Ultimate Fix For Squeaky Clutch Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greatfuldead, Aug 30, 2015.
  1. Aug 4, 2016 at 5:24 AM
    #61
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    I just lay on my back, on the floor board, using the ermatex ultra-disc-brake-caliper-lube in a plastic syringe (you can get them at pet stores) https://www.createforless.com/p-images/3/2009/0723/161720-3-1.jpg
    ...and then just push the gel like lube into the pivot points on the pedal assembly as shown in this TSB http://www.toyotapart.com/TSB-0186-12-Clutch-Pedal-Squeak-Noise.pdf ... I only do #1, #4, #5, then pump the pedal a few times to make sure is covers the area well. Works great
  2. Mar 22, 2017 at 9:45 PM
    #62
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    Has anyone had the TSB done since 2014 (when it seems to have been revised from the original 2012 release) with any success?
    Recently the dealer said that I was eligible for the TSB, only to then say I was out of warranty (currently at 3yrs 8 months and 55000km) so they want to charge me 50% of the rate ($1000 CAD, so $500 charge to me) to do the TSB.
    I am arguing it back saying at less than 3 years, and only 35000km I complained and they put grease on the parts that solved the problem and that they should have done the TSB then. I also have the extended warranty that covers the clutch master cylinder (which they plan to replace as part of the TSB). I'm not optimistic they will relent, and thus I'm trying to decide if it is worth proceeding.
    $500 is shocking, but at least its 1/2 the regular price. The clutch isn't creaking too much ATM so I'm probably going to put it off and just keep greasing it if the noise returns.
    A friend had the TSB done last year, but the sound returned and was also solved by grease application. So, seems that the TSB for free might not be the worst idea, but to pay $500 seems foolish.
    Thoughts?
    scottalot likes this.
  3. Mar 22, 2017 at 11:59 PM
    #63
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Seems foolish. In my research, a lot of posters said that the tsb only fixed the problem temporarily.
    I think reapplying grease as the problem reappears is the only "fix"
    scottalot and gearcruncher like this.
  4. Mar 23, 2017 at 2:49 AM
    #64
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I had the TSB completed and the squeak came back. Never-Seize on the pedal to rod pivot made it go away. Just put a gob on a small acid brush and shove it up between the parts.
  5. Mar 23, 2017 at 6:24 PM
    #65
    moto73
    moto73 Well-Known Member
    I can confirm I had the TSB done on my 2016 after 5k miles and it's back at 11k.
  6. Mar 23, 2017 at 11:07 PM
    #66
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    TSB = Technical Service Bulletin
  7. Mar 30, 2017 at 8:35 PM
    #67
    TacoTrooper
    James
    Vancouver, Canada
    I may be some what foolish, but ended up getting the TSB done. They came down to 75% off. Clutch pedal feels much tighter now than before, so I guess it maybe needed an adjustment previously. But, new parts and hoping no issues.
  8. Mar 31, 2017 at 5:25 AM
    #68
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    It will come back. I had the TSB clutch pedal done & i got about 2 years before the noises came back.
  9. Mar 31, 2017 at 6:08 PM
    #69
    TacoTrooper
    James
    Vancouver, Canada
    ya, I'm prepared for that. I was really on the fence. If it comes back I'll update.
  10. Apr 1, 2017 at 12:44 PM
    #70
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    It baffles me how they issue TSBs that don't fix the problem.
    I've hit a couple key spots with white lithium grease (spray) and haven't heard the creak in years.
  11. Apr 1, 2017 at 1:19 PM
    #71
    charles08tacoma
    Santa Cruz, CA
    I use the white lithium grease every time the creaking starts back up.
  12. Aug 3, 2018 at 2:15 PM
    #72
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Mine sounds like it's coming from inside the engine bay right behind the clutch pedal. Any thoughts?
  13. Aug 4, 2018 at 8:20 AM
    #73
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Everyone kept saying TSB, TSB, but I had a squeaky pedal that was annoying the shit out of me. When it came time to upgrade my clutch, I cleaned off the shift fork and everything near it...the existing grease was dried up, and there were some spots that had no grease left on it at all. After cleaning, I used Mobil1 bearing grease, and have not had any pedal squeak in 7k mi so far. I didn't touch the pedal assembly at all. I saw a thread where you use a plastic straw up through the fork boot in the bottom of the trans to put grease on the ball/arm. Without dropping the trans that's prob the best way. If I find it, I'll edit my post.
    BlakeM likes this.
  14. Jan 25, 2019 at 4:50 PM
    #74
    MBCoast
    MBCoast Member
    CA
    07 TRD 4X4 Snugtop
    3 inch front 2 rear
    I have a 2007 v6 6 spd. Bought it brand new and the clutch started being noisy at about 15 to 20K miles. Took it in and they replaced the pedal under warranty. I now have 91K and just keep using a combo of spray grease and silicone spray aimed at the spring with a smear of bearing grease on where the master cylinder rod meets the pedal. Seems to work for about a few months. Toyota knows about this shit and really should do something about it. This is bullshit.
    openroad and Norton like this.
  15. Jan 25, 2019 at 5:46 PM
    #75
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I spray my pedal pivot about once a year with Dupont Snow and Ice Non-stick Clear Coating. It is made for snow blower chutes and shovels. That keeps it quiet for months at a time and I have 60k miles on it now. I have tried other spray lubes since 2013 and nothing has outlasted this stuff. My pedal really gets a workout with our traffic. It will usually start to squeak when it first gets hot in the early summer. I spray it and it's quiet for the rest of the year.
    Norton likes this.
  16. Jul 21, 2020 at 6:58 PM
    #76
    RSchanz
    RSchanz New Member
    It looks like my assembly for the '16 is slightly different than yours. Has anyone had this issue with a 3rd Gen Tacoma? What areas did you libricate?
  17. Jul 21, 2020 at 9:07 PM
    #77
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
  18. Jul 22, 2020 at 7:02 AM
    #78
    RSchanz
    RSchanz New Member
    I'm almost positive all if not the majority of the squeaking is coming from the slave cylinder though
  19. Dec 20, 2024 at 6:28 PM
    #79
    Thrillo
    Thrillo New Member
    Hey guys, I rarely post here but I feel the need to get the word out, as I literally hate the squeak and have been fighting it for years via the lube method. That method no longer works for me now. I, so far, have fixed this dang issue today by twisting the metal plunger thingy right below the clutch pedal so that it's back in its proper position. As you twist it with a wrench or pliers or hand or whatever, it'll get really stiff, but keep going and it will feel like it pops into place and stops being loose. The clutch feels brand new now, no slop, no squeal, no rattling noises, very smooth. Credit is where credit is due: https://www.customtacos.com/threads/squeaky-clutch-still-a-problem.97704/
    The best thing is that this method is free, if you have a simple tool. I used a small adjustable wrench and latched on to the nut-like part right beneath the big plunger part to turn it.
    Waasheem likes this.
