Ultra gauge way off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shoebag22, Jul 5, 2012.
  1. Jul 8, 2012 at 5:48 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Did You get the Ultra Gauge setup correctly in the beginning?
    Engine size, Tank Size, etc
    Then Calibrate distance on the highway from mile marker to mile marker.
    Sound like it thinks it's in a different vehicle :confused:
    CC
  2. Jul 8, 2012 at 8:40 AM
    Rodallg
    Rodallg Well-Known Member
    CA
    I've been where you are since the instructions aren't real clear that you need to add the gallons up as you fill up. Such as first fill up you put in 10 gallons and record in the unit 10 gallons, second fill up you put in another 10 gallons and then record 20 in the unit.
  3. Jul 8, 2012 at 6:12 PM
    shoebag22
    shoebag22 [OP] Well-Known Member
    you may be on to something. I thought about this last night. When i first got it i plugged it in to my wife's car to clear the check engine. Bet that is where my problem is. Thanks guys. stay tuned.
  4. Jul 8, 2012 at 6:13 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It didn't "learn" anything from her car, but if you never went through the vehicle setup, then that explains why your DTE is off.
    It needs to know your engine size, fuel tank size, etc....
  5. Jul 8, 2012 at 6:32 PM
    shoebag22
    i went through the engine size/tank size calibration on the truck
  6. Jul 8, 2012 at 6:42 PM
    Cape Codder
    Jack
    .........................................And?
    CC
  7. Jul 8, 2012 at 7:21 PM
    shoebag22
    when i first got it i went through the calibration steps, so a factory reset is all I can think of.
  8. Jul 8, 2012 at 7:29 PM
    Cape Codder
    Jack
    Yeah, start at square one
    Mine's been accurate since first installed (Sept 2010)
    CC
  9. Jul 25, 2012 at 1:50 PM
    shoebag22
    i reset everything and started fresh and all appears to be working properly. I went through the calibration the first time, so I have no idea what when wrong. thanks for the help guys.
  10. Jul 25, 2012 at 11:57 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Here is a link for the directions since the unit does not come with any. It took me a while to get mine calibrated, but finally done. I think it is page 29-30. It evens calibrates my speed since I have larger tires. I would do the distance calibration on a 50 mile stretch of highway to be sure. Mine is accurate now and no issues. The fuel level and DTE is spot on with my low fuel light.
    http://ultra-gauge.com/ultragauge/support/ultragauge_user_manual.pdf
    Speedo say 80
    UG says actual
  11. Jul 26, 2012 at 5:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    80 vs 87.5???????
    The UG takes it's information from the same data source as the speedometer. Did you calibrate yours against a GPS or are you just assuming that the UG is "correct"?
    Normally, at 80mph indicated, a stock Tacoma will normally be doing around 75.
    To get the kind of error that you're reporting, you'd have to be running 35's.
  12. Jul 26, 2012 at 6:06 PM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I stopped at a mile marker 120 on the highway and reset the trip on the UG. I drove to mile marker 70 and stopped. When I was there I went into the calibration screen and adjusted the mileage to 50 which was the actual distance I traveled. It was off by 5 miles. The faster I go the greater the distance between the speedo and the UG. Cruising around 65 MPH the UG reads 70 which is correct, but the faster I go the more it is off. My MPG is actually very accurate since I calibrated it and has never worked better. THe only true test is to have a car along side of me and give them a fixed speed to travel and compare. I may do that in the near future
  13. Jul 26, 2012 at 6:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Odometer and speedometer do not have the same factory error.
    Similar to my motorcycle... speedo is about 10% off, odo is about 5% off.
    The taco is the same way.
    Compared to the GPS, I'm running 70 when the speedo is showing 75 or 76, but the odometer only shows about a 2% error (2 miles off for 100 traveled).
    You need to verify speed using a GPS.
    Using mile markers works for distance, but 50 miles is not enough.
    Even a 5% error is only going to show a 2.5 mile difference in 50 miles.
    The higher the speed, or the greater the distance, the greater the number differential will be, and the more accurate your calculated percentage error will be.
