Ugh... Rear diff FUBAR /OEM help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robstercraw, Jul 5, 2016.
  1. Jul 5, 2016 at 5:12 PM
    robstercraw
    robstercraw [OP] Member
    Austin, Texas
    2006 Tacoma TRD Off Road
    Somehow my top fill plug backed out and caused all my oil to leak out. I didn't notice it until it was too late, even though I stopped immediately when I smelled it and had it towed. No idea how it came out as my last rear diff service was 50k miles ago. I'll need a whole new 3rd member assembly as the gears are shot and the "pumpkin " was full of metal shavings.
    Anyone know the best place to order the OEM rear assembly (41110-35A20)? Dealerships in the area want 1620.00.
    Thx y'all... Off for a drink to drown my sorrows.
    2006 TRD OR 4x4
  2. Jul 5, 2016 at 5:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    east coast gear supply.
    Call them up, they will get you hooked up for the cheapest price with a full 3rd member.
    Id also consider replacing any outer bearings n seals if it was full of metal shavings.
    scottalot likes this.
  3. Jul 5, 2016 at 5:37 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Wow gl.
  4. Jul 5, 2016 at 5:37 PM
    Pigpen
    Dan
    Northwest Montana
    Get an axle from a junk yard. If you have the tools, it should be a pretty straightforward swap.
  5. Jul 5, 2016 at 5:42 PM
    Pigpen
    Dan
    Northwest Montana
    I would want to replace seals, bearings, axles and the third. That's why I vote junk yard. Just get the whole assembly and bolt it up, or have your mech do it.
    If you hadn't smoked it, I'd say ECGS.
