Ugly Gold 4 door Hoor SAS-LS
Discussion in '1st Gen. Builds (1995-2004)' started by Yota X, Jan 31, 2022.
  1. Feb 7, 2022 at 2:58 PM
    #41
    Yota X
    Yota X [OP] Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Thats sweet! That would be really nice! Those axles are awesome man! If I didn't have the lift I would do something like that. The 520 is adjustable. Can raise and lower it. Its actually perfect for axles. Ghetto but works. I want the damn thing to be under the car!
    Slashaar likes this.
  2. Feb 7, 2022 at 3:34 PM
    #42
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    You gonna box the frame while everythings out?
    skeletron and Yota X[QUOTED][OP] like this.
  3. Feb 7, 2022 at 3:36 PM
    #43
    02hilux
    Planet: EARTH
    That probably work better because you're able to raise and lower.
    Yota X[QUOTED][OP] and Slashaar like this.
  4. Feb 7, 2022 at 3:38 PM
    #44
    Yota X
    NW New Jersey
    1st gen
    Idk yet. Just trying to get all the t case/trans stuff done so I can get the pinion angle figured out. Am I gonna have issues with the frame twisting or bending without boxing it?
    Slashaar[QUOTED] likes this.
  5. Feb 7, 2022 at 3:40 PM
    #45
    Slashaar
    Josh
    Kansas City, MO
    Just as much as usual I'd guess, but I'll be doing it to mine eventually. If you go hard, you might think about it down the line. Some swear boxing is the way and others say just go full tilt and cage.
    Yota X[QUOTED][OP] likes this.
  6. Feb 7, 2022 at 3:44 PM
    #46
    02hilux
    Planet: EARTH
    I would highly recommend boxing the inner c frame and plate the outer as well.
    Slashaar and Yota X[OP] like this.
  7. Feb 7, 2022 at 3:46 PM
    #47
    Yota X
    NW New Jersey
    1st gen
    Ill prob take a look at the frame once im done with the sas and see how much flex it has I guess and make a decision then. Its easy to get underwater on builds like this and then you never get done. I don't want that to happen. lol
  8. Feb 7, 2022 at 3:47 PM
    #48
    Yota X
    NW New Jersey
    1st gen
    Did you do that to the current truck? Have any pics?
  9. Feb 7, 2022 at 3:53 PM
    #49
    Slashaar
    Josh
    Kansas City, MO
    Yota X[OP] likes this.
  10. Feb 7, 2022 at 3:55 PM
    #50
    02hilux
    Planet: EARTH
    Yep.
  11. Feb 7, 2022 at 3:57 PM
    #51
    Yota X
    NW New Jersey
    1st gen
  12. Feb 7, 2022 at 3:58 PM
    #52
    Yota X
    NW New Jersey
    1st gen
    Damn, thats nice! That's not too big of a deal either. Btw, where did you get those rigid screw jacks?
  13. Feb 7, 2022 at 4:06 PM
    #53
    02hilux
    Planet: EARTH
    Grainger. At the time, they were cheaper there vs Ebay/Amazon. Ridgid #56662 got them for cutting pipes but work for what I use them for.
    The new ridgid designed is collapsible, which I think is not as HD as the non-foldable. They're rated for 2500lbs each.
    #53
    Slashaar and Yota X[QUOTED][OP] like this.
  14. Feb 7, 2022 at 4:07 PM
    #54
    Yota X
    NW New Jersey
    1st gen
    Cool thanks! I need those bad! My ghetto pallet jack setup has to go!
    #54
  15. Feb 8, 2022 at 3:35 PM
    #55
    Yota X
    NW New Jersey
    1st gen
    i just talked to Marlin and he said his coupler won’t fit in the tg housing. He said it hits or something. Looks almost the exact same in pic. Is that true or no?
  16. Feb 8, 2022 at 3:41 PM
    #56
    Yota X
    NW New Jersey
    1st gen
    Took trans apart today. May just swap the shaft and be done with it. This case is shit.
    Mark77 and Slashaar like this.
  17. Feb 8, 2022 at 3:47 PM
    #57
    02hilux
    Planet: EARTH
    They got bad info. Many folks I know run tg adapters with MC 4.7 and MC coupler without issue
    Yota X[QUOTED][OP] and skeletron like this.
  18. Feb 8, 2022 at 4:01 PM
    #58
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    You don't think plating the outside in addition to boxing it is a bit overkill compared to just boxing it?
  19. Feb 8, 2022 at 4:39 PM
    #59
    02hilux
    Planet: EARTH
    Nope. Same concept as the front. Why plate it when it's square from factory. It's added insurance and cheaper to get it done right the first time. Plus I'm not on leaf so there's more frame twist in the rear
  20. Feb 8, 2022 at 6:18 PM
    #60
    betterbuckleup
    Ian
    Concord, CA
    Fair point.
    What plates are those. The TG ones I have don't cover that same length.
