Ugghh Aftermarket Spyders!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by perchie15, Jun 8, 2012.
  1. Jun 10, 2012 at 6:10 PM
    perchie15
    perchie15 [OP] Well-Known Member
    Joey
    Alberta
    TRD
    None,
    Thought someone was telling me no need to take them apart??
  2. Jun 10, 2012 at 6:15 PM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Well I left it in oven for 10mins and still has moisture!!
  3. Jun 10, 2012 at 6:23 PM
    perchie15
    Joey
    Alberta
    TRD
    None,
    So I'll leave them over night and see what happens? U guys think it still have a good seal with just putting silicone on the edges. Without taken it apart??
  4. Jun 10, 2012 at 6:54 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yes.. you DON'T need to take them apart.. just heat them up.. and PRESS them together to make sure they are sealed.. then. Just ADD silicone to the entire edge. Let them sit, overnight, lenses down.
  5. Jun 10, 2012 at 6:55 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Right? lol. Its just us in here too.. Hahaha
  6. Jun 10, 2012 at 9:18 PM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Lol it's faster then editing it
  7. Jun 10, 2012 at 11:10 PM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Well I put it in oven for 2nd time and it's getting bit better, but still moisture so I'll let it sit overnight. And see what happens. There's a few water spots inside the lens so I'll prob end up taken it apart now... Just to clean off the spots.. Less moisture then there was forsure :)
  8. Jun 11, 2012 at 5:46 AM
    perchie15
    Joey
    Alberta
    TRD
    None,
    There was about 100ml in it
  9. Jun 12, 2012 at 11:05 AM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Ya I'm gonna take it apart gotta get the waterspots out! Clean the lens
  10. Jun 12, 2012 at 11:15 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I have stuck them in the oven to rid the housing of moisture but I found what worked best for me was using a heat gun and using all of the light bulb socket openings to blow in hot air. I assume a hair dryer would work as well but the heat gun is what I used.
  11. Jun 12, 2012 at 11:18 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yes.. times a million! Ask me how I know..
    I would honestly avoid wiping the inside of the lenses at all. I had this issue.. and wiped It down (mistake one).. with cleaner (mistake two) and it left marks and swirls. The black DEFINITELY shows more.. the second set of lights I bought I made sure not to touch the Inside of the lenses.. and they look perfect. IF you have to clean them.. use distilled water.
  12. Jun 12, 2012 at 11:26 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No worries :)
    Hopefully OP gets it fixed. I know how It feels.. took me lots of monies and time to get them fixed. So good luck OP!
  13. Jun 13, 2012 at 10:45 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Any update OP?
  14. Jun 14, 2012 at 5:54 AM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Well I end up using glass cleaner :S. get The water spots off and end up rubbing The chrome off the reflector part where the headlight bulb goes ahhh!!! So I had to swap it out and put my factory one in there!! And so after I got it All back together. It is now drying with gator clamps help it to dry better i will probably put the light in tomorrow wait a good 24hrs to dry it out!! and see what happens from there!! I have a feeling end up buying another set :(... Since I did use windex to get water spots off ahhh
  15. Jun 14, 2012 at 7:25 AM
    #35
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oooh, ok man.. if you have any issues or have OCD like i do, just get another set, and add silicone prior to Install.. cuz there's gonna be a film and you probably won't like them.. atleast i didnt. Maybe you won't care. Lol
    Post some pics when you can. :thumbsup:
  16. Jun 15, 2012 at 4:57 PM
    #36
    perchie15
    Joey
    Alberta
    TRD
    None,
    Yeah I'm going to install them tonight an see what happens next few days if t rains and no moisture then I'm all set :). Right now don't look like there's a film in the light.. Shouldn't be no moisture I siliconed the crap out of it lol.
  17. Jun 15, 2012 at 4:59 PM
    #37
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Right on man. Good to hear.
  18. Jun 15, 2012 at 5:05 PM
    #38
    TRDBeast
    TRDBeast Boogie Man Kryptonite
    Wayne
    Coconut Creek, FL
    08 Tacoma Crew Cab TRD
    Brute Force front armor with 30" rigid and dual 4" quad rigid fogs OME suspension 3" lift with Dakar leaf pack and ToyTec body lift for total 4.25 LR UCA's 9000 sport Nitro Charger shocks 885X Coils AFE Pro Dry CAI 18" Rockstars Alpine DDIN systemw/Nav, Bluetooth and DVD 2 12's Infinity Kappa's in doors and Alpine 6.5 X 9 in front and back and 2 Alpine Zeus amps rear 2 Rockford Fosgate amps front NFab running boards Dyno tuned FXRs w/ 3" Projectors and Halos retrofit w/ Apollo shrouds and 5000k HID 55W Debadged Wet Okole skins HomerTaco Satoshi grill Elusive Elements light support with 2 Hella 500ff's behind grill Powder coated tool box TRD gear shift Andres Devil Horns TREX eyelids Body Armor rear bumper 15% Tint "ZOMBIE" light switches Custom gun concealer in dash One-piece aluminum drive shaft LED interior light swap
    I bought the spyders and did a retro fit projector with them. no problem once I resealed them. just seal them really good and let it dry before you put them back on... :D
  19. Jun 15, 2012 at 7:53 PM
    #39
    perchie15
    Joey
    Alberta
    TRD
    None,
    SOB!!! The one headlight is crapped. I went to adjust it and it just keeps turning and turning not getting tight after I siliconed it all and anyways now the light is shining to far over to the driver side.. So think I might end up ordering a new set ughh!!!
  20. Jun 16, 2012 at 11:40 AM
    #40
    perchie15
    Joey
    Alberta
    TRD
    None,
    Anybody know if anybody sells just a single headlight instead of buying the whole set???
