UltraGauge Qs
Discussion in '4 Cylinder' started by Poe, Mar 26, 2014.
  1. Mar 26, 2014 at 7:00 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    I have 3 questions about the ultra gauge.
    1. How hard is it to hook up? I would want to put it by my rear view mirror but i dont want wires running every where
    2. Which one do i get? there are 3 different models
    http://www.ultra-gauge.com/ZC/
    3. What all information does it tell you exactly? Is it worth the money
    Is the scangauge better and worth the extra money?
  2. Mar 26, 2014 at 8:18 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    bump
  3. Mar 27, 2014 at 7:33 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    Their website has most of these answers... but
    1. No it plugs right in to OBDII. Wires can be ran around the windshield... but personally I have my gauge mounted near the steering wheel with the cord running behind the panels to the OBD port
  4. Mar 27, 2014 at 8:13 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    ok thanks, pretty sure im gonna order one asap. how long does it take to hook up
  5. Mar 28, 2014 at 7:22 AM
    Speck
    Tejas
    07 2.7 4x4
    As long as it takes you to plug something into a wall socket, so about 2 to 3 seconds.
  6. Mar 28, 2014 at 1:18 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Mine's up above the rear view mirror. Bolted to it actually with a u-clamp from the hardware store because I got sick of my 3-year-old suction cup falling off.
    The wire is just tucked into the front of the headliner, down the pillar lower edge inside the door rubber, and right down to the OBDII port. Just make sure you plug it in and run the wire from there first because just to the left of center above the mirror is all it'll reach.
    I'd say just the basic EM 1.2 is all most people would need. It has many more features than my old v.1.1, like up to 8 gauges at a time vs 6 on mine, or short term tripmeters.
    Scangauge II is a nice product; it's more customizable, i.e. screen color and the ability to use manufacturer-specific readouts through xgauge (auto tranny temp for one), and the cable is detachable from the device. It's easier to hide too. Basically its only downsides are the screen resolution (only 4 gauges at once) and the price.
  7. Mar 28, 2014 at 1:24 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I have the windshield suction cup mount. Ran wires down behind door insulation (very easy), plugs right into labeled OBDII port under dash, takes about 2 minutes to install everything. I want to say there's only two things that the SG monitors that the UG doesn't. (something to do with the battery and transmission temp maybe?)
    Since I took this picture I've changed the order of the things I have on the main screen...now have speed and engine temp on two top boxes, then HP and torque on lower left, then average and instant MPG in lower right.
  8. Mar 28, 2014 at 7:27 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Thanks guys. well im gonna order one this week!
