Ultra-Power 02 Sensor Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by nchiker1, Jun 26, 2020.
  1. Jun 26, 2020 at 6:44 AM
    nchiker1
    nchiker1 [OP] Well-Known Member
    My upstream 02 sensor needs replaced. Advance Auto's cheapest option is $180, so I went over to rockauto.com.
    They have Bosch and Walker sensors for ~$150, but Ultra-Power brand ones for 60 bucks! Have to ask just because of the 'yuge price discrepancy, any reason I shouldn't just get the $60 sensor?
  2. Jun 26, 2020 at 6:59 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Denso or OEM Toyota (made by Denso) only, that is the reason and only one you should get
  3. Jun 26, 2020 at 7:13 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I don’t think anyone on here has ever reported success with anything other than DENSO or OEM.
    Black DOG Lila and nchiker1[OP] like this.
  4. Jun 26, 2020 at 7:23 AM
    nchiker1
    But is it really worth 3x the price? Do I get 3x the life out of them, or what?
    cruiserguy[QUOTED] likes this.
  5. Jun 26, 2020 at 7:25 AM
    cruiserguy
    Elijah
    SEKS
    You get the sensor that was used in the design of the system. You may get a year or two out of a Bosch or other no name part or a month or two.
  6. Jun 26, 2020 at 8:07 AM
    Glamisman
    Glamisman Well-Known Member
    non oem O2 sensors have the tendancy to not operate within the parameters that the system was designed for and might trip a CEL. Generally, if you install a part it is yours and if it does not work properly now you get to buy a second O2 sensor that will work.
    nchiker1[OP] and Black DOG Lila like this.
  7. Jun 26, 2020 at 9:31 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I'll bet there's a hundred thousand tacomas out there running these chinese o2 sensors. They're probably fine. They might not be. I know a Denso it going to work.
    nchiker1[OP] and Wyoming09 like this.
  8. Jun 26, 2020 at 9:35 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Denso sensors is the brand Toyota built these trucks around, the ECU is programmed to the sensor's exact parameters. When you throw an aftermarket sensor into the mix, you're taking a shot in the dark as to whether or not it's going to meet those exact specs. Might not throw a code right away but chances are it won't last nearly as long as it should.
    Toyotas are well-known to not play well with aftermarket sensors, just the way it is. Buy once cry once
  9. Jun 26, 2020 at 10:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your going off brand Sensor just save your money leave the old one in the same end results .
    Once I got the exhaust system sorted out I have close to 150,000 miles on my Denso Sensors
    I get mine a Napa
    cruiserguy likes this.
