Ultra Guage accuracy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCal_Yotas, Jan 17, 2016.
  1. Jan 19, 2016 at 5:50 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
  2. Jan 19, 2016 at 5:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Jan 19, 2016 at 5:53 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    mine is within .3 with my 3 inch lift
  4. Aug 6, 2016 at 6:55 AM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Resurrecting an old thread.
    I just filled up with my Ultragauge and I'm about 1.5 mpg off. The gauge said my average was 18.8 and when I check miles on the ODO divided by gallons pumped I got 17.2!
    I drove 10 miles a few months ago to calibrate the odometer on the UG. It was +0.005 miles. My tires are slightly taller than stock but not by much. I've seen people mention calibrating fuel usage but I don't recall seeing it in the manual. Anyone have more specifics?
    *EDIT* found the calibration method in the above link.
  5. Aug 6, 2016 at 12:46 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    If you haven't done it, test your gauge's odometer function error by driving and comparing at least 25 miles (by mile marker or GPS) to get the % to adjust your gauge. Might want to do it every 10,000 miles to compensate for tire wear.
  6. Aug 6, 2016 at 12:52 PM
    weldo
    Pittsburgh, pa
    I did that a few hundred miles ago. I stop on the shoulder of the highway at a milemarker and hit "zero" then drove 10 mile and stopped again. The ultragauge said I went something like 9.995 miles. I punched in 10.000. I'll have to double check it tho, I had the battery disconnected a few times. The instructions say the calibration should not be lost but who knows, stranger things have happened.
  7. Aug 6, 2016 at 12:52 PM
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    i just plugged in and played.... it says i average 14mpg which is what I calculated my average was awhile ago before ultra gauge. I have a 6 in lift with 35s
