Ultra gauge 2001 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Jun 23, 2015.
  1. Nov 26, 2016 at 3:30 PM
    MtnClimber
    MtnClimber Well-Known Member
    Jareb
    Wayne, Maine
    '10 DC
    OME suspension, STT Pro's, sliders, XRC 10K winch, Aluminum skids, ARB, CVT, GFC, OVS, ECGS stuff, Midland stuff, TRD stuff
    I have Scan Gauge II for my 01 DCSB (3.4L, auto). Works super awesome for all my telemetry needs, although I do wish it had the transmission temp option (silly Toyota...)
  2. Nov 26, 2016 at 4:28 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    So if the Ultra gauge doesn't read the transmission temp and that's one of the main things I'm interested in plus everything else. I'll have to get a Scan gauge instead right? I know Scan gauges are more expensive that the Ultra gauge but it's worth it if you want to have the transmission temp.
  3. Nov 26, 2016 at 4:36 PM
    lowriderharold
    lowriderharold Member
    2010 Base 2 Dr. Tacoma/ 2WD
  4. Nov 26, 2016 at 4:42 PM
    MtnClimber
    Jareb
    Wayne, Maine
    '10 DC
    It's not supported in the first gen Taco, only a warning light.
    Sicyota04[QUOTED] likes this.
  5. Nov 26, 2016 at 4:52 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
  6. Nov 26, 2016 at 8:25 PM
    dannyk35
    dannyk35 Well-Known Member
    Danny
    Jackson, WI
    2013 Tacoma TRD OR, 2002 Tacoma TRD OR
    Thank you all for your answers. I'm going with the MX 1.3. How do you all have them mounted?
  7. Nov 26, 2016 at 8:32 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You can get an x-code to put into your scanguage to get it to pull trans temp. It would pull the temp on my 99 Prerunner. My 99 4wd doesn't use a sensor, but your 2001 should use a sensor. I can find the code if you need it
  8. Nov 26, 2016 at 10:31 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Mine fits snugly in the cubby right under the radio.
  9. Nov 27, 2016 at 4:54 AM
    MtnClimber
    Jareb
    Wayne, Maine
    '10 DC
    Sure, that'd be great. It's worth a shot to see if it'll work!
  10. Nov 27, 2016 at 6:47 PM
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    I got the em plus. Is amazing and I love it. Would get that
  11. Nov 27, 2016 at 7:29 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    My scanguage reads my trans temp.. 04 taco
    Croth51[OP] likes this.
  12. Nov 27, 2016 at 9:15 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
  13. Nov 28, 2016 at 7:20 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    I think mine is the scanguage 2 or something....there is a code you have to input to make it work.....been years since I did it...should be in the instructions
