UltraGauge - Quick Setup, Codes & INFO
Discussion in 'Technical Chat' started by Trail Cat, Sep 19, 2014.
  1. Oct 18, 2014 at 11:42 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Thanks Tan but i effectively need a larger sample. My readings has changed and they are day and night so would like to compare.
    Anybody?
  2. Oct 20, 2014 at 5:36 AM
    Vassily28
    Ok I found the answer. I've fucked up my OT-1 channels configurations so the absolute load was display trough my MAF reading. In fact the range should be something between 4 and 320 g/s at 5 600 rpm.
  3. Nov 9, 2014 at 10:09 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i have my UG setup and the avg mpg is usually bout 1mpg off
    miles are right and everything else what im i doing wrong?
    10 taco with a sc. 21 gallon tank right? maybe thats why?
  4. Nov 9, 2014 at 10:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    21.1 tank size, I think. Are you inputting your fill ups correctly?
  5. Nov 9, 2014 at 11:31 AM
    Blacktaco2042
    wisconsin
    yea i think so
  6. Nov 9, 2014 at 11:48 AM
    Chicane
    Chicane Well-Known Member
    So Cal(Huntington Beach)
    14 DCSB TRD Sport
    Mine is also about 1 mpg off according to Fuelly. My speedometer is also about
    1-1.5 mph below where my needle is at. Then again, with the needle at zero, it sits just above the zero line.
  7. Nov 9, 2014 at 2:02 PM
    Blacktaco2042
    wisconsin
    yea im not to worried bout just wondering if its normal
    and if i can get it closer
  8. Nov 9, 2014 at 3:26 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    My MPG readings are rarely exact, usually less than 1mpg off. Its good enough.
  9. Nov 9, 2014 at 7:18 PM
    Blacktaco2042
    wisconsin
    yea mine is bout 1 off +or-. i have a supercharged i dont think that will affect it much
