Ultimate Fix For Squeaky Clutch Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greatfuldead, Aug 30, 2015.
  1. Jan 4, 2016 at 10:38 AM
    #41
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
  2. Jan 4, 2016 at 10:53 AM
    #42
    tcam27
    tcam27 Well-Known Member
    TIm
    CT
    13 silver DCSB 6spd with a bunch a sick bikes
    16 limited wheels and tires TRD Short throw shifter
  3. Jan 4, 2016 at 2:52 PM
    #43
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Had mine for 3 yrs now, squeaked twice in that time. Both were when it was summer, hot out and truck sat all day while at work. All I did was reach under and turn the clutch adjustment rod a quarter turn and no more squeak.
  4. Jan 4, 2016 at 3:04 PM
    #44
    tcam27
    TIm
    CT
    Hey Jon
    when u greased it did u pull the bolt all the out or only partially? Or at all
  5. Jan 5, 2016 at 4:49 AM
    #45
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    I just lay on my back, on the floor board, using the ermatex ultra-disc-brake-caliper-lube in a plastic syringe (you can get them at pet stores) https://www.createforless.com/p-images/3/2009/0723/161720-3-1.jpg
    ...and then just push the gel like lube into the pivot points on the pedal assembly as shown in this TSB http://www.toyotapart.com/TSB-0186-12-Clutch-Pedal-Squeak-Noise.pdf ... I only do #1, #4, #5, then pump the pedal a few times to make sure is covers the area well. Works great
  6. Jan 5, 2016 at 12:38 PM
    #46
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    AH HA! That thing is called a clevis! Odd because I always thought a clevis was something like this:
  7. Mar 4, 2016 at 9:18 PM
    #47
    ManualTaco
    ManualTaco Well-Known Member
    2021 Magnetic Gray Doublecab Shorty TRD-OR
    I set some radio stations. That's about it so far.
  8. Apr 1, 2016 at 9:02 PM
    #48
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    I just did this little trick and it seems to have worked... at least for now![/QUOTE]
    nice, going to try mine today, I'll report back if it helps by rotating this threaded shaft.....next step, white grease or that syringe trick.....driving me nutzz in traffic
    ManualTaco[QUOTED] likes this.
  9. Apr 3, 2016 at 3:27 PM
    #49
    ManualTaco
    Still fine for about a month now.
  10. Apr 3, 2016 at 3:46 PM
    #50
    Pigpen
    Dan
    Northwest Montana
    Mine hasn't made a noise since I greased it (and posted) in August. The weather is starting to warm up. I imagine I'll have to grease it again this summer, but I'm interested to see when.
  11. Apr 6, 2016 at 8:37 PM
    #51
    little squirt
    808 ALLDAY!!
    rotating the threaded rod back and forth seemed to has worked. been driving for 2 days and no noise yet. I'm sure it will return but that seemed to be neat quick trick that helped.
  12. Apr 7, 2016 at 1:05 AM
    #52
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I did this. Hasn't made a peep in years.
  13. Jun 29, 2016 at 2:39 PM
    #53
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Here i felt special because the service manager was looking at me like i had 2 heads. My 16 was in for 10k service today and first nobody could duplicate sound, then i showed the "master tech" and he went on to tell me every one does that. Except he then went on to tell me mine was the first mt 16 he drove. Then he said i must be a "heavy clutcher" whatever that means. 5th mt vehicle, none have ever sounded like a 500k mile dump truck other than my rx8 pedal just before it bent the pedal around sideways. guess ill give em 1 more shot before doing it myself.
  14. Jun 29, 2016 at 2:40 PM
    #54
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    @SlipperyTaco what was the name of that lubricant you let me use on my clutch pedal a few weeks back? Stuff worked like a charm, my clutch was terribly creaky before I used that stuff, been silent ever since.
  15. Jun 29, 2016 at 2:44 PM
    #55
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
  16. Jun 29, 2016 at 2:45 PM
    #56
    eon_blue
    Azusa, CA
  17. Jun 29, 2016 at 2:55 PM
    #57
    Taco Pete626
    Peter
    Southern California
    So even the 16's still make noise. I guess Toyota didn't do much to change the design.
  18. Jun 29, 2016 at 2:58 PM
    #58
    Taco Pete626
    Peter
    Southern California
  19. Jun 29, 2016 at 2:59 PM
    #59
    SlipperyTaco
    Chandler, AZ
  20. Aug 4, 2016 at 4:57 AM
    #60
    TALLNDIRTY
    TALLNDIRTY Active Member
    Winnipeg Manitoba
    2015 Tacoma Access cab SR5 4cyl 5spd 4x4
    My truck is at the 14500km mark....and my clutch has just started to creak. After going through various threads on the topic I was hoping mine wasn't going to develop the issue.....but there is comfort in community and Warranty!
