Ultimate LED turn signals
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Apr 15, 2017.
  1. Sep 20, 2021 at 11:45 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I haven't installed the puddle pods yet, and I have the xrunnerdude conversion harness for my 2020 LED headlights. IShould I buy the plug and play DRL connector? Thanks... @MESO?
  2. Sep 20, 2021 at 11:47 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    it's up to you. But to same $$ I would just tap the 2 wires into your conversion harness.
    RyanDCLB[QUOTED] likes this.
  3. Sep 20, 2021 at 11:57 AM
    boywonder77
    boywonder77 Well-Known Member
    Bay Area
    2018 Tacoma Cement DBSB TRD Sport
    Awesome. Thanks Meso. So if I understand this correctly for those who have Puddle Pods installed, that 2-pin connector will be given to us. HOWEVER, we still need to run the red and white wires per your instructions in order to operate the V5 as a DRL
  4. Sep 20, 2021 at 11:59 AM
    MESO
    State of Jefferson
    Correct. The red+white wires you will just splice into the ~6" 2 pin that will go to the puddle connector (that's already ran in the door). Hope this makes sense.
  5. Sep 20, 2021 at 11:59 AM
    CarverLB
    CarverLB Who Dat?!
    Bryan
    Long Beach, Mississippi
    2021 Trd Sport 4x4
    I don't have the puddle pods on my current truck I left them on my last truck when I sold it. I plan on purchasing the puddle pods as soon as they're back in stock. I'm not looking forward to that boot again!! :frusty:
    20tacoma17 and NoOne like this.
  6. Sep 20, 2021 at 12:05 PM
    Justin_Exploring
    Justin_Exploring Well-Known Member
    2019 BRM Tacoma TRD OR DCSB 4x4
  7. Sep 20, 2021 at 12:06 PM
    boywonder77
    Bay Area
    Ahhhh..gotcha. So it's not necessary to tap into the ignition switch, toggle, etc. Just tap it into the 2pin connector. Then plug and play within the puddle pod system. Basically the benefit of having the puddle pods. :D
    doublethebass likes this.
  8. Sep 20, 2021 at 12:07 PM
    Tacospike
    Two Trucks
    Those are not V5's
    Those are Limited Edition switchbacks. Only 25 were made about 3 years ago.
    Rainoffire likes this.
  9. Sep 20, 2021 at 12:08 PM
    Justin_Exploring
    I'm a dummy :anonymous:
    Tacospike[QUOTED] likes this.
  10. Sep 20, 2021 at 12:09 PM
    Tacospike
    Two Trucks
    No worries buddy. I'm sure you're not the only one who has thought that
  11. Sep 20, 2021 at 12:21 PM
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    Sorry in advance for the confusion, I have a 4 month old screaming at me right now... I have the V1 puddle pods. Do mine have the 2 pin connector I need to ask about in the notes when I place my order? Is the add on DRL harness separate from this 2 pin connector?
  12. Sep 20, 2021 at 12:23 PM
    Tacospike
    Two Trucks
    You do not have the 2 pin connector for the V1 puddles.
    the add on DRL harness is separate from this
    Keep fighting the good fight with the 4 YO :cookiemonster:
  13. Sep 20, 2021 at 12:26 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Little upset that there aren't harnesses for the OEM LED headlights BUT @daveeasa hooked me up a few months back so I should be good to go there.
    Anyone else who is looking for a DRL tap for the 2020+ OEM LED headlights can check out his thread here. Great prices and QC.
    @MESO, is the DRL input used as a trigger (similar to activating a relay and using very low current) or will the turn signals be pulling current through that DRL wire for illumination?
    Tacospike likes this.
  14. Sep 20, 2021 at 12:29 PM
    Tacospike
    Two Trucks
    Turn signals are separate current from the the DRL if I'm reading that correct?
  15. Sep 20, 2021 at 12:33 PM
    MESO
    State of Jefferson
    The same install applies for the V5's if you just want to tap inside the door.
    It is used to power the DRL. But they do not pull that much current ~1-2Amps max.
    Also here is a quick overview and unboxing
    https://youtu.be/_tJBFRkSSfY
  16. Sep 20, 2021 at 12:35 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    @MESO Looking at the pictures that you have on the site, looks like I would hook up the signals like normal for turn signals, then to link them for my strobe system I would want to use the red wire to make them bright strobes or white for dimmer strobes. Does that sound right?
  17. Sep 20, 2021 at 12:36 PM
    MESO
    State of Jefferson
    yes
    5nahalf[QUOTED] likes this.
  18. Sep 20, 2021 at 12:37 PM
    5nahalf
    Erik
    Minnesota
    Perfect! I'll post a video once I get them installed. If these lights can handle strobe systems, they should be pretty much indestructible.
  19. Sep 20, 2021 at 12:52 PM
    Justin_Exploring
    Thanks Stew! That definitely cleared it up for me. I'll for sure be getting the T harness and routing it up to the headlights. Appreciate another kick ass product!
    MESO[QUOTED][OP] likes this.
  20. Sep 20, 2021 at 12:57 PM
    Silver'16TRDSportDCLB
    Silver'16TRDSportDCLB Well-Unknown Member
    Nate
    South-Eastern PA
    2016 Silver Tacoma 4x4 Sport DCLB
    Lights, stickers, audio, and a grille…
    Meso’s front page says in stock, but I can’t order yet!:angrygirl:
    pL4tiNumfi5t likes this.
