ugh.. i cant get my driveshaft out!
Discussion in 'Technical Chat' started by darkturtleninja, May 10, 2009.
  1. May 10, 2009 at 9:47 AM
    darkturtleninja
    darkturtleninja [OP] 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    this is starting to piss me off... im changing the clutch in my 95 taco and i cant get my driveshaft out!.... ive taken all of the bolts out of the flanges on each end....in theory it should just fall...but no! it wont budge... ive tried rapping on it with my BFH... ive tried putting a jack under it and jacking it up... ive even tried spinning the tire as fast as i can and having the old lady sit in the cab and dump the clutch while im spinning the tire.... it just wont come out.... is there something im missing or what?
  2. May 10, 2009 at 9:49 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    this is the front shaft, correct?
  3. May 10, 2009 at 9:51 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    no the rear.... i will be doing the front also....
  4. May 10, 2009 at 9:53 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    did you take the carrier bearing out?
  5. May 10, 2009 at 9:57 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    um...? no....the haynes bood didnt say anything about that..... i better read more... any info you can give me is appreciated!
    yeah it doesnt say anything about it... it just says unbolt the flanges and remove the driveshaft... but the flanges will not seperate...
  6. May 10, 2009 at 10:04 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    does a standard cab have a carrier bearing?? if not and you have truly tried everything you can think of.. maybe start the truck and try and take off with the parking brake set... torque of the motor should pop it loose... just be prepared to hear a big bang when it hits the ground.. :D
    yea i know... redneck solution. but ya gotta be inventive sometimes!
  7. May 10, 2009 at 10:06 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    i actually did think about doing that.... but i figured it might hurt something....
  8. May 10, 2009 at 10:33 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Pry bar?
  9. May 10, 2009 at 10:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Dont use the engine to get it out. It will come.
  10. May 10, 2009 at 5:09 PM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    well i got it out... turns out its pretty much a 2 person job.... my father helped me after he got out of church.... he got the ol chisel out and sharpened it up and after a few rapps with the bfh it came out.... well anyhow... the driveshaft was the least of our problems... we got the tranny out and removed the clutch components and we couldnt get the bearing out for nothing.... we tried the whole packing it with grease and using a bolt and hammer to force it out... well it was a no go.... the bearing was dry and had no seal on the front or back so the grease was just shooting out between the little "bb's"....and its sunday and the local hardware store was not open and we didnt have the right puller so it took about 4 hours to get the damn thing out... i dont know how he did it but he finally got it... so by then he was tired(he is old) and was done for the night so the tranny will sit on the garage floor till he gets off work tomorrow....
    so here after bit ill go back out and clean my flywheel and put the new clutch kit in....
    btw the old clutchplate was shot.... not much left of it....
