Ultragauge for Manual Transmission Temps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bayou Baw, Oct 20, 2019.
  1. Oct 20, 2019 at 12:20 PM
    Bayou Baw
    Bayou Baw [OP] New Member
    2009 taco TRD SPORT 4X4
    Does anyone know if the Ultragauge MX 1.4 will display transmission temperature for my manual 6 speed? All threads I've seen so far only refer to ATF, torque converters etc.
    Thanks in advance!!
  2. Oct 20, 2019 at 12:28 PM
    Pigpen
    Dan
    Northwest Montana
    There's no temp sensor in the manual trans. Temp shouldn't be an issue unless you drive around hitting the Rev limiter all the time.
    Bayou Baw[OP] likes this.
  3. Oct 20, 2019 at 12:33 PM
    Bishop84
    Bishop84 Well-Known Member
    No sensor, your motor would be nuclear before a m/t overheated.
  4. Oct 20, 2019 at 12:33 PM
    Bayou Baw
    That's what I figured. I drive like a normal person and dont tow often, I just like the idea of having access to that information but no big deal. Will probably still get the gauge anyways for the rest of the features.
    Thanks for the quick reply
