Ultimate LED turn signals
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Apr 15, 2017.
  1. Mar 11, 2019 at 7:58 PM
    #8421
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Thanks! Where would I run the wires to? Also I saw you mentioned that v5’s will be easy to install if you get the puddles installed/future proofed- is that the case for the LE’s too or should I just wait for V5?
  2. Mar 11, 2019 at 8:28 PM
    #8422
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    My LEs are set to turn on with the dash illuminations.
    Off for "Off and DRL" and On for "Dash Lights and Low Beam" on the signal stock.
    I believe if you have Auto headlights, they will also turn on and off depending on if your dash lights are on.
    MESO[OP] and MGMSangTaco like this.
  3. Mar 11, 2019 at 8:36 PM
    #8423
    MGMSangTaco
    Denver, CO
    Hmmm- so they are always off when your DRL’s are on? Did you wire them per his instructions or did you do something different? I have been trying to get myself to use the auto light button more, but I do want to retain the DRL light function.
    I am stalking the puddle light thread now and I am obsessed with yet another meso mod.. wonder if the “future proof” wiring will be applicable to LE’s in addition to v5’s.
  4. Mar 11, 2019 at 8:39 PM
    #8424
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    If you want them on anytime the DRL's are on just run it to the drl circuit. Little extra wire needed but not difficult.
  5. Mar 11, 2019 at 8:41 PM
    #8425
    MGMSangTaco
    Denver, CO
    Sorry if I’m not being clear. I want them to be off when the steering column is set to off, bright when the DRL steering wheel column switch is on DRL, and on but dimmed when the steering wheel column is set to low beams. Is this a pipe dream or possible?
  6. Mar 11, 2019 at 8:46 PM
    #8426
    Rainoffire
    As per the original instructions, the DRLs would turn on the instant the car is on. Then dims with the dash illumination.
    I do not recall the wire colors, but I thInk I connected the red wire to dash lights instead of ignition, then just taped of the white wire.
    This method means you have no DRL "dimming"
    But I'll take that over not being able to turn them off.
    The other way to make it truly like the trucks DRLs, is to run a long line and tap into the headlight DRLs.
  7. Mar 11, 2019 at 8:48 PM
    #8427
    Rainoffire
    Might be possible, if the headlight DRLs have two wires to tap into for full and dimmed.
    Even then, dimmed does not seem all that dim, it is still laser bright.
    I think you can run on dimmed mode only also, just swap the connected wires. Not sure if it works like that though...
    MGMSangTaco[QUOTED] likes this.
  8. Mar 11, 2019 at 10:40 PM
    #8428
    MGMSangTaco
    Denver, CO
    Thanks for your help man. In that case, IDGAF about the dimming feature anymore (unless anyone has another solution), really just want to be able to turn them off when switched to off and then turn them on for DRL/Low beams. Would auto lights help with this?
  9. Mar 12, 2019 at 1:51 AM
    #8429
    Rainoffire
    I do not have auto lights on my truck, but if it is anything like the auto lights on my Corolla, then it would work as if manually switching it.
  10. Mar 12, 2019 at 2:55 AM
    #8430
    ShadyCoh
    ShadyCoh Well-Known Member
    Burnet, Tx
    You can also just add a switch to the red/white wires so you can turn them on and off when you want them on and off.
  11. Mar 13, 2019 at 4:47 PM
    #8431
    skynyrd87
    skynyrd87 Well-Known Member
    2023 TRD Pro Solar Octane AT 2001 TRD OR White MT
    I want some Switchbacks:( any in the works @mesojdm?
  12. Mar 13, 2019 at 5:11 PM
    #8432
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    :cheers::thumbsup:
  13. Mar 13, 2019 at 7:54 PM
    #8433
    Trevbuddy11
    Trevbuddy11 Well-Known Member
    Western Canada
    Trd Sport
    Anyone have a set of ultimate turn signals that they got, but haven’t installed, willing to sell?
  14. Mar 13, 2019 at 7:56 PM
    #8434
    20tacoma17
    2017 DCLB Sport AT
    New ones should be out fairly soon. :D
    Nv2056 likes this.
  15. Mar 13, 2019 at 8:27 PM
    #8435
    Trevbuddy11
    Western Canada
    Trd Sport
    hope able to get some.
    Nv2056 and 20tacoma17 like this.
  16. Mar 13, 2019 at 10:06 PM
    #8436
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I never met able, but I hope he's able to get some too
    HelloMyNameIs likes this.
  17. Mar 13, 2019 at 10:35 PM
    #8437
    Rainoffire
    All these recent LE installs,
    makes me want to buy another set.
  18. Mar 16, 2019 at 7:17 PM
    #8438
    Tman0969
    Tman0969 Well-Known Member
    Eric
    Columbus, GA
    2019 Tacoma OR
    When are these dropping again?
    Nv2056 likes this.
  19. Mar 16, 2019 at 10:08 PM
    #8439
    Nv2056
    Nv2056 Hunt, fish, trap, repeat
    Rural Nevada
    17 DCSB TRD OR
    Icon suspension stage 3 with Toyo MT 255 85 16
    X2
  20. Mar 17, 2019 at 6:01 AM
    #8440
    ShadyCoh
    Burnet, Tx
    when he is finished making them
    FloBass likes this.
