Uhaul 12x6 road trip tire psi
Discussion in 'Towing' started by cementnotgray, Mar 21, 2021.
  1. Mar 21, 2021 at 7:54 PM
    cementnotgray
    cementnotgray [OP] Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    First time hauler here. I’m pulling a 12x6 Uhaul halfway across the country so I’m trying to get this right. Can’t seem to find a straight forward answer. What’s the proper psi for E load tires when pulling 3-4k pounds? Also, do you inflate all 4 tires to that pressure or just the rears? I run 255/85/r16 ST Maxx’s FWIW
  2. Mar 21, 2021 at 7:57 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    cementnotgray[OP] likes this.
  3. Mar 21, 2021 at 8:14 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
  4. Mar 21, 2021 at 8:20 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Sure it is.
    First page of the LT tires.
  5. Mar 21, 2021 at 8:23 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If they are “trailer” tires ( which they should be) they should be inflated to the max pressure as shown on the tire. Trailer tires are designed to run at max pressure. Under inflating trailer tires causes them to over heat and can lead to catastrophic tire failure. If they aren’t trailer tires then ask the people at UHaul for the proper inflation.
    Oops, just realized your are asking about your truck tires.
  6. Mar 21, 2021 at 8:35 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    My bad, I stopped scrolling when I hit the European section. Got my answer thank you
