UltraGauge Trans Temp Codes for 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma04, Dec 28, 2017.
  1. Aug 23, 2019 at 7:01 AM
    #41
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Oh well, thank you anyway. If I ever find out, I will post it here. Which gauges are you displaying on yours?
    Soul Surfer likes this.
  2. Aug 23, 2019 at 7:48 AM
    #42
    tacoma04
    tacoma04 [OP] Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I have the six panel screen: instant MPG, engine temp, trans pan temp, torque convertor temp, % engine load, and relative throttle %. I like to keep an eye on temps. I also go to Colorado and have also played with the gears in S to see the effect on engine load and relative throttle. Sometimes this trans wants to hold too high a gear in the mountains and when I down shift the relative throttle % goes down yet I maintain speed or gain speed even. It runs a lot better in the lower gear.
  3. Aug 23, 2019 at 9:22 AM
    #43
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    The codes posted in this thread worked for my 2017 (thanks) but don't work for my 2019 4 cyl. Anyone have the codes or tricks for the 4 cyl auto?
  4. Aug 23, 2019 at 9:44 AM
    #44
    tacoma04
    Bruce
    Tennessee
    I can't help you there, but contact UG customer service and ask them about it. They were very good when I contacted them about my 17 and the trans codes.
    ancient11[QUOTED] likes this.
  5. Aug 24, 2019 at 11:47 AM
    #45
    OnHartung'sRoad
    Found an easy and inexpensive way to mount mine. Keeping it away from the windshield stopped those irritating UG overheat warning beeps whenever the sun was shining on it.
    EDIT: note that the gum adhesive strip does not tolerate heat well after all, so I am trying to hang the hook with foam tape adhesive instead.
    Update: foam adhesive works well so far in 100-degree outside temps (see pics for update). Lightly sand to rough up the back of the hook, the tape will stick to it more securely. Also clean the mounting area on the dash and back of the hook with alcohol before using the tape.
    tacoma04[OP] and ancient11 like this.
  6. Aug 24, 2019 at 11:54 AM
    #46
    OnHartung'sRoad
    Thanks! I will definitely replace my mileage reminders for engine load and relative throttle %. I also like having voltage in order to be able to monitor the alternator output as well as our main battery when we are camping.
    nftyper and tacoma04[QUOTED][OP] like this.
  7. Aug 24, 2019 at 6:42 PM
    #47
    tacoma04
    Bruce
    Tennessee
    That's a great idea. Certainly don't want a dead battery in that situation.
  8. Aug 25, 2019 at 8:33 AM
    #48
    tacoma04
    Bruce
    Tennessee
    Let us know how the foam tape works once you have some time to check it out. I'm interested.
  9. Aug 25, 2019 at 1:57 PM
    #49
    OnHartung'sRoad
    Updated- foam tape works (see pics above)
    tacoma04[QUOTED][OP] likes this.
  10. Aug 25, 2019 at 6:38 PM
    #50
    tacoma04
    Bruce
    Tennessee
    That's great! Nice clean install with the foam tape.
  11. Aug 25, 2019 at 11:03 PM
    #51
    OnHartung'sRoad
    Hey- lightly sand the back of the hook to give the tape more bite, the hard plastic on it is rather shiny. My gauge stayed up with full sun at over 104 today, so far so good.
  12. Aug 26, 2019 at 8:32 AM
    #52
    tacoma04
    Bruce
    Tennessee
    Thanks for the tip. Wow, 104!
  13. Aug 26, 2019 at 8:47 AM
    #53
    OnHartung'sRoad
    It had to be much over that in the truck with the windows closed, too. Test closed, works well.
  14. Sep 8, 2019 at 9:00 AM
    #54
    ancient11
    robert
    tallahassee
    2019 4 cyl srsx ac
    Ended up using codes for 2nd gen, out of desperation, and they worked20190908_111236.jpg
    tacoma04[OP] likes this.
  15. Sep 8, 2019 at 3:02 PM
    #55
    tacoma04
    Bruce
    Tennessee
    That's great that you got it working! Thanks for letting us know. Hopefully other 4cyl guys will find this helpful.
  16. Sep 8, 2019 at 3:04 PM
    #56
    tacoma04
    Bruce
    Tennessee
    @ancient11 Did you get the codes from the Ultraguage site? Can you post them here for others to use?
  17. Sep 8, 2019 at 3:30 PM
    #57
    ancient11
    robert
    tallahassee
    2019 4 cyl srsx ac
    UG site wanted a ticket # and I didn't have one. These are some for 2nd gen, 4 cly. They are on the TW site too.
  18. Sep 8, 2019 at 3:31 PM
    #58
    ancient11
    robert
    tallahassee
    2019 4 cyl srsx ac
    These worked for 3rd gen, 4 cyl
  19. Sep 8, 2019 at 3:37 PM
    #59
    tacoma04
    Bruce
    Tennessee
    :thumbsup:
  20. Feb 23, 2021 at 1:57 PM
    #60
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    tacoma04 thank you for sharing this. I've entered these values but now am not sure how to have these show on my gauge. I went to the first page and tried selecting these gauges but don't see them anywhere. Do I need to go into a different folder option? Thank you in advance!
