Ultimate LED turn signals
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Apr 15, 2017.
  1. Jan 13, 2021 at 9:06 AM
    #9681
    Tacospike
    Two Trucks
    They will also have DRL function. Similar to the Limited Edition Switchbacks
    They will have a White DRL function for sure, I am not sure if there will be a Amber DRL function also. I think I might have seen that as an option but cannot remember for sure.
    Edit: Not sure if the pic on page 486 was the DRL function or turn use
    Re-Edit: Both options for color
    #9585
    Page 480
    More Edits:
    DRL-->Normal TURN-->Sequential TURN---> Reverse Sequential TURN
    https://vimeo.com/382653489
    These have taken a while, as they are pretty complex. Fitting all the drivers/controllers/etc internally, then making proper optics to make them the brightest and most efficient:)
    There are 2 ways to diffuse light;
    1)Phosphorus Coating(the white stuff you see over halos)
    2)Optics(magnifying glasses)
    There are PROS and CONS of each.
    Phosphorus Coating:
    PRO: Diffuses light more evenly+ cheap to manufacure
    CON: See a big white strip + loose intensity
    Optics:
    PRO: more intensity + More efficient (need less LED's)
    CONS: More expensive to manufacture + you can see the LED's themselves
    I went with optics because for a DRL, you want the intensity and brightness. It might look funny to some (like cracked ice light) but once you are ~5+ft back it looks like a solid beam of light anyway.
    You can see here how it takes all the light and magnifies it forward.
    jaymz25, KUMA26, antlab67 and 8 others like this.
  2. Jan 13, 2021 at 9:51 AM
    #9682
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    The v5 is going to be a thing of beauty for sure!
    Tacospike likes this.
  3. Jan 13, 2021 at 9:54 AM
    #9683
    MSGulfCoastTaco
    MSGulfCoastTaco Well-Known Member
    Mississippi Gulf Coast
    2020 MGM DBSB OFF-ROAD 4x4
    Thanks!!!!!
    Tacospike[QUOTED] likes this.
  4. Jan 13, 2021 at 9:55 AM
    #9684
    Ovrlnd Taco
    Ovrlnd Taco Well-Known Member
    Conrad
    Madison, WI
    2020 Tacoma TRD Offroad
    Stage 4 IVD lift, CBI Bed Bars, CBI Ditch brackets, Rigid DSS Lights, Switch Pros 9100, 255/85/16 MT01
    Thank you for this! Super informative!
  5. Jan 13, 2021 at 1:12 PM
    #9685
    Tacospike
    Two Trucks
    I will add one more thing.
    I know the puddle light harness's for the first initial run did not have the power supply connector for the V5 DRL function. The later runs do.
    I know some people might want these that do not have puddle lights and I am not sure how DRL power will be provided or if there will be an option for non puddle light equipped installs. Might be in this thread somewhere and I missed it, but I've kept an eye out for this and haven't seen it.
    The Limited Editions tapped power from the interior door window / lock switch. I do not know if this option will be available for the V5's. New harness's as an a la carte might be an option?
    Ovrlnd Taco[QUOTED] and daveeasa like this.
  6. Jan 14, 2021 at 12:51 AM
    #9686
    jaymz25
    jaymz25 Well-Known Member
    Edward
    2020 Midnight Black Metallic Tacoma TRD Pro
    please pretty please please take my moneyyyyyyy that thing is so seeexxxyyyyy
  7. Jan 14, 2021 at 1:30 AM
    #9687
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    I hope for the early puddle pods buyers that we can just get that one piece of the harness along with the V5s. Will suck to have to take the whole mirror and door off again (easy enough though), but it would make sense to me to just replace the one section of the harness with the new one that plugs into the V5s too. For non puddle poders, I have no idea.
    Knowing @MESO's customer service, he would probably supply the harness if asked. Although, I'm sure he's thought about all this already.
  8. Jan 14, 2021 at 1:40 AM
    #9688
    jaymz25
    Edward
    What if I don’t have the puddle pods would I still be able to use the drl feauture? And if i plan on installing a puddle pods, are the puddle pods compatible with models that have birds eye view camera? Thanks
  9. Jan 14, 2021 at 1:54 AM
    #9689
    tacobelletx
    TX
    '18 Sport ACLB
    Not completely sure, but I can't imagine Meso would require the puddle pods in order to use the DRL feature. If you plan to get puddle pods though, it would probably make the most sense to install them at the same time.
    Yes, the puddle pods sit in the plastic under the mirror closest to the door while the cameras are on the outer portion (the two plastic pieces aren't connected). I know there are pictures floating around here somewhere...
    EDIT: Found a post with pictures:
    Tacospike and jaymz25[QUOTED] like this.
  10. Jan 14, 2021 at 2:13 AM
    #9690
    jaymz25
    Edward
    Dang it! Anyone selling there puddle pods? I swear the “i’m done with the truck” was so 10 parts ago. Lol
  11. Jan 14, 2021 at 3:33 AM
    #9691
    tacobelletx
    TX
    '18 Sport ACLB
    I see them pop up every now and then from someone who bought them and then decided not to tackle the install (it's really not that bad). Meso did comment somewhere on having a pretty big restock coming soon, not sure if puddle pods are included in that restock though.
    “i’m done with the truck” - I think this is an unobtainable statement....
    jaymz25[QUOTED] and Tacospike like this.
  12. Jan 14, 2021 at 3:52 AM
    #9692
    dleonard1122
    dleonard1122 Well-Known Member
    New Jersey
    2020 Cement SR5 Tacoma DCSB 4x4 2021 RAV4 Hybrid
    Does anyone know if 3rd gen SR5's are already wired to be able to accept the MESO Ultimate LED turn signals?
  13. Jan 14, 2021 at 4:05 AM
    #9693
    tacobelletx
    TX
    '18 Sport ACLB
    Unless they've updated it recently, it doesn't seem like they have the connection needed. You'll also need to purchase a set of mirrors that the turn signals can fit into (or possibly modify yours - not sure on that).
    This post has the wiring for where you'd need to tap into:
    HELP w/upgrading to TRD signal mirrors from SR5 model
  14. Jan 31, 2021 at 4:34 PM
    #9694
    RegulusII
    RegulusII Active Member
    Samuel
    Space Coast, Fl
    2020 Tacoma TRD Sport M/T Premium
    Core/Hurst short shifter, Accumulator delete Prinsu Cabrac/ Cali-Raised Slim LED Light bar Method 702/Nitto ridge grappler 285/70/17 Depo Tail lights Meso total tail stage 1 Meso puddle pods Meso Ultimate Turn Signals Meso Dome and Map lights Morimoto XB LED Headlights "Viper Cut" Front Bumper OV Tuned
  15. Feb 15, 2021 at 2:17 PM
    #9695
    poroto
    poroto Well-Known Member
    Puerto Rico
    @MESO V5 :benchpress: any Update ?
    Glaese likes this.
  16. Feb 15, 2021 at 2:26 PM
    #9696
    travadol
    travadol Well-Known Member
    Travis
    Prairies, Canada
    2020 Cement DCSB OffRoad Premium
    Man, y'all are needy. They'll get here when they get here. Meso has a lot on the go with custom headlights, new LED tail assemblies, V5 turn signals, etc etc.
    fezzy likes this.
  17. Feb 15, 2021 at 2:42 PM
    #9697
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    If memory serves me correctly, hasn't it been over a year? I believe KTJO4x4 set the bar at about a year with her grab handle. LOL
  18. Feb 15, 2021 at 4:06 PM
    #9698
    tacobelletx
    TX
    '18 Sport ACLB
    I'm not sure that's the bar we want to aim for...:rofl:
    doublethebass likes this.
  19. Feb 15, 2021 at 4:17 PM
    #9699
    markgphoto
    Mark
    Middle Tennessee
    I didn't say it was a high bar. Besides, in all seriousness, MESO is much higher class.
  20. Feb 24, 2021 at 8:51 AM
    #9700
    pL4tiNumfi5t
    pL4tiNumfi5t Active Member
    Zona
    2020 TRD Pro (2016 TRD OR, 1998 PreRunner)
    TRD Beadlock-Style Wheels, Goodyear Wrangler Workhorse AT 265/75/16, HPS Silicone Air Intake Tube w/TRD Intake Flow Accelerator, Banks PedalMonster, Lamin-X Amber Fog Light Covers, Plasticolor 4WD Mudflaps, MESO Total Tail Stage 1, MESO V5 Switchback Mirror Turn Signals - Amber, MESO RED TRD/START/STOP Button w/Chrome Delete, MGM Steering Wheel Cover & Shifter Ring, MESO Gasshole V2, VLEDS 5500K Full Interior LED Kit
    Check your inboxes! :thumbsup:
