Ultragague pending codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Oct 25, 2015.
  1. Oct 25, 2015 at 10:19 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    P0441 P0455 what is that? Only thing I did this morning was put gas in. And left the gas cap attached to the gas door and driver for a bit. Nothing showing on dash at all. Gas cap is back on, and car has been restarted a few times and it still sounds
  2. Oct 25, 2015 at 10:30 AM
    Unchained 5150
    Rick
    Auburn Ma
    So answered my own question? Thank you self.
  3. Oct 25, 2015 at 10:31 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    just reset it, code set off due to you driving without the gas cap on. if it does come back on
    P0441:
    • Bad vacuum switch
    • Broken or damaged EVAP line or canister
    • Open in PCM purge command circuit
    • Open or short in Voltage feed circuit to Purge Solenoid
    • Faulty purge solenoid
    • Restriction in EVAP solenoid, line or canister
    • Corrosion or resistance in purge connector
    • Bad PCM
    P0455:
    • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
    • Otherwise, replace the gas cap, and/or
    • Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
  4. Oct 25, 2015 at 10:32 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Man you gotta be patience next time :laugh:
    Unchained 5150[OP] likes this.
  5. Oct 25, 2015 at 10:34 AM
    Unchained 5150
    Rick
    Auburn Ma
    Yeah figured it was the gas cap. Replaced it and found the code in the Ultargauge. Cleared it and no in the gauge in the TC area states no codes now.
  6. Oct 25, 2015 at 10:37 AM
    00yotasr5
    lee
    merced, ca
    Lol I remember a few years back I left mine on the tire and ran over it. Drove to Toyota (5 miles) to get a new one and the damn light never came on.
  7. Oct 25, 2015 at 10:39 AM
    Unchained 5150
    Rick
    Auburn Ma
    Is there a dash light for it? Because it never went on?
  8. Oct 26, 2015 at 1:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes there is a light for it. " Check Engine Light or CEL " P0441 P0455.
  9. Oct 26, 2015 at 4:40 AM
    Unchained 5150
    Rick
    Auburn Ma
    Hmmmmmmmmmmmmm never came on just a noise on the UG
