Ultra gauge mounting location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DryCreek, Jan 28, 2014.
  1. Oct 20, 2014 at 1:28 PM
    #141
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Remounted mine since I installed a dash cam
    Taco_2s_day and scott96929 like this.
  2. Oct 21, 2014 at 5:21 AM
    #142
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Pm'd
    Thanks!
  3. May 14, 2015 at 2:52 PM
    #143
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    I have mine mounted on the left side of the dash. I used one half of a conduit clamp that I found at work. Rounded end slips in between dash pieces. Applied glue to their end and used the clamp holder from a Goxt cell phone holder to glue to the conduit clamp. My original holder broke.
    MY50cal and scott96929 like this.
  4. Jun 9, 2015 at 7:53 PM
    #144
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I liked one that I saw in the first couple pages and I just rigged it up today
  5. Jun 9, 2015 at 7:55 PM
    #145
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  6. Jun 10, 2015 at 4:25 AM
    #146
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
  7. Jun 10, 2015 at 7:07 AM
    #147
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I think this is the best solution I've seen yet, I like how clean and isolated it is, definitely going to try this myself. What dash pieces specifically did you use?
  8. Oct 6, 2015 at 11:42 PM
    #148
    NewShockerGuy
    NewShockerGuy Member
    Nigel
    DC
    So I gotta ask how exactly did you mount it there? Did you screw it in, double sided tape/jb weld..etc?
    I like how this looks.
    Thanks,
    -Nigel
  9. Feb 28, 2016 at 6:48 AM
    #149
    Truck Yeah
    Truck Yeah OK, maybe just 1 more...
    Maryland
    2013 Silver TRD Sport Access Cab
    Toytec Boss 3" Lift, Dakar Leaf Pack, Light Racing UCAs, ECGS Bushing, 265/70R17 Duratracs, 17 x 9 Fuel Mavericks, Truxedo Low Pro QT, AntennaX 14" Billet, Weathertech Front Mats, Pop and Lock PL5400, OEM Chrome Exhaust Tip, OME Carrier Bearing Drop, OEM Bed Mat, NFab Textured Black Step Bars, OEM Mini Tie Down with Hooks, Tinted Front Windows, Stainless Steel Braided Rear Brake Lines, mattgecko Sliding Window Security Bar, OEM Black Badges, Depo Black Tail Lights, Winco Console Caddy, Turn Key Clamp Anti Theft Tailgate Mod, Devil Horns by Andres Diaz, Kenwood DDX672BH Receiver, Memphis Audio 6x9 Component Speakers in the Front Doors, Memphis Audio 6.5" 2 Way Speakers in the Access Cab Doors, Bazooka 6.5" Bass Tube, Kenwood Excelon XR900 5 Channel Amp, Custom Access Door Speaker Covers, Rokblokz Oversized Mud Flaps, Philips EcoVantage 750 Lumens GY6.35 Reverse Bulbs, ImMrYo Mirror Relocation Bracket, UltraGauge MX, SmittyBilt D Ring Shackle Hitch Receiver, BP Fabrications Front Recovery Bracket with D Ring Shackle Receiver, YotaMafia US Flag Decals, DirtyD510 Custom Weathertech TRD Decals, Plano Storage Full of Recovery Gear, Bed Storage Compartment D Rings, TRD Shift Knob, TRD Oil Cap TRD Radiator Cap, Amp Research Bed Extender, OEM Skid Plate, Rigid SR30 Lightbar in the Lower Valence with Rigid Mounts and a Mictuning Dash Switch, ACEkraut License Plate Relocation Bracket for the OEM Skid Plate, BumperPlugs, Rear Diff Breather Relocation Mod with Uni Breather, Redline Tuning Quicklift Hood Struts, Apex Fog Light Mounts with Cali Raised 18W Amber Pods, nd4spdbh Fog Light Anytime Mod, Wheelers Front Superbump Stops, Uni Breather Smog Air Pump Mod, tsumara Cup Holder, Bullaculla Trailer Plug Relocation Bracket, Salex Glove Box Organizer, Grid-It Center Console Lid Organizer
    Decided to finally install the UltraGauge I bought a month ago. I hadn't done it yet because I was planning on mounting and running the cable up the A pillar, which would require disconnecting the battery to avoid possible airbag sensor tripping. I didn't want to disconnect the battery without first jotting down all of my custom head unit settings. Well, plan B. Saved myself the hassle and just mounted it over the TRD Sport's blank switch covers, next to the USB/AUX input. Took 5 minutes. I ran the cable into the cubbie on the right side of the steering wheel, then between the bottom of the steering column and the cover. No cutting, had to remove nothing and the cable isn't seen. Used the vertical mount from UltraGauge and just trimmed it down to 1.5" x 2", the size of the two switch blanks. The buttons on the rear of the UltraGauge are easily accessible and I left plenty of extra cable in the cubbie. Very happy with it. Easy for me to read, yet not easily seen from outside, especially with tinted windows.
    scott96929, Valpo and Soul Surfer like this.
  10. Jul 27, 2016 at 5:02 PM
    #150
    Lita4x4
    Lita4x4 Well-Known Member
    Daniel
    California
    2017 DCLB TRD Sport
    How did you pull that off?
  11. Aug 1, 2016 at 3:21 PM
    #151
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
  12. Sep 26, 2016 at 10:46 AM
    #152
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    14444888_10209507908227338_3710714033945_66706704f38fd6143a01d7d92a14860c3f3b8a65.jpg
    Using the vertical surface mount in the upper left corner of the windshield. Out of the way, easy to see, and discreet. Install took literally 10 minutes. Remove A pillar trim(two 10mm bolts) and it comes right off with no prying. Drop UG OBD connector between pillar and dash and install.
  13. Apr 9, 2017 at 5:31 PM
    #153
    Valpo
    Valpo Well-Known Member
    Indiana
    2015 4x4
  14. Apr 9, 2017 at 5:58 PM
    #154
    Justinlhc
    Justinlhc Not looking for a relationship
    Why does mine look like a chaotic mess compared to everyone else's? :annoyed:
    igno1tus likes this.
  15. Jul 21, 2017 at 11:18 AM
    #155
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
    This thread is pretty old but I came here looking for ideas yesterday so wanted to contribute back with my own setup. I used a guy wire tensioner I had laying around in camping supplies from my hammocks and mounted that under the forward visor screw. The Ultragauge with the included mount clip it comes with just slides directly onto the tensioner with nothing holding it on other than a tight fit and friction. Wire ran down through pillar and under dash for a clean install. It has held on for roughly 20 miles so far with no movement and the buttons couldn't be easier to get to! Visor movement is reduced to about 45 degrees but I don't use it in front of me anyway and there is no issue rotating it over to the door.
    [​IMG] [​IMG] [​IMG] [​IMG]
  16. Jul 21, 2017 at 12:17 PM
    #156
    Boilerman
    Brian
    It slips down in between the dashboard and the trim piece with the a/c vent on it. Just used a small screwdriver to separate the two pieces to get the conduit clamp to slip in.
  17. Sep 13, 2018 at 8:56 AM
    #157
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
  18. Sep 21, 2018 at 4:54 AM
    #158
    KeithB
    Keith
    Cheshire, CT
    Mounted mine in front of the RPM gauge. I can still see up to 2500 rpm and there are no idiot dash lights in the top section of the rpm gauge so nothing is blocked besides the higher rpm which I normally never reach anything over 3000rpm. Also, I tried in the bottom left and upper left of the windshield and near the rear view mirror but didn't like that my visibility was hindered or that the gauge would be in direct sunlight and in view of thieves. Here it's much less obvious and can't be seen through my tinted windows unless you are specifically looking for it. I used the horizontal surface mount and routed the wire around the outside fo the rpm gauge and down through the steering column.
  19. Sep 25, 2018 at 3:50 PM
    #159
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Looking at the mount option on the ultragauge gauge website. It looks as though both the vertical and horizontal mounts are curved. How well do they stick to the windshield near the rear view mirror? Also which is the suggested mount for near the mirror?
  20. Sep 25, 2018 at 4:03 PM
    #160
    yotagang548
    yotagang548 Active Member
    Squamish, B.C.
    2009 Extended cab Tacoma TRD
    Flowmaster 50 series muffler n' some stuff
    I put mine above my rearview mirror with the horizontal pivot mount. You can hide the cable the whole way down and it's a nice location that's easy to glance up at.
