Ultra gauge 2001 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Jun 23, 2015.
  1. Jun 23, 2015 at 11:59 AM
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Alright I searched and didn't find what I wanted.... I see first gens all the time with them... Will I not be able to use it? Its on there list of non compatible
  2. Jun 23, 2015 at 1:50 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  3. Jun 23, 2015 at 7:10 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1. The ISO-9141 & KWP2000 Isolation Cable works perfectly on my 2004 (w/ABS).
  4. Jun 23, 2015 at 7:18 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Alright guys badass..... But one thing.... My taco doesn't have abs :notsure:
  5. Jun 23, 2015 at 8:04 PM
    Norton
    Sorry. I didn't understand that.
    The "incompatibility" is that the UG sometimes causes ABS to enter a diagnostic (i.e., non-functional) mode. No ABS means you have NO problem. The UG will work just fine for you without any special cable.
  6. Jun 24, 2015 at 12:46 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Alright should I just get the cable instead
  7. Jun 24, 2015 at 12:46 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Incase*
  8. Jun 24, 2015 at 7:11 PM
    Norton
    If it makes you more comfortable, by all means, get the cable.
    FWIW, I've run my UG for several years (including several months BEFORE the cables were available), and the ONLY issue I EVER encountered was the ABS one I described above. If you don't have ABS, you should NOT have any problems.
  9. Jun 25, 2015 at 8:18 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Cool man you're the best... Thanks so much
  10. Jun 25, 2015 at 8:20 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've run an ultra gauge on my non-ABS '01 without the cable for a couple years with no issues. Cable is only for those with ABS.
  11. Jun 27, 2015 at 3:24 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    i love tacoma world.. Ordered it
  12. Jun 27, 2015 at 3:35 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    x2.. Has worked flawlessly for 4yrs now
  13. Jun 27, 2015 at 6:00 PM
    MtnClimber
    MtnClimber Well-Known Member
    Jareb
    Wayne, Maine
    '10 DC
    OME suspension, STT Pro's, sliders, XRC 10K winch, Aluminum skids, ARB, CVT, GFC, OVS, ECGS stuff, Midland stuff, TRD stuff
    These will actually tell you your instant mpg, avg mpg, and dte?
  14. Jun 27, 2015 at 6:02 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah, you can check codes. I think it tells you your speed and avg. speed for a trip. Mine will be here Monday
  15. Jun 27, 2015 at 6:10 PM
    MtnClimber
    Jareb
    Wayne, Maine
    '10 DC
    I have a code scanner/reader/eraser for that and my Garmin and inReach can tell me my trip data. I'm more interested in fuel mileage, DTE (Distance To Empty) and any engine telemetry (volts, oil pressure, etc).
  16. Jun 27, 2015 at 11:44 PM
    Norton
    Yes. For me, the readings were in the ballpark right out of the box. They got more accurate with each fill-up, as I made minor corrections to measured fuel consumption and distance traveled via the Vehicle Setup -> Calibration screen.
  17. Jul 2, 2015 at 4:09 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    not to hijack but is this the gauge that reads atf temp too?
  18. Jul 2, 2015 at 4:30 PM
    Norton
    I don't have an automatic, but I don't think so.
  19. Jul 2, 2015 at 4:42 PM
    TIPICOTACO
    Tyler
    nw nj
    No tranny temp
  20. Nov 26, 2016 at 3:23 PM
    dannyk35
    dannyk35 Well-Known Member
    Danny
    Jackson, WI
    2013 Tacoma TRD OR, 2002 Tacoma TRD OR
    Alright, I really don't want to start a new thread so I'm gonna start here. I'm looking to order an UltraGauge, but I'm not sure if I should get the 1.3 or EM Plus. Any suggestions? 2001 SR5.
