Ultimate install howto
Discussion in 'Toytec Lifts' started by SCFirefighter, Jun 27, 2010.
  1. Jun 27, 2010 at 6:15 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I'm preparing to install this kit, or at least most of it, myself. I have a few questions before starting this endeavor. Starting with the following picture:
    I have 8, approx 4.25", rings that I don't know what to do with.
    Also, the two metal plates with the bolts on the far right of this picture: what are they for?
    I didn't get the entire kit. I don't have longer u-bolts or a new center pin.
    I also don't have many of the smaller parts, screws and washers as shown in this picture.
    The coils did not come pre-assembled, so that's par for the course. A question on that: It looks to me that the ring used to adjust your shock settings bears the full weight of the compressed springs when installed. Sure, there is something between that ring and the actual spring, but it still rests on that little $0.01 piece of aluminum used to set your shocks. There is one piece I have not been able to piece together yet: the aluminum cylinder with the adjustable ring on threads. It's pictured in the assembled coils but I'm unsure how to assemble it correctly.
    What am I missing?
  2. Jun 27, 2010 at 6:30 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    Hmm... the "two metal plates with the bolts on the far right of this picture" is the hardware to relocate the sway bar. *I think*
    If you haven't already done so, try going to the toytec site here and just match pictures.
    Hopefully someone with more experience can be of some better help.
  3. Jun 27, 2010 at 6:45 PM
    SCFirefighter
    Stephan
    Cary, NC
    Jup, you're right. That's to relocate the sway bar. I did just that: match pictures lol. I do have the diff. drop kits (front and rear) too, and know what's what.
    Question about the coil assembly still stands. I'll keep looking.
  4. Jun 27, 2010 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 8 rings are known as "Flat bearings", or "Pancake bearing" they go on top and on the bottom of each spring. 2 on the tops, 2 on the bottoms. Makes it more easy to adjust the CO's. Also, smear some grease on them before install.
  5. Jun 27, 2010 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, the names for those washers was given to me by an old hot rodder friend of mine. What the actual names are Im not sure.
  6. Jun 27, 2010 at 6:54 PM
    SCFirefighter
    Stephan
    Cary, NC
    I think I got it. The piece I was wondering about is the base plate for the spring that comes packaged with the 5100. It's for use with the stock spring only; see image:
    The base that comes with the new coils is what confused me:
    -- which brings up another question:
    I was under the impression that the height could not be adjusted without taking the assembly apart and moving the shock indicator to 0.85 or 2.5 or whatever setting you wanted. With this new spring base, however, and the spanner wrenches, it appears you can adjust the lift without taking everything apart?????
    If so, what should I set the shock height marker at? 0, 0.85, 1.75 or 2.5?
  7. Jun 27, 2010 at 6:55 PM
    SCFirefighter
    Stephan
    Cary, NC
    Awesome. Thanks. Yeah, I'll get some lithium grease for that.
  8. Jun 27, 2010 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check with Toytec as to what height the collar should be set to.
  9. Jun 27, 2010 at 7:02 PM
    SCFirefighter
    Stephan
    Cary, NC
    I will, to be sure. However, playing with the parts here in my living room I was able to reproduce the exact look of the above pictured coils by keeping the market at 'stock' (0).
  10. Jun 27, 2010 at 7:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, but you wont be able to adjust the springs too much. I think they need to be set at the .85 or 1.75 setting.
  11. Jun 27, 2010 at 7:36 PM
    SCFirefighter
    Stephan
    Cary, NC
    By the way, is there a particular order I need to keep in mind?
    I believe the sway bar relocate should come before the coil install, but what else?
  12. Jun 27, 2010 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It really doesnt matter.
  13. Jun 28, 2010 at 6:46 AM
    SCFirefighter
    Stephan
    Cary, NC
    morning bump. I'm starting on the rear shocks and the AAL :)
    any last minutes hints would will be appreciated.
  14. Jun 28, 2010 at 9:46 AM
    SCFirefighter
    Stephan
    Cary, NC
    Holy hell .. 2.5hrs later the rear drivers side AAL and billstein are done. Oh, and that included a trip to Autozone with my neighbor lol.
    It's 95F!!! Granted, the passenger side will go faster due to the learning curve, but I don't think I'll have enough time to start and finish the coilovers.\
    I know I have to finish the whole axle. I'm taking a union break :)
  15. Jun 28, 2010 at 10:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot:
  16. Jun 28, 2010 at 12:55 PM
    SCFirefighter
    Stephan
    Cary, NC
    DONE with the rear.. holy shit. 101F when I picked the last tool up from my driveway.
    lost 20lb lol. It looks higher. After I cool down and take a shower I'll measure the change for y'all.
    Front suspension maybe on Wednesday; tomorrow is a busy work day for me
