Uh, melted intake box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TropTaco913, Aug 23, 2012.
  1. Aug 23, 2012 at 5:53 PM
    #41
    TropTaco913
    TropTaco913 [OP] Active Member
    Will
    Virginia
    2020 TRD OR 4x4
    It hasn't overheated since I bought it, the radiator is full, and the overflow looks fine. I've checked everywhere, there's no other signs of heat.
  2. Aug 23, 2012 at 5:54 PM
    #42
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    The brown line on the box is a crack, right above the melting.
  3. Aug 23, 2012 at 5:57 PM
    #43
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    By any chance have you used anything to clean the engine bay? Or had it cleaned by someone? Ive seen a type of tire gloss that combined with heat can do crazy shit to plastics.
    Just another thought
  4. Aug 23, 2012 at 5:57 PM
    #44
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Take it to the DC's on the boat and have them check it out. Have em fab you up a new shiny aluminum one haha!
    Could there maybe be exhaust gases coming out through the throttle body and hanging out in the top of the box (because heat rises) and melting it....this could be caused by an intake valve not seating all the way..... don't think that would get hot enough to melt it tho. So forget everything you just read.
    Buckshot approach!
  5. Aug 23, 2012 at 5:59 PM
    #45
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    I don't use tire polish because it just sounds silly to me, and I haven't cleaned the bay or had anyone do it. I took it to the dealership at 5k miles to have my oil changed, but that's it.
  6. Aug 23, 2012 at 6:03 PM
    #46
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    I actually work with the DC's, haha
  7. Aug 23, 2012 at 6:10 PM
    #47
    Blkvulcan
    Blkvulcan Well-Known Member
    Paul
    Augusta, GA
    12 Prerunner SR5
    Maybe the dealer used something on it. Maybe sprayed some Purple Power and didn't rinse?
  8. Aug 23, 2012 at 6:42 PM
    #48
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    That might be it, but with hurricane Isaac being such an asshole I won't be able to take it to the dealer for a while.
  9. Aug 23, 2012 at 6:43 PM
    #49
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Hot air intake? Your doing it wrong...
  10. Aug 23, 2012 at 6:45 PM
    #50
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    :eek:
  11. Aug 23, 2012 at 6:47 PM
    #51
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    2011
  12. Aug 24, 2012 at 7:03 AM
    #52
    shemp
    shemp Well-Known Member
    I'm looking very closely at this picture:
    What I see in it is that the melting damage is strictly to the lid of the box, not at all to the lower part of the box. There is a very clean line between the bottom and the top.
    I very strongly doubt that this happened on the truck. I think the lid was removed and burned deliberately, or someone stole your good lid and replaced with a burned one. I believe that if it got hot enough under the hood to do that, there would be obvious damage to the paint on the hood itself.
    Do you ever leave the vehicle unlocked when you park it? (Weird stuff happens in key west, I know, I have a place down there.)
    When was the last time you looked under the hood? Before or after you had the dealer change the oil?
  13. Aug 24, 2012 at 7:09 AM
    #53
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    That may not be from heat, that looks more like chemical contact/inter-action, were you recently using some sort of Cleaner, solvent?
    the photo shows the body of the enclosure with no deformation, if it was heat the proximity of the whole box would have shown the result of radiant heat soak, this is why I'm leaning towards chemical
  14. Aug 24, 2012 at 7:18 AM
    #54
    shemp
    If it was chemical, would that chemical not have also affected the bottom of the box? This is why I think that it happened off the truck.
    Another thing is that the dust suggests that it didn't happen recently.
  15. Aug 24, 2012 at 7:37 AM
    #55
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    Do you have a shop perform your maintence? If so they may have went to check your filter and removed the lid and placed it someware near your engine. or any hot surface
  16. Aug 24, 2012 at 9:12 AM
    #56
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Exactly what I was thinking back on the first page. It looks to me like this damage happened when the lid was off and sitting off to the side near something very hot. Otherwise there would be heat damage to things surrounding it, including the lower part of the box. Someone did this and didn't fess up to it.
  17. Aug 24, 2012 at 9:27 AM
    #57
    SoCaltaco65
    Not really, on initial contact its possible a covalent scenario took place and neutralized that reaction, whats more alarming is the corner is missing, almost like someone else had a fire or instance and pop'd the hood and swapped it for the good one.
  18. Aug 24, 2012 at 9:38 AM
    #58
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Looks like the dealership removed the lid to check the filter, set it precariously on top of the engine, and then accidentally bumped it and it dropped behind/beside the engine and wedged on/next to the exhaust system. Notice that only the side/corner of the lid is melted?
    Did you notice any plastic smell immedietely after having your oil changed? Look for a black sticky mark on your exhaust.
  19. Aug 24, 2012 at 9:39 AM
    #59
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or... guy who did oil change before put his 400W light on the box and it made it melt.
  20. Aug 24, 2012 at 9:46 AM
    #60
    TropTaco913
    Will
    Virginia
    2020 TRD OR 4x4
    I haven't cleaned my engine since I bought it, and the only maintenance that's been done since I've had the truck was the first oil change at 5k miles. I bought the truck basically new, it was a dealer demo vehicle. And like I said, there's no other heat damage anywhere.
