UltraGauge LED Swap
Discussion in 'Technical Chat' started by babyboi2284, Oct 26, 2011.
  1. Oct 26, 2011 at 1:43 PM
    babyboi2284
    babyboi2284 [OP] Well-Known Member
    Brian
    Lockport, Louisiana
    09 Barcelona Red X-Runner
    LS 6k projectors w/ white halos, 6k fogs, T-Rex Angry Lids, NST SSK, Coupe Shift Knob, BHLM, LFM, DLM, FLM, JL 500/1 amp, JL 10"w6v2, subX wanna be made by me, Magnaflow muffler, 5% tint, k&n drop in filter, Craven Speed Stubby, map light mod
    Ive had quite a few ppl asking me about how i swapped my UG leds from white to red and what type did i use. First off I personally didn't do the led swap I had a friend who does electronic repair do it for me. I was going to do it until i saw how tiny the leds are. If you have swapped the leds in your gauge cluster then those leds are twice the size of the ones in the UG....they are TINY!!! My friend said be very careful taking it apart, the little board that has the leds on it has to be unsoldered from the main board and be patient when soldering. The led type is smt 0806 and I think there are 5 LEDs total. To open the UG case you just pry the case open. You may break some of the tabs but it's hard not to because they are very thin. I think two of mine broke and I just super glued the case back together. If you do use super glue make sure to barely squeeze it on the edge of the case...if you put alot it may run and get on something you don't want it to like the LCD screen.
  2. Oct 26, 2011 at 2:18 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    He is one of the members that asked me the info about the led swap lol
  3. Oct 26, 2011 at 2:30 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Could you throw a pic up of the color change? I didn't know anyone had done this!!
  4. Oct 26, 2011 at 2:45 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    Before
    After
    And this is how I have it mounted. The metal strap runs over the headliner and is self-tap screwed into the part that the overhead console mounts to.
  5. Oct 26, 2011 at 2:48 PM
    Pugga
    Massachusetts
    F-150 Mod
    That looks great! :thumbsup:
  6. Oct 26, 2011 at 3:00 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Looks good, whoever tackles this next should to a write-up :D I just got mine couple days ago, I must say its smaller than i thought hah. I got the new EM version. Still got to customize the display options and calibrate...
    Oh and whoever needs a new case if cracked/dropped its only $6 on their site.
    http://ultra-gauge.com/ZC/index.php?main_page=index&cPath=3&zenid=12povh9scbm2qebib5lppr6sh0
    I was thinking the same spot to mount mine! The drivers side looked better but the wire comes out on that side so it looks more clean as you have it. Any clearer pics of the strap/mounting you mention?
  7. Oct 26, 2011 at 4:43 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    The end of the strap above the overhead console is folded over the self rapping screw...i guess for a cleaner look even though you dont see it anyway lol. The second pic shows the piece that the UG clips to with 3m double sided tape connecting it to the metal strap.
  8. Oct 26, 2011 at 6:43 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Sweet, hopefully I'll be doing this next, would any of these work?
    http://www.oznium.com/leds
    I'm having a hard time finding 0805s
  9. Oct 26, 2011 at 6:48 PM
    Pugga
    Massachusetts
    F-150 Mod
    FWIW, you can make it mount to that spot with the suction cup thing they provide with the Ultragauge. Put the suction cup behind the rear view mirror and then bend the stalk to make it sit above the rear view. That's actually how I have mine set up.
  10. Oct 26, 2011 at 7:10 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    I probably would have used the suction cup but I have a tint strip on my windshield and have had the tint get discolored from my radar detector being on it over time
  11. Nov 19, 2011 at 2:10 PM
    Drunknsloth
    Retribution
    South West
  12. Jan 31, 2012 at 10:55 AM
    Drunknsloth
    Retribution
    South West
    I still can't find any smt 0806 LEDs. Has anyone else attempted this? Any other LEDs we can use?
