Ujoint vibration resolved....and then
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoCats, Aug 2, 2016.
  1. Aug 2, 2016 at 9:43 PM
    TacoCats
    TacoCats [OP] Active Member
    07 Tacoma Off Road
    solved my 20 mile an hour bad vibration problem and indeed it was a bad u joint at the diff.It was a mother to take off considering it being seized up in two bearing caps.Took it for a drive and now a new vibration...but this time at 40mph,not as bad with the bad u joint previously,unbalanced tires perhaps?Discount tire says they balanced them but I'm skeptical if they even lug balanced them or not.....`everything is secure on the drive shaft BTW,re checked it after I drove it.
  2. Aug 2, 2016 at 9:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    center bearing...
  3. Aug 2, 2016 at 11:09 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did you mark the parts of the driveshaft prior to disassembly to be able to reassemble the same and maintain the balance of the driveline?
  4. Aug 3, 2016 at 4:19 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    like landphil says did you mark the drive shaft? if not rotate it 180 degrees....................
  5. Aug 3, 2016 at 7:39 AM
    TacoCats
    07 Tacoma Off Road
    No, I did not mark it,The only reference I used was on the white label on the shaft, which was facing downward
  6. Aug 3, 2016 at 8:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if he replaced the u joint at the diff it doesnt matter.... the only thing that could be flipped 180 would be the lil yoke piece, and that isnt going to cause unbalancing. Now if you did the center u joint and flipped a driveshaft half 180 then yes you will unbalance everything.
  7. Aug 3, 2016 at 8:28 AM
    TacoCats
    07 Tacoma Off Road
    BTW, the Ujoint it was a tad snug when I put it back on,i'm probably going to have to re-adjusted somehow that might contribute to the vibrations in contrast with the center bearing being another issue
