Ugly Gold 4 door Hoor SAS-LS
Discussion in '1st Gen. Builds (1995-2004)' started by Yota X, Jan 31, 2022.
  1. Apr 1, 2022 at 4:19 PM
    #301
    Yota X
    Yota X [OP] Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    500lbs of rubber and aluminum in route finally! This is the part/s I’m looking forward to the most! Can’t wait to see how these look.
    ToyRyd04 and Slashaar like this.
  2. Apr 1, 2022 at 4:26 PM
    #302
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    40s? :rofl:
    Yota X[QUOTED][OP] likes this.
  3. Apr 1, 2022 at 4:37 PM
    #303
    Yota X
    NW New Jersey
    1st gen
    Yes sir!
    Kwikvette and Slashaar[QUOTED] like this.
  4. Apr 1, 2022 at 4:46 PM
    #304
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Curious, will future replacement or service of the starter require any extra work, or is it accessible to you now? Awesome stuff.
    Slashaar and Yota X[OP] like this.
  5. Apr 1, 2022 at 4:57 PM
    #305
    Yota X
    NW New Jersey
    1st gen
    Thanks man. I originally was considering minor changes to get it in there but it would have been an in shop fix to swap the starter so I changed completely. Now it is fully accessible and easier than stock to get out.
    Slashaar and MalinoisDad[QUOTED] like this.
  6. Apr 1, 2022 at 5:48 PM
    #306
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Try just putting heavy tacs on everything till you pretty close to done. I learned that the hard way same as you. A heavy tac is easier to cut than redoing an entire mount. Then when your close to done with the project; you just spend a day (or in my case a week) welding everything
  7. Apr 1, 2022 at 7:41 PM
    #307
    Slashaar
    Josh
    Kansas City, MO
    :eek: :benchpress:
  8. Apr 2, 2022 at 2:49 AM
    #308
    Yota X
    NW New Jersey
    1st gen
    For sure! Im starting the links this week. Im not welding anything solid til its rolling and been tested with tires on outside of shop!
  9. Apr 2, 2022 at 11:27 AM
    #309
    malburg114
    Las Vegas, NV
    Pretty much how I did it. Besides the frame and some other important things I didn’t want breaking, I tacd everything and cycled. It saved me a ton of time because there was a lot of grinding and cutting to get my stuff to fit
  10. Apr 4, 2022 at 4:06 PM
    #310
    Yota X
    NW New Jersey
    1st gen
    Been losing sleep over it, but I think Im gonna do a little swap-a-roo for a motor that makes power and can run on 89 or ethanol. LS too big. Not trying to have a clusterfuck in the bay. Have a few days to decide. Kinda gonna suck to scrap the whole drivetrain but im thinking better now than later.
    Anton338, Slashaar, jubei and 2 others like this.
  11. Apr 4, 2022 at 4:14 PM
    #311
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    What motor is that?
  12. Apr 4, 2022 at 4:15 PM
    #312
    Yota X
    NW New Jersey
    1st gen
    2014-2018 chevy 4.3 ecotec.
    easleycrawler[QUOTED] likes this.
  13. Apr 4, 2022 at 4:19 PM
    #313
    easleycrawler
    Travis
    2014 RC Taco 4wd
    That's what I thought, but wanted to make sure before I talked through my ass. That will be pretty sweet and definitely different.
  14. Apr 4, 2022 at 4:20 PM
    #314
    easleycrawler
    Travis
    2014 RC Taco 4wd
    What trans and t case?
  15. Apr 4, 2022 at 4:27 PM
    #315
    Yota X
    NW New Jersey
    1st gen
    4.3 is a great motor but the old ones don't make a lot of power. This 14 and up does. Basically the same as a 2uz and its small. Its dimensionally similar to the 3.4 as well. Just have to get a Howell harness for it and deal with the bs of wiring tank and speedo and have to make a power steering bracket to hold whatever psc pump is best. Prob one for an LS. The biggest issue is, im gonna have to go to an atlas cause the harness for a 4l60/700r4 is like 500 more and the adaptor for the yota case to that is another few hundred so it just makes sense to swap and sell most likely.
  16. Apr 4, 2022 at 4:29 PM
    #316
    easleycrawler
    Travis
    2014 RC Taco 4wd
    Atlas is definitely your best bet. Your setup now should sell pretty quick.
    slander and Yota X[QUOTED][OP] like this.
  17. Apr 4, 2022 at 4:30 PM
    #317
    Yota X
    NW New Jersey
    1st gen
    Im thinking now is the time to sell the cases as well. The trans that comes with that motor is a 6l80 btw.
  18. Apr 4, 2022 at 4:33 PM
    #318
    Slashaar
    Josh
    Kansas City, MO
    Fuel Efficient and powerful! Runs on Alcohol!
    Anton338, ToyRyd04, jubei and 2 others like this.
  19. Apr 4, 2022 at 4:36 PM
    #319
    Yota X
    NW New Jersey
    1st gen
    That company is def out of my price range! lol Looks sweet though.
    Slashaar[QUOTED] likes this.
  20. Apr 4, 2022 at 6:47 PM
    #320
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    LV3’s are awesome and a buddy is just about done swapping one in his 80 for a lot of the reasons you mentioned. Running a black box in front of an 80 tcase.
    The biggest problem has been getting it tuned/wired since the EPA crackdown. Swaptime shafted him on a harness/PCM and I think he’s ended up doing most of it on his own. Made me know that I’m just going regular LS for ease when that time comes.
