Uh oh...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy Yoda, Feb 5, 2013.
  1. Feb 5, 2013 at 2:20 PM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    Was under the truck about to install my carrier bearing drop because I had been feeling some really bad vibes lately and saw this...ImageUploadedByTapatalk1360102824.973274.jpg
  2. Feb 5, 2013 at 2:21 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Well that's your vibe problem, not the carrier bearing.
  3. Feb 5, 2013 at 2:21 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    well, that would explain the vibes haha
  4. Feb 5, 2013 at 2:21 PM
    Large
    Large Red
    1 Piece drive shaft time ?
  5. Feb 5, 2013 at 2:23 PM
    Toy Yoda
    Garrett
    06 DCLB
    Perhaps, it's happened before. Faulty u joints was the cause last time so we'll see
  6. Feb 5, 2013 at 2:26 PM
    Toy Yoda
    Garrett
    06 DCLB
    I'm just happy I didn't drop my drive shaft on the interstate on the way home today and hurt anybody
  7. Feb 5, 2013 at 2:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That's not good. This is good.
  8. Feb 5, 2013 at 2:34 PM
    Toy Yoda
    Garrett
    06 DCLB
    Thank you I needed that
  9. Feb 5, 2013 at 3:15 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Good catch. Didn't get stranded, nobody got hurt! I've never seen one fail like.
  10. Feb 5, 2013 at 3:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No worries, you would have had to tear the u-joints apart to replace the carrier bearing anyways. If it were me, I'd have planned on replacing the u-joints anyways if I'm going to go through the trouble of tearing them apart. Good thing you found it now and not when it left you stranded.
  11. Feb 5, 2013 at 4:35 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    This is VERY good!!
  12. Feb 5, 2013 at 6:28 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    On a positive note, it was the cheap, replaceable yoke that got destroyed. Thats about as close as you can get without things getting REALLY bad.
  13. Feb 5, 2013 at 7:19 PM
    Toy Yoda
    Garrett
    06 DCLB
    yeah im just glad i noticed it when i did, the carrier bearing is bad too so i'll just replace it all, get rid of the vibes and the squeaks
  14. Feb 5, 2013 at 11:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pole vaulting, yota style. Glad you caught it.
  15. Feb 5, 2013 at 11:49 PM
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
  16. Feb 6, 2013 at 7:03 AM
    Toy Yoda
    Garrett
    06 DCLB
    trucks in the shop today, i'll keep yall updated for the cost of damage report
  17. Feb 6, 2013 at 7:43 AM
    Toy Yoda
    Garrett
    06 DCLB
    Turns out the entire driveshaft has to be replaced because of all the vibes, trying to convince dad to let me get a one piece, to replace the stock one is about 900, I think a custom will be cheaper
  18. Feb 6, 2013 at 7:53 AM
    Pugga
    Massachusetts
    Check local salvage yards. You could pick up the entire drive line, flange to flange a lot cheaper than $900.
    Also, were you given a reason why it needed to be replaced or is the shop just being lazy? U-joints and a carrier bearing are cheap and I can't see that yolk being overly expensive either. I'm not seeing a reason why you'd have to replace everything just because of the damage you pictured in the OP. I'd get the truck to a shop that specializes in drive line type work and let them take a look at it.
  19. Feb 6, 2013 at 8:18 AM
    Toy Yoda
    Garrett
    06 DCLB
    Well I trust this shop my family has been dealing with them for over ten years, but I think the carrier bearing was coming into direct contact with the driveshaft, and that's what was making the metal on metal grind when I accelerated, the u joints were broken in addition to it
  20. Feb 6, 2013 at 8:34 AM
    Pugga
    Massachusetts
    I just wanted to make sure you had a good reason to replace everything. A lot of shops will push people to replace everything rather than rebuild the u-joints and replace the carrier bearing (and sometimes paying shop labor to replace the whole thing can be less also). Check salvage yards, a local member got a complete used drive line in the low 200's when he bent his.
