hear back from UDR.
  13. Oct 13, 2015 at 3:34 PM
    #53
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Shitty deal
  14. Oct 13, 2015 at 3:51 PM
    #54
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    These are the equal length udr headers?
  15. Oct 13, 2015 at 3:54 PM
    #55
    SconnieHailer
    Marc
    "URD" equal length 12+ headers yes.
    I looked and mine are rubbing in the same spot as OP's. No bigs, solid motor mounts here I come :cool:
  16. Oct 14, 2015 at 1:05 PM
    #56
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Do you have other mods recently done on your truck? Like CAI?
  17. Oct 14, 2015 at 6:56 PM
    #57
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    This all started after the install of the udr headers and ypipe.
    I'm getting PO420 bank one catalyst.
  18. Oct 15, 2015 at 6:45 AM
    #58
    Vassily28
    Yeah i know,
    Just asking cause sometimes the problem can come from an other mod but the new mod put you out of the acceptable margin of error taht generate the signal.
  19. Oct 15, 2015 at 6:46 AM
    #59
    Vassily28
    You said you removed the headers, did you install new gasket between the headers and the Y-pipe flange?
  20. Oct 15, 2015 at 7:56 AM
    #60
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Yes I had 2 sets of ypipe to header gaskets. One set came with the headers and the other with the ypipe. So when I pulled the header and had the flanges machined then reinstalled them I installed new header to ypipe gaskets
