Ultragauge group buy
Discussion in 'Group Buys' started by Traviste, Jan 24, 2014.
Thread Status:
Not open for further replies.
  1. Jan 26, 2014 at 8:05 AM
    #141
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Alright! Just needed some convincing, haha
  2. Jan 26, 2014 at 8:07 AM
    #142
    tylershane17
    tylershane17 Back to Back World War Champions
    Tyler
    Northwest Alabama
    2007 TRD OFF ROAD DCSB
    Brushguard, Lift.
    There is a list I posted back in one of the pages in the thread that told everything they would show you :D
  3. Jan 26, 2014 at 8:13 AM
    #143
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    UltraGauge EM can display 76+ possible gauges*. Gauge selection is completely customizable. The actually gauges available are vehicle dependent. If your vehicle supports any of the gauges listed, then the gauge will be available for display by UltraGauge.
    UltraGauge currently does not support Manufacturer specific gauges such as Transmission temperature.
    Gauge
    % Engine Load
    Engine Coolant Temperature (ºF)
    Engine Coolant Temperature (ºC)
    Short Term Fuel Trim Bank 1
    Long Term Fuel Trim Bank 1
    Short Term Fuel Trim Bank 2
    Long Term Fuel Trim Bank 2
    Fuel Pressure (PSI)
    Fuel Pressure (kPa)
    Intake Manifold Absolute Pressure (MAP)(PSI)
    Intake Manifold Absolute Pressure (MAP)(kPa)
    RPM
    MPH
    KPH
    Timing Advance
    Intake Air Temperature (ºF)
    Intake Air Temperature (ºC)
    Mass Air Flow Sensor 1 (g/s)
    Absolute Throttle Position 1 %
    Bank 1 0xygen Sensor 1 Voltage
    Bank 1 0xygen Sensor 2 Voltage
    Bank 2 0xygen Sensor 1 Voltage
    Bank 2 0xygen Sensor 2 Voltage
    Run time since last start (hours:mins)
    Miles traveled with Check Engine Light On.
    Kilometers traveled with Check Engine Light On.
    Fuel Pressure (Diesel & Direct Injection) (PSI)
    Fuel Pressure (Diesel & Direct Injection) (10kPa)
    Bank 1 Wide 0xygen Sensor 1 Lambda
    Bank 2 Wide 0xygen Sensor 1 Lambda
    EGR Flow %
    EGR Flow % Error
    Evaporative Purge %
    Fuel Level % of full
    Number of Warm-ups since Check Engine Light Cleared
    Miles traveled since Check Engine Light Cleared
    Kilometers traveled since Check Engine Light Cleared
    Evaporative System (PSI)
    Evaporative System (Pa)
    Barometric Pressure – Inches of Mercury (inHg)
    Barometric Pressure – Inches of Mercury (kPa)
    Catalytic Converter Bank 1 Sensor 1 Temperature (ºF)
    Catalytic Converter Bank 1 Sensor 1 Temperature (ºC)
    Catalytic Converter Bank 2 Sensor 1 Temperature (ºF)
    Catalytic Converter Bank 2 Sensor 1 Temperature (ºC)
    Catalytic Converter Bank 1 Sensor 2 Temperature (ºF)
    Catalytic Converter Bank 1 Sensor 2 Temperature (ºC)
    Catalytic Converter Bank 2 Sensor 2 Temperature (ºF)
    Catalytic Converter Bank 2 Sensor 2 Temperature (ºC)
    Battery Voltage (Measured by ECM)
    UltraGauge Battery Voltage (Measured by UG)
    Load absolute %
    AFR Commanded Ratio
    Relative Throttle Position %
    Outside Ambient Air Temperature (ºF)
    Outside Ambient Air Temperature (ºC)
    Absolute Throttle Position 2 %
    Accelerator Pedal Position 1 %
    Accelerator Pedal Position 2 %
    Command Throttle Position %
    Boost Pressure, (Relative Pressure) (PSI)
    Boost Pressure, (Relative Pressure) (kPa)
    Brake Horsepower 1
    Brake Kilowatts 1
    Torque 1 (ft lbs)
    Torque 1 (N.m)
    Brake Horsepower 2
    Brake Kilowatts 2
    Torque 2 (ft lbs)
    Torque 2 (N.m)
    Mass Air Flow Sensor 2 (g/s)– Calculated
    Instantaneous MPG
    Instantaneous KPL
    Instantaneous L/100Km
    Average MPG – General
    Average KPL – General
    Average L/100Km – General
    Average MPH – General
    Average KPH – General
    Run Time – General
    Miles – General (miles)
    Kilometers – General (miles)
    Fuel Used – General (gallons)
    Fuel Used – General (liters)
    Average Gallons/Hour - General
    Average Liters/Hour - General
    Fuel Level (gallons)
    Fuel Level (liters)
    Instantaneous Gallons/hour
    Instantaneous Liters/hour
    Distance to Empty (miles)
    Distance to Empty (kilometers)
    Time to Empty
    Volumetric Efficiency (MAP vehicles only)
    General Trip Gauges
    Average MPG
    Fuel Used
    Average Gallons/hour
    Average MPH
    Distance (miles)
    Run Time
    Average KPH
    Average KPL
    Average L/100Km
    Liters Used
    Average Liters/Hour
    Distance (kilometers)
    Short Trip Gauges**
    Average MPG
    Fuel Used
    Average MPH
    Distance (miles)
    Run Time
    Average KPH
    Average KPL
    Average L/100Km
    Liters Used
    Average Liters/Hour
  4. Jan 26, 2014 at 8:32 AM
    #144
    Vorra65
    Vorra65 Well-Known Member
    66. Brianr4
    67. heythereuthere[/QUOTE]
    68. MJS
    69. Roadrunner392005
    70. meisme08[/QUOTE]
    71. Vorra65
  5. Jan 26, 2014 at 8:34 AM
    #145
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Heading for 100 in the GB! WOO HOO!
  6. Jan 26, 2014 at 8:41 AM
    #146
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    5100/887, Dakars, 285s, Built Right UCAs, Icon rears
    68. MJS
    71. Vorra65[/QUOTE]
    72. rileySB
  7. Jan 26, 2014 at 8:46 AM
    #147
    Traviste
    Traviste [OP] Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    up to 72!
    Let's get 100
  8. Jan 26, 2014 at 9:02 AM
    #148
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  9. Jan 26, 2014 at 9:19 AM
    #149
    bliznack
    bliznack Well-Known Member
    Jake
    PNW
    '13 2.7l 5-speed 4x4
    73. bliznack
    :thumbsup:
  10. Jan 26, 2014 at 9:23 AM
    #150
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    1.Traviste
    2.tylershane17
    3.coloturfguy
    4.RNGRCaldera
    5.00yotasr5
    6.wheelerkr2
    7.MatthewMay1
    8.Mking
    9.Hritz
    10 ramonortiz55
    11.Mit122
    12.Joshbovaird
    13.Jferrill84
    14.Menj309
    15.Flashcb
    16. mandzach
    17. RiverTaco
    18. Justus
    19. Grimjack
    20. Beaker76
    21. tacoma guy
    22. TACOIII
    23. jqueener
    24. Jiveydude
    25. ultrarnr
    26. Steves104x4
    27. Joeybags
    28. Drakivnsf
    29. Metrick1215
    30. Gerkyn
    31. Ponethousand
    32. duffman825
    33. Geem750
    34. Rbraddock
    35. Salvage
    36. MTopp
    37. BlackTacoma13
    38. Sje1124
    39. Eaglesfn5402
    40. mynewtoy
    41. Spanman702
    42. WisTaco
    43. Northernlights
    44. Tmill
    45. roro
    46. DMart
    47. NoTown98Yota
    48. Nicko
    49. DaVikes
    50. robssol
    51. tacotundra
    52. Xtremewelder
    53. tacoma guy
    54. nj636
    55. will5885
    56. Proyota
    57. devil1
    58. Chim
    59. DownTym
    60. Loco38SUP
    61. Frankakashane
    62. Treaddirt
    63. ozmon420
    64. PCYC
    65. Keywerk
    66. Brianr4
    67. heythereuthere
    68. MJS
    70. meisme08
    71. Vorra65
    72. rileySB
    73. bliznack
    i think i got everybody
  11. Jan 26, 2014 at 10:42 AM
    #151
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Bump.. Hoping to get 100
  12. Jan 26, 2014 at 10:54 AM
    #152
    riverray
    riverray Ready to Roll
    ray
    san antonio, tx
    07 4x4 v6 sr5
    Bilstein 5100's set to 1.75. K&N air filter, aux input solder on stock disk changer, westin running boards, and rain guards.
    Ill take one too. Thanks. :^)
  13. Jan 26, 2014 at 11:02 AM
    #153
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    1.Traviste
    2.tylershane17
    3.coloturfguy
    4.RNGRCaldera
    5.00yotasr5
    6.wheelerkr2
    7.MatthewMay1
    8.Mking
    9.Hritz
    10 ramonortiz55
    11.Mit122
    12.Joshbovaird
    13.Jferrill84
    14.Menj309
    15.Flashcb
    16. mandzach
    17. RiverTaco
    18. Justus
    19. Grimjack
    20. Beaker76
    21. tacoma guy
    22. TACOIII
    23. jqueener
    24. Jiveydude
    25. ultrarnr
    26. Steves104x4
    27. Joeybags
    28. Drakivnsf
    29. Metrick1215
    30. Gerkyn
    31. Ponethousand
    32. duffman825
    33. Geem750
    34. Rbraddock
    35. Salvage
    36. MTopp
    37. BlackTacoma13
    38. Sje1124
    39. Eaglesfn5402
    40. mynewtoy
    41. Spanman702
    42. WisTaco
    43. Northernlights
    44. Tmill
    45. roro
    46. DMart
    47. NoTown98Yota
    48. Nicko
    49. DaVikes
    50. robssol
    51. tacotundra
    52. Xtremewelder
    53. tacoma guy
    54. nj636
    55. will5885
    56. Proyota
    57. devil1
    58. Chim
    59. DownTym
    60. Loco38SUP
    61. Frankakashane
    62. Treaddirt
    63. ozmon420
    64. PCYC
    65. Keywerk
    66. Brianr4
    67. heythereuthere
    68. MJS
    70. meisme08
    71. Vorra65
    72. rileySB
    73. bliznack
    74. riverray
  14. Jan 26, 2014 at 11:03 AM
    #154
    jgillchevy
    jgillchevy Well-Known Member
    Dan
    Clarksville, TN
    2011 DCSB TRD Off Road
    5100s on all corners, front set at .85" w/ Eibach coils TSB rear springs w/ Wheelers offroad 3 leaf aal pack AFE drop in airfilter Weathertech floormats Wetokole seatcovers Tacoma bedmat Maglight install Rear diff breather mod Moroso oil catch can painted black rear bumper HomerTaco color matched satoshi grill BAMF bolt-on sliders URD fuel pump w/ external fuel filter Ultragauge
    Can you please add me to the list
  15. Jan 26, 2014 at 11:30 AM
    #155
    shetltd
    shetltd New Member
    Colorado
    06 PR5 TRD Off Road
    Please sign me up!
  16. Jan 26, 2014 at 11:37 AM
    #156
    tkbolts21
    tkbolts21 Member
    TK
    TRD Sport
    Please sign me up as well.
  17. Jan 26, 2014 at 11:47 AM
    #157
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Sign me up!
  18. Jan 26, 2014 at 11:53 AM
    #158
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
    75. Heavylifter
  19. Jan 26, 2014 at 12:14 PM
    #159
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    1.Traviste
    2.tylershane17
    3.coloturfguy
    4.RNGRCaldera
    5.00yotasr5
    6.wheelerkr2
    7.MatthewMay1
    8.Mking
    9.Hritz
    10 ramonortiz55
    11.Mit122
    12.Joshbovaird
    13.Jferrill84
    14.Menj309
    15.Flashcb
    16. mandzach
    17. RiverTaco
    18. Justus
    19. Grimjack
    20. Beaker76
    21. tacoma guy
    22. TACOIII
    23. jqueener
    24. Jiveydude
    25. ultrarnr
    26. Steves104x4
    27. Joeybags
    28. Drakivnsf
    29. Metrick1215
    30. Gerkyn
    31. Ponethousand
    32. duffman825
    33. Geem750
    34. Rbraddock
    35. Salvage
    36. MTopp
    37. BlackTacoma13
    38. Sje1124
    39. Eaglesfn5402
    40. mynewtoy
    41. Spanman702
    42. WisTaco
    43. Northernlights
    44. Tmill
    45. roro
    46. DMart
    47. NoTown98Yota
    48. Nicko
    49. DaVikes
    50. robssol
    51. tacotundra
    52. Xtremewelder
    53. tacoma guy
    54. nj636
    55. will5885
    56. Proyota
    57. devil1
    58. Chim
    59. DownTym
    60. Loco38SUP
    61. Frankakashane
    62. Treaddirt
    63. ozmon420
    64. PCYC
    65. Keywerk
    66. Brianr4
    67. heythereuthere
    68. MJS
    70. meisme08
    71. Vorra65
    72. rileySB
    73. bliznack
    74. riverray
    75. Heavylifter
    76. jgillchevy
    77. shetled
    78. tkbolts21
    79. gnyla
  20. Jan 26, 2014 at 1:06 PM
    #160
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Come on 100!
Thread Status:
