ultra guage is showing code..HELP PLEASE
Discussion in 'Performance and Tuning' started by 1mrwatermaker, Jan 12, 2013.
  1. Jan 12, 2013 at 3:13 PM
    1mrwatermaker
    1mrwatermaker [OP] Well-Known Member
    Kentucky
    2006 TRD 4X4
    XD Chrome Revolvers 18x9, 285/60R18 Cooper Zeon LTZ tires,chrome bull bar,chrome nerfbars, foglight mod, led interior lights,5% tent all around, factory HU, AUX mod kicker6x9 front, kicker 6.5 rear, power acoustik tweets F&B, eclipse EQ, kicker 4 ch amp, 600D directed amp, 2 8" Kicker DVC Comp subs, ultraguage, LED cupholder lights, LED bed lights
    My UltraGuage is sounding an alarm for a pending trouble code... code is 0456 does anyone know what that might be. No check engine light on , everything looks good
  2. Jan 12, 2013 at 3:16 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
  3. Jan 12, 2013 at 3:17 PM
    1mrwatermaker
    Kentucky
    2006 TRD 4X4
    yep forgot to put in the P
  4. Jan 12, 2013 at 3:22 PM
    1mrwatermaker
    Kentucky
    2006 TRD 4X4
    from what im getting from google it has to do with the fuel system ( cap, hose, vent, line ext.)
  5. Jan 12, 2013 at 3:26 PM
    1mrwatermaker
    Kentucky
    2006 TRD 4X4
    just read your reply thanks for the quick answer. put gas in the truck today and left it running , that cld have caused my problem.....
  6. Jan 12, 2013 at 4:08 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That would definitely trip a P0456. Reset it, tighten the cap just to be sure, and you should be fine.
  7. Jan 13, 2013 at 7:29 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Here is what you do from this point on.
    TURN OFF ALL THE ALARMS on the Ultra Gauge.
    If you get a real code the check engine light will be on and you can check the code then. Until then you do not need that alarm going off for all kinds of different things that do not matter.
    G
  8. Jan 13, 2013 at 10:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ^^^ Word. All of those pending Alarms will make a person paranoid.
