Udr headers/check engine light.
Discussion in 'Performance and Tuning' started by Brianawd, Oct 10, 2015.
  1. Oct 19, 2015 at 12:36 PM
    #81
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    I ordered the extensions Last night. I'm really hoping this fixes the issue. I think it will as it seems I'm the only having issue. If this does fix the issue then URD ;) will need to update there site that the 0/2 needs to go in the collector.
    I'm interested to see if you guys moved your 0/2s up if you would get the same issue as me
  2. Oct 19, 2015 at 12:40 PM
    #82
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Have you thought about swapping the left and right sensors to see if the problem stays with the sensor or the header?
  3. Oct 19, 2015 at 12:42 PM
    #83
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I have but I'm also getting p0430 some times. More p0420. I will try moving the o/2's down to the collector first. Then move on from there. Trying one thing at a time
  4. Oct 19, 2015 at 12:59 PM
    #84
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Smart move, just thought you might try moving them around while waiting for the extensions.
  5. Oct 20, 2015 at 9:50 AM
    #85
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Already did that. :thumbsup:
    http://www.xr-underground.com/forum/showthread.php?p=976300#post976300
  6. Oct 20, 2015 at 11:11 AM
    #86
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
  7. Oct 27, 2015 at 11:28 AM
    #87
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Just wanted to update you all. I got the 0/2's moved down to the collector. So far I have about 100miles since moving them and no check engine light. So it seems running the 0/2's in the single runner causes there to be to much of a variance between the 2 sensors even when running the 0/2 sims.
    Revelations and Justus like this.
  8. Oct 27, 2015 at 11:29 AM
    #88
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I like this
  9. Oct 27, 2015 at 11:40 AM
    #89
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Did not think this was going to work. Glad it did.
  10. Nov 6, 2015 at 12:57 PM
    #90
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    And you were right. Made a 200 mile trip to my parents house on Monday. No check engine light the whole way. The next morning I got up and did some running around and about 5 miles in check engine ligh. Code p0420/p0430.
    I would like to know if anyone else with these headers also has a TRD SC with the TRD flash.
  11. Nov 6, 2015 at 1:27 PM
    #91
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are the wires for the WRAF sensors swapped? Which side of the truck has the harness with the blue tape on it?
  12. Nov 6, 2015 at 1:37 PM
    #92
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I did one side at a time so no way I could have mixed them up.
    And when I pulled then back off to have the flanges machined I plugged the afr sensors back and then them hang
  13. Nov 6, 2015 at 4:31 PM
    #93
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    @Brianawd how is your header doing where it was rubbing your coil bucket? mine is rubbing like a mofo.
  14. Nov 6, 2015 at 5:26 PM
    #94
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    The header has a nice dent in it where the was hitting. It's clearanced it self. Can't really hear it rubbing anymore.
    On a side note I'm going to try and run a O/2 spacer on the rear O/2 and take out the URD 0/2 sim.
    I know people are going to say you can't do that because the the warf sensors needs the 2nd for cal. But VW have been using wide band 0/2 for years and people use spacers all the time on those cars.
    I'm just getting sick of the check engine light.
  15. Nov 6, 2015 at 6:08 PM
    #95
    SconnieHailer
    Marc
    Nice mine does too. I wish i had a go-pro to mount there and get video to see when it's hitting because i'm pretty sure mine touches under full throttle in 1st 2nd and maybe 3rd. I've got solid motor mounts going in next week so that should solve it for good. I'm tired of keeping out of the skinny pedal...
  16. Nov 6, 2015 at 6:23 PM
    #96
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^ I was just gonna say, sounds like a job for solid motor mounts :D
  17. Nov 7, 2015 at 7:18 AM
    #97
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Any possibility that the O2 SIM is bad? I would ask URD if there is a way to check it with a multimeter.
  18. Nov 7, 2015 at 8:19 AM
    #98
    VolcomTacoma
    Jeff
    NorCal
    Did he say he swapped them and got the same error code for one side?
  19. Dec 14, 2015 at 8:13 PM
    #99
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Sorry guys. Have not been on here much. Life has kept me away. I'm still getting codes. And the headers are still contacting the coil buckets. At this point i only get a check engine light after driving the truck for over a 100miles turning it off then driving some more. That's when it comes on. I just clear it and go on my way. Gadget has tried to help but seems to ask the same questions. I'm still going to use the old school 0/2 spacers and see if that fixes the issue.
  20. Dec 15, 2015 at 5:49 AM
    #100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At least with it being a 100 miles before a CEL, all systems are a go and you can still pass an OBD2 systems ready test.
