UGH Mobil 1 75w90 GL5 Full Synthetic safe in my 5speed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bluebr65, Feb 2, 2012.
  1. Feb 2, 2012 at 7:58 AM
    bluebr65
    bluebr65 [OP] Active Member
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    I have searched and searched and searched. Still unclear if new synthetic gear oils like GL5 Mobil 1 75w90 synthetic in my t-case and manual transmission (2001 2.7) will cause problems? Are the newer GL5 lubes ok to use or should I drain and wait till next week when my four quarts MT-90 comes in? I'm paranoid to all hell because my taco is my only ride and I dont want to drive her (highway and roads) if this will kill the drive-line in a weeks time. Oh god please someone, I'm meltingggggggg
  2. Feb 2, 2012 at 8:43 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Um I've had Mobil1 synthetic gear oil in my TC/Transmission for almost a year and nothing's blown up on my so I think you're all good there.
    I also run partial synthetic in my rear dif...all good!
  3. Feb 2, 2012 at 10:51 AM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    That helps def. I still ordered the redline just to be sure. I'll change out the mobil 1 next week for peace of mind.
  4. Feb 2, 2012 at 8:55 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Synthetic GL5 doesn't come with the problems petroleum-based GL5 can cause. You're fine with Mobil 1 but, if you've got money to burn, you can swap it out
  5. Feb 2, 2012 at 9:07 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    specs calls for gl-4 or gl-5 so i'd think you'd be fine with any. i'd just stick with the redline mt-90 personally. its in my tranny & t-case and does works well and isn't much more expensive than the mobile 1
  6. Feb 5, 2012 at 9:06 AM
    frank1970
    frank1970 Member
    Alabama
    96 Tacoma 3.4 4x4
    I've been running synthetic in mine for 3 years now. No problem!
  7. Feb 5, 2012 at 12:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ive used the mobil1 75w90 in my diffs,transfer case since i bought my 04. no probs. you wont have any probs with it.
  8. Feb 5, 2012 at 12:24 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    I had the same question a while back as you OP... i heard along the way that the GL5 could strip the soft (yellow) metals in the trans. How true this is, I don't know, and no one really touched on that subject. I ended up going with Amsoil 75-90 GL4 sever gear. i know plenty of people on here use gl5 so i guess its ok. I think the manual says gl4 (I COULD BE COMPLETELY WRONG) so thats what i went with
    If anyone could touch on the subject of why or if gl5 is bad, would be much appreciated
  9. Feb 5, 2012 at 1:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if i remember correctly...some of the additives can eat up the syncros.
  10. Feb 6, 2012 at 6:58 AM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    Thank you all for the informative responses, I'm still weary on the synthetic GL5, in about 24 hours the tcase and trans will be holding fresh mt-90. Hope that smooths out the 1- 2 - sometimes 3; hard gearshifts when things are cold. It sort of improves when things warm up but ugh why so hard to shift? Clutch is good, please don't be synchros......
  11. Feb 6, 2012 at 7:54 AM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    Let us know if you notice a difference with the Redline MT 90 in the transmission. I would be curious as I run Mobile 1 75w90 full synthetic and also have the rough shift on first, second in cold weather. Would appreciate hearing if you think it smooths out the shifts.
    Thanks
  12. Feb 6, 2012 at 2:32 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    my cold shifts into 1st and third suck too. Interested if the mt-90 makes a difference.
    The mt-90 made a slight improvement in my bmw 5 speed tranny. I'm considering it for the taco as well based on your feedback.
  13. Feb 6, 2012 at 2:34 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  14. Feb 6, 2012 at 9:55 PM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    I should have some detailed feedback for you guys on wednesday late night after I get back from the garage. I'm super hopeful for the Redline products from what I have read. Let's see if they can kill the notchy, not so smooth shifting!
  15. Feb 7, 2012 at 8:38 AM
    87xjmike
    Folsom
    98 5lug 2rz
    Please do, i've ran two different types of fluids in 4k miles and i still can't kick the hard shifts. I'm willing to pay extra for whatever works in these sombitches. Does yours ever pop out of first when cold? Mine does. Prolly the syncros, so i'm looking for something to preserve those muthas.
  16. Feb 7, 2012 at 11:24 AM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    I'm the same man, these transmissions shift so hard, its not natural. Especially for me coming from the world of cars. I think I get angry while driving because I want the shifts to be smoother but the 1 - 2 - 3 in the cold is just not effin' smooth at all!!! I'll have an initial drive report tomorrow late night for you all. Keep in mind, im switching from a weeks old Mobil 1 75W90 Synthetic gear oil to Redline MT90 for all the detail nuts.
  17. Feb 7, 2012 at 11:28 AM
    87xjmike
    Folsom
    98 5lug 2rz
    cool beans thanks
  18. Feb 7, 2012 at 1:00 PM
    pt law
    Concord, NH
    04 xtracab 4x4 TRD
    Keep us updated. I am interested in hearing if you notice any difference now and if not, may be in a couple weeks. It would be a great help to us who struggle with the really hard shifts in 1 and 2nd gear in the cold.
    Hope it works for you.
  19. Feb 9, 2012 at 5:26 AM
    bluebr65
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    Cheers! Didn't get the chance to swap the fluids on the truck last night but I will be right after work today.
  20. Feb 9, 2012 at 8:53 AM
    87xjmike
    Folsom
    98 5lug 2rz
    fuck this cold morning and fuck these cold hard shifts, somethings gotta change now, i'm doing some mt90 gl4 tonight.
