Udr headers/check engine light.
Discussion in 'Performance and Tuning' started by Brianawd, Oct 10, 2015.
  1. Oct 15, 2015 at 9:23 AM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    U R D
    U R D.
    Not "UDR." There.
    N/Es06, GT7 and SconnieHailer like this.
  2. Oct 15, 2015 at 12:28 PM
    #62
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I sometimes have the same problem but most of the time it seems to be related ot the activation of the traction control at hard acceleration on slip surface like rainy pavement.
  3. Oct 15, 2015 at 9:55 PM
    #63
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    So I believe the issue is resolved.
    I pulled the 0/2 sim back apart. I found water in the connectors(we go some heavy rain the other day) on both sides. More on the passanger side. I noticed no rubber seal. So I dried it all out and put in some die electric grease. So far 60miles and no check engine light.
    On a side note I'm also see a nice increase I'm MPG. Normly I get right around 200 a take in city drive. So far I'm at 210 and still a little over 1/4 tank.
  4. Oct 16, 2015 at 8:42 AM
    #64
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Oct 18, 2015 at 6:51 PM
    #65
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Just a update. What I thought I had fixed is not. Today I got code po420 and po430
    I cleared them then with in a few min got po420 again.
    I have now sent 3 emails to UDR and have not for a response. So I'm going to try calling them tomorrow.
  6. Oct 18, 2015 at 7:24 PM
    #66
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Dang, that's awful. I've been wanting a set of these, but not if it's going to throw codes all the time.
  7. Oct 18, 2015 at 7:54 PM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We have no issues with Lucario Runner's and I don't believe @SconnieHailer is either.
    This poor guy just seems to have bad luck with his.
  8. Oct 18, 2015 at 8:05 PM
    #68
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    No issues for me in respect to codes. Just header touching the coil bucket. Fixing that with solid motor mounts soon though...
    Torspd likes this.
  9. Oct 18, 2015 at 9:20 PM
    #69
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Where do you guys have the main 0/2 mounted?
  10. Oct 18, 2015 at 9:24 PM
    #70
    SconnieHailer
    Marc
    I mounted front o2 in the collector of the header and used the urd extension harness. Rear o2 is still in stock ypipe location with simulator attached.
    Torspd likes this.
  11. Oct 18, 2015 at 10:10 PM
    #71
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I'm going to try that. I think having mine mounted in the one runner could be causing some issue.
    Torspd likes this.
  12. Oct 19, 2015 at 4:53 AM
    #72
    Revelations
    2014 MGM DCSB
    Any idea if only installing the passenger side motor mount would keep it from rubbing?
  13. Oct 19, 2015 at 5:00 AM
    #73
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Even if it did,,, solid on one side, rubber on the other? I would be more concerned with the solid mount flexing it's way to cracking.
  14. Oct 19, 2015 at 6:21 AM
    #74
    Revelations
    2014 MGM DCSB
    I'm not into having vibrations at idle. If a solid mount cracks from vibrations, then it wasn't that great to begin with.
  15. Oct 19, 2015 at 8:01 AM
    #75
    SconnieHailer
    Marc
    Well just wait until I get mine and I'll tell you how much vibe there is at idle. I'll even solid mount a camera on the dash before and after. Should be able to tell how much vibe there is that way. I'm not worried about it, I hardly ever just sit idle in my truck, waste of gas
  16. Oct 19, 2015 at 8:08 AM
    #76
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Meh, these trucks have vibes anyways lol. Soon as you throw on an offroad tire and change the suspension, you've got vibes. There are guys who spend years and money trying to track down phantom vibes after a lift. Then theres those of us who shrug and say "its a truck, MOAR BOOST!". my solid engine mounts are sitting on my work bench, waiting for the solid transmission mount to be made so i can install the matching pair together. Vibes be damned!
    Torspd likes this.
  17. Oct 19, 2015 at 8:08 AM
    #77
    VolcomTacoma
    Jeff
    NorCal
    Also,
    URD
    URD
    URD
    URD
    :rofl:
    Justus, Torspd and SconnieHailer like this.
  18. Oct 19, 2015 at 8:29 AM
    #78
    Revelations
    2014 MGM DCSB
    That's fine if you plan on doing all that stuff, but I don't. I daily drive my truck and will never off-road intentionally. I won't be installing a lift, aftermarket suspension, or off-road tires. I sit at idle quite a bit during my commutes as well as when we go out.
  19. Oct 19, 2015 at 9:42 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We did the collectors. As he and I both knew that extensions were required. As well as he already had purchased extensions back when he had the 2nd Gen DTLT's.
  20. Oct 19, 2015 at 9:43 AM
    #80
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It'd make for some strange engine vibrations. That would very likely be felt in the cab.
