Udr headers/check engine light.
Discussion in 'Performance and Tuning' started by Brianawd, Oct 10, 2015.
  1. Dec 15, 2015 at 6:04 AM
    #101
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    @Brianawd You hooked the 02 sims into the rear 02's, not the AF sensors in the headers, correct? Ive been running the Doug Thorley long tube headers from URD for almost 4 years now with 02 sims and luckily have not had a CEL come on
  2. Dec 17, 2015 at 10:06 PM
    #102
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Yes the 0/2 sim is installed in the rear 0/2's
  3. Dec 22, 2015 at 9:16 AM
    #103
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Perhaps the sim is just going out of range once in a while, causing the code? If the O2 SIM is borderline on the output, then it should be addressed in the product. Here's excellent info on what may be the issue: http://repairpal.com/OBD-II-Code-P0420-Toyota
  4. Mar 23, 2016 at 11:57 PM
    #104
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Well pulled the URD o/2 sim and installed
    2 vibrant 0/2 sims. Guess what no more check engine light.
    SconnieHailer and Revelations like this.
  5. Mar 24, 2016 at 4:31 AM
    #105
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well that is good to hear. Had to just be a faulty unit. Mine has worked well for years. Either way I'm sure you're glad it's corrected.
  6. Apr 19, 2016 at 11:33 PM
    #106
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Does vibrant actually make a sim? Part number?
  7. Apr 20, 2016 at 5:04 AM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It isn't an electrical sim. Just a tube which extends the spark plug futher from the exhaust stream.
  8. Apr 20, 2016 at 7:38 AM
    #108
    TRON
    That's what I thought. You think there are any drawbacks for extending the rear o2 sensors?
  9. Apr 20, 2016 at 3:08 PM
    #109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    None. Unless it doesn't work. Cheap enough to try. Worked for Brianawd, and many other people on many other cars.
  10. May 6, 2016 at 2:21 PM
    #110
    Revelations
    2014 MGM DCSB
    :boink:
  11. May 6, 2016 at 5:50 PM
    #111
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good eye. Doh. O2 sensor. :facepalm:
    Revelations likes this.
  12. Feb 10, 2018 at 5:46 PM
    #112
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    I just finished my exhaust. URD equal length headers, URD offroad y-pipe and marklll 3" catback. I misread the torque specs for the headers. Headers are 16lbd and flanges are 47lbs? What sort of sounds would one hear that would suggest an exhaust leak? I understand the soot and the common lifter tic (like) sounds but on acceleration I'm getting some rattling, similar to a heat shield and a weird indescribable propeller like sound mixed with a pretty nice aggressive low note. I know.....propeller? But the closest thing I can compare it to would be like a small plane with popeller lol. I only get these sounds on acceleration but in the boost 3000+ rpm @ 1/2-wot and it sounds damn good. Only code I get is the p0300. Still haven't figured this out yet but I drive a spirited 45+ miles daily and it seams to be minor. Unless I'm really experiencing a multiple misfire and that is what I'm hearing now that I'm ABLE to hear it through the larger unrestricted system.
    But I've had the 300 code since I got the truck a year ago with factory exhaust.
    I also cleaned the maf sensore and throttle body recently and while doing that I discovered I have a 76mm tb from a 2010 5.7 tundra and that the ucon probably doesn't know that since I didn't know the last time I talked to Scott and Gadget @ URD. My next step is replacing the header manifold gaskets and attempting proper torque specs before recording some street runs for Scott and sending them with the throttle body info.
    Should I get the thick crush style or the layered steal tyep gaskets? I'd email Gadget but he's a busy dude, it's the weekend and I'd rather work on it than wait for a response.
  13. Feb 10, 2018 at 9:30 PM
    #113
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Had that Y-pipe and got that noise - an exhaust leak at medium acceleration. Changed all the gaskets and still had it. Put the original Y back on and it's gone. Think I like the tone of the Spec-U exhaust better with the stock Y anyway.
  14. Feb 10, 2018 at 11:18 PM
    #114
    N/Es06
    I wouldn't have done it but the old cats were blowing apart. Some are adding a resonator between the muffler and y-pipe.
  15. Feb 11, 2018 at 1:17 PM
    #115
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
  16. Feb 11, 2018 at 1:24 PM
    #116
    TRON
    An equal length y pipe and two mufflers in the catback will eliminate that noise
    Torspd likes this.
  17. Feb 11, 2018 at 3:47 PM
    #117
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Second this. Mines still pretty loud and a slight rasp when cold
  18. Feb 11, 2018 at 6:57 PM
    #118
    JaxJacket
    2013 DCLB
    Anybody make a pre-fabbed equal length y-pipe, or is that a do it yourself proposition?
  19. Feb 11, 2018 at 6:59 PM
    #119
    SconnieHailer
    Marc
    I've only seen one and it's for 2wd only. Don't think it's made anymore either.
  20. Feb 11, 2018 at 8:02 PM
    #120
    TRON
    Most reputable custom exhaust shops can easily replicate the APR equal length y pipe. It’s a great design that APR came up with first
    SconnieHailer likes this.
