Ultimate LED turn signals
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Apr 15, 2017.
  1. Sep 24, 2021 at 12:30 PM
    caribe makaira
    Caribbean, Puerto Rico
    https://youtu.be/_tJBFRkSSfY
  2. Sep 24, 2021 at 1:30 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Consider his regular version then…. Brighter that stock by a landslide (better radius view too) and should work just fine in your application, since essentially same as stock.
    I’d recommend limiteds but you want amber strobe. Limiteds are two circuits, yellow turn and white DRL. Some are upgrading to V5 for the “effects” options.
  3. Sep 24, 2021 at 1:31 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I think thats going to be part of my plan. If I cant get anywhere with the v5, I may have to go for a v4 set and just do the resistors like I had to do with the front and rear signals.
  4. Sep 24, 2021 at 1:33 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Resistors in his turns eliminate that problem in most cases.
  5. Sep 24, 2021 at 1:35 PM
    5nahalf
    Erik
    Minnesota
    the resistors diodes are not for any other issue other than to prevent voltage from the strobe controller from backfeeding into the trucks electrical systems.
    EDIT: I meant diodes I think. Whatever it is thats a 1 way path for electricity.
    AbnMP13 likes this.
  6. Sep 24, 2021 at 1:40 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Ah, yes I was going to ask if Diodes were a better choice… resistors fix that pesky flasher problem of hyperflash.
  7. Sep 24, 2021 at 2:09 PM
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    I would assume and also hope someone makes an instructional video as well. The V5 are far more complicated than the V2 or the limited switchbacks- fortunately for me, I can wait for a video on youtube.
    BlueTRD4x4 likes this.
  8. Sep 24, 2021 at 2:12 PM
    caribe makaira
    https://youtu.be/2Qth3PQGKDo
  9. Sep 24, 2021 at 3:59 PM
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    You are a genius! The wire on the driver's side puddle pod was pinched between the mirror and the the door. I rerouted it a tiny bit and replaced the fuse and now my dome lights and puddle pods are working. Thanks man!
  10. Sep 24, 2021 at 4:38 PM
    NoeWiy
    NoeWiy Well-Known Member
    Alex
    Washington State
    2018 TRD Sport MGM DCSB
    @MESO , can you explain how to install with the 2 pin connector if we don't care about dimming? I'm confused on what to splice into the two black wires coming off the little connectors
  11. Sep 24, 2021 at 5:24 PM
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    got mine today and installed them. found 3 dead LEDs on the driver side turn... :annoyed:
    sent in a warranty ticket, hope there are still some spares in stock!
    sorevilo and FishnTx like this.
  12. Sep 24, 2021 at 5:25 PM
    FishnTx
    South East Texas
    ‘17 OR
  13. Sep 24, 2021 at 5:31 PM
    airmac_11
    Thank you. . . but this is an install of a V-1 or V-2. We need a video for the V-5 and the wiring.
    birdieking33 likes this.
  14. Sep 24, 2021 at 5:32 PM
    Steamy Longbottom
    Steamy Longbottom Well-Known Member
    1LT Browneye
    East TN
    '21 Army Green TRD O/R 6MT
    Modifications are bad and only bad people modify.
    Can confirm, on auto it's basically the same as your "DRL", full bright, during the daytime except at night it should dim when headlights come on. Getting itchy to be one of the Meso bros, lol.
    Still not sure if I should power in from headlamps(I think?) to have the option from the stalk to turn all DRLs off, Tacospike is sure tempting me with a good time...
    Rainoffire[QUOTED] and stiles88 like this.
  15. Sep 24, 2021 at 5:34 PM
    stiles88
    Do it! It really wasn't too bad wiring it to the headlights.
  16. Sep 24, 2021 at 6:03 PM
    caribe makaira
    There is nothing different between them for removal and replacement.
    Once installed, the choice of illumination is in the video:
    Yellow to Yellow = OEM;
    Yellow to Green = Standard Sequential
    Yellow to Blue = Reverse Sequential
    Red to IGN/or MESO pigtail = DRL HIGH
    White
    to PANEL circuit = DRL LOW ...each door has a PANEL circuit feed to illuminate the window switch.
    FishnTx and 20tacoma17 like this.
  17. Sep 24, 2021 at 6:09 PM
    Steamy Longbottom
    1LT Browneye
    East TN
    This would be the first job of this type for this ole dangus.
    For wiring to the headlights, do you just wire an extension of the same gauge wire to the existing clamp/wires for extra length, and run to the full/dim wire on the V5s to the headlights through the firewall pathway? I do have some wago connectors somewhere, unless that's not a good way to connect. I better make sure I connect to/find the right wires...
    I guess the point of having the off-functionality is being able to have the truck running without any lights on/have "ghost" mode, which could be a good idea when I'm in the middle of nowhere camping and might not want to be too visible while in my truck for whatever reason.
    stiles88[QUOTED] and FishnTx like this.
  18. Sep 24, 2021 at 6:17 PM
    caribe makaira
    If you hold off on the DRL side of the wiring you would be able to purchase a plug n play solution. Run the wires from the doors to the cab, though...
  19. Sep 24, 2021 at 6:37 PM
    Steamy Longbottom
    1LT Browneye
    East TN
    That would be optimal, and my gut feeling was to wait for the plug and play. I am guessing it would connect somewhere on the driver's side?
  20. Sep 24, 2021 at 6:41 PM
    caribe makaira
    Yes...:burp:
