Ultimate Camping Thread
Discussion in 'Outdoors' started by davestaco, Oct 9, 2010.
  1. Mar 10, 2014 at 9:14 PM
    #4901
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Yep I know rail dust, my truck is covered in it:eek:, luckily on darker colors you can't see it. It could be the manufacturing process, but it can also come from residue form other guns. I work in a fab shop and we have to be extremely careful not to use any abrasive that has touched anything other then the same grade SS. A lot of people use steel wool not knowing it will contaminate the SS. scotch brite works very well, you can get it in differing grades similar to sand paper grit.
  2. Mar 15, 2014 at 2:22 PM
    #4902
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Hey guys, I need your opinion here. I have a small tent trailer, only 1350 lbs dry weight. I installed a wheel swivel on the front and without considering it may weaken the frame I drilled a hold in it so I could install it. Im not going to use the wheel now and the hole is showing. Heres a picture, do you think I should make a doubler plate or piece of channel to go over it and fasten it to it or something to make sure its not a weak point?
    I know it was stupid but I didnt think before i did it
  3. Mar 15, 2014 at 3:09 PM
    #4903
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    What size hole is that? Probably not. But, I would cut a piece of metal and bolt it or weld it the inside of the of the rail. Of corse, prime and paint it afterwards.
  4. Mar 15, 2014 at 3:12 PM
    #4904
    nagorb
    Alabama
    2001 dbl cab 4x4
    You should be fine, but you can always weeks a plate on it.
  5. Mar 15, 2014 at 3:15 PM
    #4905
    maxpower29
    Jordan
    Nova Scotia, Canada
    less then an inch, I would say no more then 3/4". Im probably just going to bend a piece of U channel to fit over it, about 6 inches long and either weld it to it or rivet it. Just to be sure. Thanks guys!
  6. Mar 15, 2014 at 8:57 PM
    #4906
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Anyone have a good recommendation for a waterproof pouch for gallaxy s3 for kayakin?
    The aquapac looks to small, saw the otter box vault that look nice but cant see screen.
  7. Mar 15, 2014 at 9:21 PM
    #4907
    MTgirl
    Weesa
    Bob's secret mod lair
  8. Mar 15, 2014 at 9:47 PM
    #4908
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
  9. Mar 16, 2014 at 6:56 AM
    #4909
    MTgirl
    Weesa
    No personal experience. I have thought about getting a pouch for my Kindle and those are the ones I keep coming back to.
  10. Mar 16, 2014 at 6:58 AM
    #4910
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    I order the 13 last night will be here wednesday . I will report back
  11. Mar 16, 2014 at 7:08 AM
    #4911
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    I use the iPhone version of that SealLine case all the time.
  12. Mar 18, 2014 at 7:31 PM
    #4912
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    I did a little bit of hiking today. A little bit windy:
  13. Mar 18, 2014 at 9:12 PM
    #4913
    hockeyovs
    hockeyovs Member
    Trevor
    Calgary, Alberta
    11 4x4 Sport
    hey all, my wife and i are looking at doing a backpacking trip in the middle of May. probably near las vegas or pheonix as they are easy to fly to from calgary. I was just wondering if anyone has an idea of something easily reached without a vehicle that is 3 or 4 days long. any ideas would be awesome. we are pretty experienced hikers so the more challenging the better.
  14. Mar 18, 2014 at 9:26 PM
    #4914
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    This trail that I been on is 79 miles long. It's north of Phoenix.
  15. Mar 18, 2014 at 10:08 PM
    #4915
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    May is approaching hot in that part of the country.
    Vegas will get you to Zion/Bryce with a bus trip. Valley of Fire is very close to LAS but again, probably going to be hot.
    No ideas on PHX.
  16. Mar 19, 2014 at 12:34 PM
    #4916
    hockeyovs
    hockeyovs Member
    Trevor
    Calgary, Alberta
    11 4x4 Sport
    hot might not be too bad. been dealing with cold for the last 7 months. any one know of a good place for that time of year. the good trails up here are all snowbound till at least june.
  17. Mar 19, 2014 at 12:41 PM
    #4917
    MTgirl
    Weesa
    Maybe you would get more response posting in the local BS threads for those two areas.
  18. Mar 19, 2014 at 12:44 PM
    #4918
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    It's in the 90's to about 100 in May here in Phoenix. I'm sure it's the same for Vegas. I would not advise coming to Phoenix in May through September to backpack.
    If you are wanting to hike in the early morning, Echo Canyon at Camelback is awesome. Best to go in the early morning around sunrise though.
    We do have plenty of places in Northern Arizona that is a bit cooler in the Summer months.
  19. Mar 19, 2014 at 2:07 PM
    #4919
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Yesterday I went to the Columbia Sportswear outlet and scored a mid-weight fleece for $18 :woot: also may or may not have flirted with the girl helping me and got a discount code for 50% off (employee friends and family code) on the Mountain Hardware site. :D
  20. Mar 19, 2014 at 6:36 PM
    #4920
    hockeyovs
    hockeyovs Member
    Trevor
    Calgary, Alberta
    11 4x4 Sport
    yeah thanks. i think i got the info i needed. ive decided that we are going splitboarding instead. thanks for the input people
