Ultimate Off-Road Utility Light and Power Station
Discussion in 'Lighting' started by colinb17, Mar 30, 2014.
  1. Mar 31, 2014 at 6:09 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The amplifier only pulls 2 amps. :D
  2. Mar 31, 2014 at 6:22 AM
    ClayCrusher
    ClayCrusher Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
  3. Mar 31, 2014 at 6:22 AM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    so you're going to have a 24 watt stereo? o.0
  4. Mar 31, 2014 at 6:29 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    There are mixed reviews on the amp and what it can do. It's supposed to be 2x180w, but the power input is 12v at 2 amps. We'll see what it sounds like when I get it put together.
    There are several amps with the same form factor so if this one doesn't work out I'll try a different one.
  5. Mar 31, 2014 at 6:33 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Nice. what speakers are you going to use. i'm debating on using my marine Polk Audios, or just getting a new kit with everything. mine will be in a second stereo only box though. not all-in-one like yours.
    Just so everyone knows what we are talking about, round 2 is the same concept, but a stereo instead of lights. Nathan is simply combining the two into one.
    Picture for refference......
  6. Mar 31, 2014 at 6:46 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
  7. Mar 31, 2014 at 6:57 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    will the usb have audo capability, or just charging? why not just get a little bluetooth reciever so there's no cables outside of the box.
  8. Mar 31, 2014 at 7:01 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The usb will only be for charging. The bluetooth receiver is an option that I may add later on.
  9. Mar 31, 2014 at 7:38 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This is very, very cool... It's like combining the necessities of night camping with the convenience of charging the electronics that would prob be almost burnt out from the days use.
    I'll def be trying to assemble one of these before my trip to Canada. Thanks for the write up! :cheers:
  10. Mar 31, 2014 at 7:41 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :cheers:
    I also should mention, I used an AC charger because i have the factory inverter wired to an outlet inside of the cab. this allows me to use it at night, and charge it while driving around all day. if you do not have in-cab AC power, you can simply splice up a male/male 12V cord and charge it directly off of a cigarette lighter outlet.
  11. Mar 31, 2014 at 7:49 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    This is pretty awesome!
  12. Mar 31, 2014 at 8:10 AM
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Great idea. awesome job. Could you do a quick wiring diagram of the set up? thanks
  13. Mar 31, 2014 at 8:13 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Wiring diagram?
  14. Mar 31, 2014 at 8:22 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Hmm, I like how easy it is to expand on the idea and customize it to your liking. I probably don't need it but I always need a little side project.
  15. Mar 31, 2014 at 8:25 AM
    #35
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Precisely. Goal of this thread was to show that you can fit a decent amount of 12V power into a portable, watertight unit, as a reasonable price. what you do with that power is up to you and your imagination....
  16. Mar 31, 2014 at 9:19 AM
    #36
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    freaking tight!!
  17. Mar 31, 2014 at 10:01 AM
    #37
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I like the mini stereo idea..I could do all sorts of crazy shit with that...hmm..
  18. Mar 31, 2014 at 10:07 AM
    #38
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Any chance of it recharging the truck battery in case of rundown?
  19. Mar 31, 2014 at 10:37 AM
    #39
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the thought actually crossed my mind at one point. chances are slim, but it all depends on how dead it is. the batteries i used do not have the cold CCA to start a truck on their own. that means, that you'd have to hook it up to your vehicle and let the voltages equalize between the betteries. so with a completely dead battery, no chance in hell you'll bring the voltage up enough to start the truck. however, if you're just below the starting threshold (somewhere in the 9V range), then maybe. i would not treat this as a backup jumper though.
  20. Mar 31, 2014 at 12:59 PM
    #40
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    those LED's suck. light output is good. cases are heavy steel. biggest problem is the reflectors are loose in the light and bounce around. I bought four of them and only one is properly secured. I fear if I don't stop the reflector from bouncing around on top of the LED they won't last long.
    #40
