UltraGauge Group Buy - 55 shipped
Discussion in 'Group Buys' started by JAG, Sep 1, 2010.
Thread Status:
Not open for further replies.
  1. Sep 4, 2010 at 2:39 PM
    #361
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    Well got mine today about to plug it up to my truck. However I did plug it up in my grandma's 2007 Kia Sorento earlier today and for some odd reason it turned the stability control off.:confused: But any how does any one know the exact size of the fuel tank on the 4cyl 1st gens? I guess it to be about a 16 gallon tank but Im not 100% sure. And also can someone please link my to the user manual please!!
  2. Sep 4, 2010 at 2:42 PM
    #362
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dam i just went downstairs and guess what i got....yup its here
    now i am going outside to try it out......
  3. Sep 4, 2010 at 2:42 PM
    #363
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Go to the support page, can't miss it. :thumbsup:
  4. Sep 4, 2010 at 2:44 PM
    #364
    jab08
    Alabama
    02 T4R 4wd
    Thanks found it I think I looked at everything else on their site except the support link:eek:
  5. Sep 4, 2010 at 2:51 PM
    #365
    jab08
    Alabama
    02 T4R 4wd
    Wow!! I just googled the tank size and it says its a 68 liter tank. So 18 gallons is that correct? The most I have ever put in is about 14.5 gallons and that was with the gas hand sitting below the E mark. Does this sound about right???
  6. Sep 4, 2010 at 2:59 PM
    #366
    brutalguyracing
    F.U> GUYZ
    broken mods
    dam this is the most stupid rebate ever
    :help::help::help:
    PROBLEM SOLVED IM STUPID
    SEE BELOW
  7. Sep 4, 2010 at 3:03 PM
    #367
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Not sure if 00 is the same but for 01-04:
    5 lug - 16.0 gal
    6 lug - 18.5 gal
  8. Sep 4, 2010 at 3:04 PM
    #368
    JAG
    JAG [OP] Well-Known Member
    Yeah the most I ever feel up is 19 and I have a 21 tank.
    Its really simple. Just take your computer out there. I should have saved the numbers for you. Plug the unit into your truck and run the test with the truck running or switched to on.
  9. Sep 4, 2010 at 3:08 PM
    #369
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yup, despite what the actual specs of the tank sizes are listed by Toyota, no matter how bone dry you run your tank down to, even to the point where it won't start no matter what at any angle, you'll still have fuel in the tank.
  10. Sep 4, 2010 at 3:14 PM
    #370
    JAG
    Thats crazy! Too bad theres not a secret unlock switch when you run out of gas.
  11. Sep 4, 2010 at 3:30 PM
    #371
    jab08
    Alabama
    02 T4R 4wd
    Ok thanks!! I just set it to 18. Any one have any clues as to why it disabled the stability control on the Kia?? I had to unplug the gauge and restart the engine to get it back on.
  12. Sep 4, 2010 at 3:58 PM
    #372
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    ok so I just got mine today... I plan to take some pic's later today all I can say for now is this thing is a lot smaller than what I thought...
  13. Sep 4, 2010 at 4:01 PM
    #373
    jab08
    Alabama
    02 T4R 4wd
    Pics on the way!!! Uploading them now!
  14. Sep 4, 2010 at 4:11 PM
    #374
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    In for 1. ~$79 via PayPal. Added notes to both UG and PayPal. PM'ing now.
    Thanks!
  15. Sep 4, 2010 at 4:18 PM
    #375
    jab08
    Alabama
    02 T4R 4wd
    Wow this thing is sleek! I ran the cord through the opening for the e-brake and stuffed the extra wire behind the center dash. I just set it on top of the steering column and it seems to set there pretty snug. I tried a few kinda sharp turns to try and fling it off but it never budged so hopefully it will stay without any problems. I haven't had it in there but for about 15min so I cant really give any detail on the accuracy, but I drove to the gas station with it and topped off the tank. So Ill let yall know after I drive a little more how it does.
  16. Sep 4, 2010 at 4:32 PM
    #376
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Can anyone take pics of the back? Wondering if I can mount it in the upper left corner of the windshield.
    Also how long is the OBD2 cable?
  17. Sep 4, 2010 at 5:25 PM
    #377
    fsbrain03
    fsbrain03 Well-Known Member
    It's only 9 bucks. Don't freak out too bad man.
  18. Sep 4, 2010 at 5:42 PM
    #378
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    To anyone waiting for my review for the 1st gens you may have to turn else where :-(. I can't get paypal to hurry up and process and it says estimated process date 9/8. The buy will be over by then. There was a link to a ttora thread talking about the same problem on the scanguage II. Maybe check it out. It had some solutions to the abs dilemma on it.
  19. Sep 4, 2010 at 5:51 PM
    #379
    tootall
    tootall Well-Known Member
    Todd
    Maryland
    10 5 Lug Reg Cab Magnetic Gray
    Secondary Filter Removed, AVS In line vent visors, pop n lock, extang tri-fold tonneau, Fat Bob's 5 lug lift kit, Intermittent wiper stalk, mdshooter.com sticker
    no clue whats up but i have cookies enabled and cant get the damn site to work in either IE or Firefox. FML. works on the fiances computer... but the now SWMBO's input must be used lol
  20. Sep 4, 2010 at 6:23 PM
    #380
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    read somewhere it was 6ft
Thread Status:
