Ultragauge group buy
Discussion in 'Group Buys' started by Traviste, Jan 24, 2014.
Thread Status:
Not open for further replies.
  1. Feb 24, 2014 at 2:30 PM
    #861
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    PM'd.
  2. Feb 28, 2014 at 5:07 AM
    #862
    MyMistress
    MyMistress Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
    Pm'd
  3. Mar 3, 2014 at 4:45 PM
    #863
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Why does the UG think I went 355 miles when I only did 195?
  4. Mar 3, 2014 at 6:26 PM
    #864
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    You have to calibrate the unit for your tires and gear ratio. Make sure to check the online manual to perform this. Basically you drive a known distance above 50 mph and then you plug in that distance once you're done. You can use mile markers or a GPS unit.
    RJM
  5. Mar 3, 2014 at 6:28 PM
    #865
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I use the tire calculator on here and input my stock tire size and new tire size, and whatever the percentage is for circumference is what I use.
    I took how many miles my trip meter showed. Say 300. And multiplied by 1.079 to add in the difference in tire size. And then used that as my calculated true distance.
    Calibrate Distance
    MENU > Vehicle Setup .. > Calibration.. > Calibrate Distance
    Use this menu item to calibrate all Distance Gauges. This calibration also directly affects the accuracy of all Speed, MPG and
    DTE gauges. This calibration is especially necessary for vehicles which no longer have the stock wheels, tire sizes,
    transmission, or rear-end differential. This calibration will also compensate for inaccuracies in stock speed sensor and the
    vehicle’s distance measurement system. Perform this Calibration prior to all other calibrations.
    **** Calibration cannot be performed unless a distance of at least 4 Kilometers or 2.5 miles have been driven. ****
    To perform the distance calibration follow this procedure:
    1. Align front tire with first mile marker
    2. Reset the trip gauges: MENU > Gauge Menu > Zero All Trip
    3. EXIT THE MENU
    4. Travel to the 3rd mile marker (at 50+MPH), aligning the front tire to the mile marker
    5. Select: Menu > Vehicle Setup > Calibration > Calibrate Distance
    6. Change the value shown to 3.000 miles*, using the UP and DOWN keys
    7. Press Menu to save and set the calibration
    Once saved, the calibration factor will be displayed at the bottom of the display
  6. Mar 3, 2014 at 6:51 PM
    #866
    MatthewMay1
    Matthew
    Lone Star Republic
    Well here's what I did. Last time I filled up the tank, I reset the odometer. Then when I filled up tonight I took the 195 miles I got and set that in the UG. Also clicked the "full fill up" button as well. I have stock everything except my tires are 75 aspect ratio rather than 70. That shouldn't effect my readings by over 100 miles. I did the same process the tank before this last one
  7. Mar 3, 2014 at 6:51 PM
    #867
    PcBuilder14
    Brent
    Nor Cal
    Did you input the size of your gas tank?
  8. Mar 3, 2014 at 6:56 PM
    #868
    MatthewMay1
    Matthew
    Lone Star Republic
    Sure did. When I click fill up it says 18.5 gals remaining
  9. Mar 11, 2014 at 9:39 PM
    #869
    lkwan78
    lkwan78 New Member
    Luke
    Sugar Land, Tx
    if they start another group buy. i would be interested.
    Or For those that may have bought multiple units... if you have an extra one that you want to sell let me know as well.
    lkwan78@gmail.com
    Thanks
  10. Mar 25, 2014 at 5:03 PM
    #870
    MatthewMay1
    Matthew
    Lone Star Republic
    Another tank of gas passed and the UG thinks I drove 302 miles when I actually drove 173. I calibrated it last fill up. What am I doing wrong??? Please help!
  11. Mar 25, 2014 at 5:25 PM
    #871
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    I have one never opened with a mount if anyone is interested pm me
  12. Mar 26, 2014 at 7:40 PM
    #872
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I will sell mine for 55 shipped no mount as it is stuck to my head unit and not sure if it will be useable when i pull it off but will send it to if wanted .
  13. Mar 27, 2014 at 2:08 AM
    #873
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Mine is sold
  14. Mar 29, 2014 at 7:37 AM
    #874
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Don't laugh - you may have already checked this but is it maybe measuring kilometres? 302 kilometres is pretty close to 173 miles. Maybe you either have it set for ams or it is doing it in error.
  15. Mar 29, 2014 at 2:20 PM
    #875
    MatthewMay1
    Matthew
    Lone Star Republic
    Haha, no. The KM it thought I drove was way more than 300
  16. Mar 29, 2014 at 8:42 PM
    #876
    Loco38SUP
    North Seattle, WA
    Can you post what the factor is set at in calibration screen?
    Also what is your tire diameter?
    RJM
  17. Apr 13, 2014 at 9:59 PM
    #877
    MajorPayne
    MajorPayne Well-Known Member
    North East Oregon
    Gold 1995 Tacoma LX 4x4
    Camo Interior 3" Camburg Coilovers Camburg UCA's 2" rear block lift monomax rear shocks Pioneer deck Pioneer door speakers 10" rockford P1 sub custom siren flowmaster super 44 with turndown rigid duallys on cbi ditch brackets 42" lightbar on All 4 Offroad brackets LED dome light Cobra 19 IV CB Radio w/ PA 3' firestik antenna DeeZee black diamond plate Toolbox 2nd gen badges Tacoma Beast Development (TBD) stickers Beltronics V10 radar detector Ultragauge
    anyone interested in starting another group buy? I'm sure there were a few people who missed the last one
  18. Apr 13, 2014 at 10:14 PM
    #878
    Cykososhull
    Cykososhull Better not bring your kids
    Anthony
    Texas
    03 Tacoma SR5 TRD
    uniden cb, Grey wire, Deck plate, OME 883 coils, Dakar w/D6XL, 4X innovations sliders, tinted windows, debadged, TG low profile bumper, Piaa lights, Allied soft 8s, Bighorn 285,75,16s
    I missed the last one. :mad:
  19. Apr 14, 2014 at 7:55 AM
    #879
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I will sell you mine $50 plus shipping.
  20. Apr 14, 2014 at 9:23 AM
    #880
    cpanther1995
    cpanther1995 Well-Known Member
    Charlotte
    Prerunner TRD Sport
    Interested in the group buy too if it happens again.
Thread Status:
