Ultimate 3rd Gen Dual Battery setup?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MisterKitchen, Jun 19, 2022.
  1. Jun 19, 2022 at 7:19 AM
    MisterKitchen
    MisterKitchen [OP] Well-Known Member
    FABIAN
    2018 CONCRETE TACOMA TRD OFF ROAD
    Too many
    It has been a long and tiresome process. I am glad to finally be just about done with this endeavor. Figured it would be worthwhile to share if anyone is in the same boat as I.
    It started with a dometic CFX45 and voltage drops. One thing led to another.
    I'm running dual Northstar AGM batteries. Starter is a 31, Aux is a 34. Larger start battery since I never intended on rolling into dual batteries. I figured the 31 would hold me over.
    I did upgrade to an SDHQ/DC Power high output alternator. She can push 270 amps. On top of that, voltage output was raised to 14.6-14.7 using vF Tuner. This is to accommodate the AGMs.
    Both batteries are tied together/ managed by a Redarc BCDC1225D. I picked up an Off Grid Engineering ultimate dual battery kit. It included everything you'd need for a simple dual setup. The BCDC is an awesome piece of kit. It maintains your AUX battery and has an MPPT function for solar. I'll get into that soon.
    In addition to the BCDC, I opted to install an RK1260 Relay to the system. This allows me to cut input voltage to the BCDC when the truck ignition is turned off. This is important because of battery drain issues when attempting to use battery chargers (AC to DC). The BCDC senses an input, turns on and automatically wants to send all power to the AUX battery. Draining the start.
    On the topic of battery charger, I opted for a NOCO Gen 5x2. A dual lead, 5 amp per lead smart charger. Each battery gets its own lead and I can independently control what each battery is getting. I stood around for 35 minutes trying to figure out where to mount it. Ended up drilling and tapping the OGE battery tie down 1/4x20 and bolting it down. Actually worked out perfect. Ran one of NOCOs AC port/extensions from the bumper to the charger for a nice clean look.
    Moving on to solar. I chose a Renogy 100 watt panel. Mounted to the roof rack. Simple enough. Ran 10 awg to the BCDC. All connections made with Anderson Powerpole connectors. Love these things. Mounted 3 to the rack. One is panel 1 input. Panel 2 input (portable panel for extra wattage if need be) and power out. Next to that is a blue sea systems 25 amp circuit breaker. Aside from safety, it is used as a shut off when I do not want solar input. If I have the noco plugged in and it senses any other input, it will shut off. No Bueno. To combat that. Simply walk by and push the little button. Cuts power. Good to go.
    The rest is fairly straightforward. Just some blue sea breakers, panels and fuse blocks. The next step is to install an SBI12 and a changeover Relay so that the excess solar will charge the start battery as well.
    The main purpose behind all of this tomfoolery is to ensure that batteries stay topped off in extended periods where the truck won't be started. Definitely makes the camping trips easier. Is it all worth it from a price perspective? I'll find out. Sure does look cool though. That's all that matters, right?
  2. Jun 19, 2022 at 8:13 AM
    kherron
    kherron Well-Known Member
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
    Nice setup. This is the direction I’m headed as well. I’ve been running the OGE / Redarc dual setup for a couple years but next up is a 27F AGM starter with a tune to keep it topped up and then some flexible solar panels to the Redarc. Not gonna worry about shore power or an upgraded alternator.
    MisterKitchen[OP] likes this.
  3. Jun 19, 2022 at 8:28 AM
    MisterKitchen
    FABIAN
    Too many
    Best part is, you can customize everything to suit your needs. How does the solar keep up with draw on the battery?
  4. Jun 19, 2022 at 8:43 AM
    kherron
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
    I’ll tell you once I’ve got it hooked up :p
    The only thing drawing on my battery at camp is a Dometic fridge. Hoping 2 panels can keep that going either indefinitely or at least an easy 3-4 days.
  5. Jun 19, 2022 at 8:49 AM
    MisterKitchen
    FABIAN
    Too many
    That's what I'm going for as well. It doesn't pull a ton of power.
  6. Feb 8, 2024 at 5:38 PM
    Dorf on Tacos
    Dorf on Tacos Member
    J
    Las Vegas
    2019 TRD Sport
    Throttle controller, air horn, I know, im just getting started
    Wow, amazing write up.
    I'll be honest, i understood about 45% of it. All the acronyms are new to me, but im gonna use this thread as my central hub for startn research.
    I was gonna just get an isolator, but im hella interested in a custom setup now. Especially with the solar panels.
    Thnks for the input!
    lamjam and MisterKitchen[OP] like this.
  7. Nov 8, 2024 at 1:05 PM
    RiverMando
    RiverMando Well-Known Member
    2019 TRD OR DCLB
    Thanks for putting this together!
  8. Nov 8, 2024 at 9:45 PM
    MisterKitchen
    FABIAN
    Too many
    I’ll be reinstalling it all soon. Accident. Pulled everything. But I have the truck back now after 5 months… I’ll probably do a better more detailed write up.
    wradar and CenCal805 like this.
  9. Nov 9, 2024 at 3:54 AM
    RiverMando
    2019 TRD OR DCLB
    Oh damn. I’ll keep on the look out for it
  10. May 28, 2025 at 9:42 AM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    Beautiful setup. Do you have a parts list complete with prices? That would be super helpful! Would like to emulate this build.
