Ugly Gold 4 door Hoor SAS-LS
Discussion in '1st Gen. Builds (1995-2004)' started by Yota X, Jan 31, 2022.
  1. May 3, 2023 at 4:23 PM
    #1581
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I was taught you want it near the bend and if there's any peppering at all you need to back off.
    Yota X[QUOTED][OP] likes this.
  2. May 3, 2023 at 4:26 PM
    #1582
    Speedytech7
    Sounds like you might actually be able to go further with gasoline. Rules for alcohol and gasoline are different
    https://www.google.com/amp/s/www.mo...ark-plug-reading-101-dont-leave-hp-table/amp/
  3. May 3, 2023 at 4:39 PM
    #1583
    Yota X
    Yota X [OP] Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Ok, yeah, so I guess the timing is still too high if its too far out on the tip vs the radius. The Holley map had timing at 30 degrees up to 7psi. Im really glad I am precautious with testing cause I woulda blown it up at 6-7k even at 5.5 psi.
    This is the original ignition map for my setup. I can't believe they even put it on base cals. Prob hundreds of people have bent rods with this.
    Slashaar likes this.
  4. May 3, 2023 at 4:40 PM
    #1584
    Speedytech7
    Have you scoured the sloppy mechanics pages for a baseline map? They have excellent resources for boosted LS guys.
  5. May 3, 2023 at 4:47 PM
    #1585
    Yota X
    NW New Jersey
    1st gen
    No, didn't know they even had maps but I did model my ignition off there little boost gauge with all the points of safe timing based on boost. At this point I want to spend the time and make it special for my truck so I can diagnose issues in the future easier. Ill def go see if I can steal some detail off them though.
    On another note, I got one of those Amazon intercoolers (american based company supposedly) but it was like $190 I think. Perfect fit for a tacoma. It is so damn good that I didn't believe the MAT readings. I tested sensor like 10x. It runs at pretty much 70-75 degrees intake air temp even after like 4 pulls and driving around in 80 degree weather. Basically like 10 degrees less than air temp. Very happy about that.
  6. May 4, 2023 at 6:37 PM
    #1586
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
  7. May 9, 2023 at 4:08 PM
    #1587
    Yota X
    NW New Jersey
    1st gen
    Got muffler mounted. Made use of some spare parts. She is stealthy-ish now.
    9A2EA42B-9911-457C-BC12-370ACE13C574.jpg 23D61392-25E8-441E-92EF-08CD7246122B.jpg
    Slashaar, la0d0g, ToyRyd04 and 4 others like this.
  8. May 9, 2023 at 4:14 PM
    #1588
    02hilux
    Planet: EARTH
    Expensive hanger :eek:
  9. May 9, 2023 at 4:17 PM
    #1589
    Yota X
    NW New Jersey
    1st gen
    Lol. Not as expensive as me having to grind, weld and repaint that crossbar. :rofl::rofl: Getting that exhaust done was a major priority. Ill prob have to change it but at least I can drive in peace for now.
  10. May 9, 2023 at 4:25 PM
    #1590
    02hilux
    Planet: EARTH
    I feel you, lol. Did mine 4x already and might have to redo it one more time after a trail test and flex run this summer.
  11. May 9, 2023 at 4:31 PM
    #1591
    Yota X
    NW New Jersey
    1st gen
    Yeah, I nailed the first half but the second half has been done 3 times. Ended up like an inch lower than I wanted it to be in back. Can prob make up 1/2 that but it is like 6" from top of AntiWR so it may hit. I may just let it dent it. Truck is quiet as shit now though so kinda liking it.
    jubei, sparkystaco and cynicalrider like this.
  12. May 9, 2023 at 6:03 PM
    #1592
    02hilux
    Planet: EARTH
    Yes sir. Mines lower than what I want but will have to wait. Everything to the muffler is good.
  13. May 9, 2023 at 6:59 PM
    #1593
    Yota X
    NW New Jersey
    1st gen
    Looks good man! I can't believe you wrapped that whole exhaust!!:rofl::rofl: That must have taken forever!
  14. May 9, 2023 at 7:40 PM
    #1594
    02hilux
    Planet: EARTH
    Definitely a bitch but I got soft brake line, soft fuel lines, rubber diff breather, and locker air lines on the upper link running a few inches away from the exhaust. Rather be safe than sorry
  15. May 9, 2023 at 7:43 PM
    #1595
    Yota X
    NW New Jersey
    1st gen
    Yeah, for sure. I have to drive and see what the temp is on mine. I have a gas bomb in my bed. I already filled it up at gas station and forgot to put the cap on and spilled like 2 gallons in bed. That was scary.
    Kinda wish I powder coated my axle housing now, looking at yours. Spray paint just isn't an option here. sucks.
  16. May 9, 2023 at 8:19 PM
    #1596
    02hilux
    Planet: EARTH
    That suck. I went as far as buying foil wrap for the soft fuel lines at the side of the tank. Anything to help. You can also see how close the upper link and accessories is to the muffler. So far so good.
    Slashaar and Yota X[QUOTED][OP] like this.
  17. May 9, 2023 at 8:29 PM
    #1597
    Yota X
    NW New Jersey
    1st gen
    Yep, always a struggle to fit things in these builds. DEI makes some really cool sleeves. Prob gonna get some for my brake and trans lines by exhaust too.
    02hilux[QUOTED] likes this.
  18. May 9, 2023 at 8:30 PM
    #1598
    02hilux
    Planet: EARTH
    DEI sleeve aren't cheap and I'm cheap so these will do :rofl:
  19. May 9, 2023 at 8:33 PM
    #1599
    Yota X
    NW New Jersey
    1st gen
    Haha. Says the guy who built that truck...:rofl::rofl::rofl::rofl::rofl:
  20. May 10, 2023 at 5:48 AM
    #1600
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I think it would be interesting to do a side exit that was a part of sliders. Though you may not want to step on it barefoot.
