ultra gauge problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirtytaco2010, Oct 7, 2010.
  1. Oct 7, 2010 at 7:12 PM
    dirtytaco2010
    dirtytaco2010 [OP] Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    I have had my ultra gauge for about 1 month up until now I have loved it. Today my tire air sensor went on. I checked air pressure sure enough it was low. Filled tires. Still having low air sensor issues. Finally took it to the dealer they thought it was 2 broken sensors from having my tires installed. Then the tech reset it again this time without the ultra gauge plugged in and no more error code.
    Just curious if anyone else is experiencing any problems with their ultra gauge?
  2. Oct 7, 2010 at 7:26 PM
    dirtytaco2010
    SR5 TRD Sport LB
  3. Oct 7, 2010 at 7:32 PM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    i've had mine for a couple months, no problems with it so far...changed my tires out twice, had the maintenance light come on the dash plus the ultragauge alarm
  4. Oct 7, 2010 at 7:34 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Had my slip indicator light and my ABS light come on when I first installed it, but other than that it's been great.
  5. Oct 7, 2010 at 7:36 PM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    ^^ i noticed that as well, forgot to mention
  6. Oct 7, 2010 at 7:51 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    no problems at all here...
  7. Oct 7, 2010 at 8:02 PM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    Does the ultra gauge read/display tire pressure? I don't have one, but Im curious on why it interferes with the tire indicator as mentioned by the OP.
  8. Oct 7, 2010 at 8:07 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    No, it doesn't show tire pressure. I haven't had any issues with mine...thus far.
  9. Oct 7, 2010 at 8:13 PM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    My tire sensor went on also....but i'm pretty sure i know why. I live in southern cali and in the begining of the week my tire sensor went off cause of the weather. it was really cold a couple of days and i remember that back last winter when it got cold, cold the sensor would light up. but once it warmed up it goes off....not right away but eventually does. so i doubt its the ultra gauge. most likely a coincidence that the tech unplugged the UG and your sensor light went out.
  10. Oct 7, 2010 at 8:32 PM
    dirtytaco2010
    SR5 TRD Sport LB
    so an update on my issue... after leaving the dealership i left the ultra guage unplugged drove it 3 times after the 1st time no light came on. But after the 2nd it came back on without the ultra gauge plugged in. so i doubt its the gauge. It could be when I had my tires installed they broke the sensors...or its a manufacturer issue.
    T-frax it was cold up here too this am. about 49 but as it warmed up there was no change it had been on all day. I thought the temperature may have done it when i was airing up my tires this morning but who knows. Im taking it to the place i had my tires installed tomorrow
  11. Oct 7, 2010 at 8:52 PM
    t-frax
    Cali
    yeah mine is still on too even though it has warmed up a bit but i know it will eventually go off as it has happened to me twice before....last winter and couple of weeks ago. by any chance did you check your spare tire?
  12. Oct 7, 2010 at 9:11 PM
    dirtytaco2010
    SR5 TRD Sport LB
    ok ill give it a few days then...no I didnt check it is there even a sensor on it?
  13. Oct 7, 2010 at 9:33 PM
    t-frax
    Cali
    yes there is is sensor on your spare...or at least there should be. Most of the time if it isn't the cold and your tires are aired and the sensor light is still on, could be the spare because most people...like me...forget about it and don't check the pressure.
  14. Oct 7, 2010 at 10:07 PM
    dirtytaco2010
    SR5 TRD Sport LB
    ok ill check that out. My truck is barely a year old how fast will a spare air down? either way ill check it. thats one of the 3 things it can be. at least the tires are holding air and its safe to drive
  15. Oct 7, 2010 at 11:03 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    You check the spare?
  16. Oct 8, 2010 at 6:26 AM
    BCTacoma2010
    BCTacoma2010 Michigan Member
    Jay
    Southwest Michigan
    2017 Ford Platinum F150
    Toyota discontinued the spare tire sensor on the Tacoma. I'm not sure what year but the 2010's do not have it.
  17. Oct 8, 2010 at 6:29 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    no issues with it although i know it reads my gas tank level as being more full then it actually is.
