Ugly Gold 4 door Hoor SAS-LS
Discussion in '1st Gen. Builds (1995-2004)' started by Yota X, Jan 31, 2022.
  1. May 27, 2022 at 6:25 PM
    #561
    Yota X
    Yota X [OP] Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
  2. May 27, 2022 at 6:30 PM
    #562
    Kwikvette
    Fresno County
    4 run, 2 don't
    And here my boss tells me 'it's ok to be off a cunt hair or two' :rofl::bananadead:
  3. May 27, 2022 at 6:46 PM
    #563
    Yota X
    NW New Jersey
    1st gen
    Man, I DO NOT want to have to redo either of these diffs on the truck. Trying to make perfect while up on a stand.
    Slashaar and Kwikvette[QUOTED] like this.
  4. May 27, 2022 at 7:42 PM
    #564
    Yota X
    NW New Jersey
    1st gen
    Thanks Yukon! Master shims for air locker completely fucked. So, this project is on hold.
    5705D928-B8EC-4867-AEE8-73E4FB823AB3.jpg B1DB9F84-ED5E-4200-9E45-3DD85735B067.jpg
    Slashaar likes this.
  5. May 28, 2022 at 12:38 PM
    #565
    02hilux
    Planet: EARTH
    Just pedal it through
    Yota X[QUOTED][OP] likes this.
  6. May 28, 2022 at 7:18 PM
    #566
    Yota X
    NW New Jersey
    1st gen
    I tried flattening them. I will get my carrier preload right w them and in like a few hundred miles it will be like way outta whack. Just gonna call and bitch Tues. hopefully my atlas gets here wed or Thursday and I can make some progress.
  7. Jun 3, 2022 at 7:41 AM
    #567
    Yota X
    NW New Jersey
    1st gen
    Think pinion may be too close.
    CD5529E7-EE77-4F59-9DA4-610C5F7A03EC.jpg 722FBAAA-A11F-46E3-8D45-C9A501F811CF.jpg
    Slashaar and ToyRyd04 like this.
  8. Jun 3, 2022 at 7:47 AM
    #568
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    What's your Backlash right now? Looks like pinion is too deep in the ring gear, and want that pattern a bit closer to the toe of the ring gear.
    Its close though, because pattern isn't bad.
  9. Jun 3, 2022 at 8:05 AM
    #569
    Yota X
    NW New Jersey
    1st gen
    -.02 cleaned it up a lot
    EA3AD922-062F-4141-AA93-E85904557B60.jpg 273EA80A-540F-4A3A-A9AB-4FAF9EF62C53.jpg
    Slashaar, Kwikvette and ToyRyd04 like this.
  10. Jun 3, 2022 at 8:05 AM
    #570
    Yota X
    NW New Jersey
    1st gen
    backlash is 8
    Took .02 from pinion.
  11. Jun 3, 2022 at 9:09 AM
    #571
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Looks much better, pattern is slightly wider and not as deep in the ring gear.
    Kwikvette and Yota X[QUOTED][OP] like this.
  12. Jun 3, 2022 at 1:08 PM
    #572
    Yota X
    NW New Jersey
    1st gen
    I’m gonna press bearings on like that I think. I had to redo the pinion preload for some reason. I’ve had it on and off about 30 times today.
    you think I need to set pinion back more? That last pattern seemed like if I took more it would just make the surface area smaller.
  13. Jun 3, 2022 at 2:38 PM
    #573
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    I think the ring gear looks great now, wider contact patch.
    What's your pattern on the pinion look like? Did it change any with the .02 removed?
  14. Jun 3, 2022 at 3:12 PM
    #574
    Yota X
    NW New Jersey
    1st gen
    Everything was money. I swapped the setup race w press in and pressed carrier bearing and the carrier backlash is at 3 in some spots and 5/6 in others. Something is def not right. I think the race isn’t seated.
    Pinion preload also shot up from 15 to 30 which seamed dramatic w just a race and seal.
    had to leave so gonna try to spend some time on it tomorrow.
  15. Jun 3, 2022 at 3:25 PM
    #575
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Sounds like there's a shaving or something hanging a roller on the bearing. Should be easy to see with (hopefully small to no scoring). Also, reading pinion preload without the pinion seal on? Sounded like your using setup parts before final install.
    Wulf and Yota X[QUOTED][OP] like this.
  16. Jun 3, 2022 at 3:45 PM
    #576
    Yota X
    NW New Jersey
    1st gen
    The seal bumps pinion preload 1-2 inch lbs. I checked it prior to installing it and the preload was like 29 and went to 30. I just keep it low to start. You can’t have everything setup on these ford 60’s. Pinion preload is 20-35 so I started at 15. I was expecting it to go to 25.
    Backlash can change w the one new bearing vs the setup bearing I had in but it’s the fact that it’s different around the ring.
    Either the shims on carrier bearing got cock eyed on the press, race is not seated or some scrap metal from new yoke and nut flew in there like you suggested. Hope it’s just the carrier bearing.
  17. Jun 5, 2022 at 8:01 AM
    #577
    Yota X
    NW New Jersey
    1st gen
    @ToyRyd04 Good call. Pinion is way smoother. This was stuck under pinion and a roller. Resetting carrier preload now. Hope that was part of the problem.
    a2lowvw, jubei, Slashaar and 2 others like this.
  18. Jun 5, 2022 at 8:01 AM
    #578
    Kwikvette
    Fresno County
    4 run, 2 don't
    Damn, the smallest things...
  19. Jun 5, 2022 at 8:16 AM
    #579
    Yota X
    NW New Jersey
    1st gen
    just found a second. Keep spraying and gravity draining then adding oil. Hope no more. Idk wtf it’s from though. Looks like chrome flake.
  20. Jun 5, 2022 at 9:24 AM
    #580
    02hilux
    Planet: EARTH
    Partout....:rofl:
