Ultragauge transmission temp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MyMistress, Mar 2, 2014.
  1. Apr 5, 2015 at 2:54 AM
    #401
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    I was thinking about getting a ultra guage, but don't know if I should get the MX 1.3 or the EM plus. I have a 2014 regular cab 2wd manual transmission. Any benefits to go with the MX 1.3? I am threading a lot of the posts, but can't find the information to get definitive answer...appreciate an explanation.
  2. Apr 5, 2015 at 4:39 AM
    #402
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Here's what I think, hopefully someone else chimes in:
    MX 1.3 - better for a truck with the auto transmission, as the trans temp reading and torque converted lock and most of the other special gauges only work with an auto. Your manual, from what I've been told, will have lower trans temps than an automatic, which uses the fluid more as a hydraulic.
    EM plus - better off getting this one I think because it has all the engine temps and mpgs and such PLUS it has like "performance" stuff like 0-60mph times and fun stuff like that
  3. Apr 13, 2015 at 8:22 PM
    #403
    imom
    CAL
    2014 Regular Cab
    Thanks for the feedback
  4. Apr 14, 2015 at 5:38 PM
    #404
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    Is there a way to get the mx to read the fuel level instead of having to input the gallons pumped?
  5. Apr 14, 2015 at 6:34 PM
    #405
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    not as of now
  6. Apr 14, 2015 at 6:39 PM
    #406
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Now that would be ideal!!!
  7. Apr 29, 2015 at 6:05 PM
    #407
    Tbryson2
    Tbryson2 Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    Just towed my Sportsmen 14RB from central Florida to lower Kentucky. Transmission temps were a low of 180 to a high of 225 when going up the mountain. Average was about 190.
  8. Apr 29, 2015 at 6:20 PM
    #408
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you have the tow package? 225 is a little high for comfort. I also wonder if its reading the torque converter output temp (which is over inflated) vs the much more desirable pan temp.
  9. May 2, 2015 at 7:52 PM
    #409
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    Yes I do. Again, that was only while we were going up the steepest part of the mountain. Always left the tranny in 4th gear (5 spd automatic). Trailer gross weight is (approx) 3500lbs or so.
  10. May 3, 2015 at 8:22 AM
    #410
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    According to my UG, I was hitting tranny temps right at 200-205 F* last Friday driving down the highway with ambient temps around 58* F. I never saw those temps before and it doesn't make sense that they would get that high under those conditions. No trailer, just truck. Never saw those temps before.
    I'm beginning to not trust this gauge.
  11. May 3, 2015 at 9:52 AM
    #411
    nd4spdbh
    SoCal
    Yeah no way you were at those temps cruising unless you were in 5th unlocked the entire time.
  12. May 6, 2015 at 7:45 AM
    #412
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    So i have tried to read as much of this thread as possible and would like some direction as;
    1. non of the UG come pre-programmed for a 12-15 taco? so do i just bypass that option at checkout?
    2. which is better for my setup; 13 taco with SC (i plan on getting an AFR / Boost gauge down the line but UG seems like a decent option for now)
    3. how hard is it to input the codes / how does one do so?
    4. thanks all and yes i read and searched, perhaps i missed a sticky with this info? if not maybe it can be added to the OP #1 of this thread
  13. May 6, 2015 at 8:07 AM
    #413
    Jefes Taco
    Denver, CO
    I have a SC and I bought the UG for it's tranny temp readings.
    1. Order the M Gauge. It's the "pro" model that's programmable.
    2. Skip the UG and get the Scangauge and AFR/boost gauge. Or none at all. You really don't need any of it unless you start modifying the SC/boost.
    3. Not hard at all. It's in the options menu under M Gauges.
    The more I have the UG the more I'm NOT impressed. It seem to me that it's slow to respond like there's a delay between what's happening real time and when it's reported by the UG.
  14. May 6, 2015 at 8:32 AM
    #414
    Jefes Taco
    Denver, CO
    I changed the refresh rate to 1 second I believe and turned off nearly all alarms.
  15. Jun 22, 2015 at 11:55 AM
    #415
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    Just towed a longer distance for the first time since getting the MX1.3 upgrade.
    Below is a graph of the one-way elevation profile of the trip.
    My avatar is a photo of the load towed, of which the trailer is roughly 3000lbs.
    Outside temps were 85-95°F, depending on elevation.
    Kept her in 4th gear (Auto-trans w/tow package) except on very steep declines where I could let the engine rest a bit. On some of the steepest climbs I dropped it into third.
    Engine temps never exceeded 210°F. RPM was usually around 2700 (in 4th) running between 60-65MPH.
    On the way out, tranny temps climbed from 160°F to 180°F at the bottom of the hill, and then spiked around 225°F at the last hill before the end. On the way back temps were pretty much at 200 +/- 10°F the whole time.
    The temps went up, of course, when the torque converter engaged, but they never seemed to drop back as low as they were before it engaged. I am now wondering where the reading is being taken.
    I am also wondering how well aux trans-cooler works. In theory, shouldn't the tranny fluid be the same temp (or cooler) as the coolant as it enters the transmission? My tranny temps exceeded my engine temps more than a few times.
    My truck has 93K miles and I had the tranny fluid swapped at 80K. I'm thinking I might want to do it again soon if these temps keep up. Any other tips on keeping the temps down, while towing or otherwise? And can anyone point me to a good resource that explains how the fluid moves in the tranny at different points during the driving cycle?
    Jeff in Flagstaff
  16. Jun 22, 2015 at 1:40 PM
    #416
    nd4spdbh
    SoCal
    It would be interesting to see the same readouts on say my torque pro app with torque converter output temp and pan temp. compared to the Ultragauge.
    With something like this http://www.amazon.com/dp/B000TMCX72
    with your ultragauge and my ELM 327 hooked up.
  17. Jul 21, 2015 at 5:25 AM
    #417
    UoD
    UoD Well-Known Member
    Charleston, SC
    2015 Tacoma TRD Sport DCSB 4x4
    N-Fab 3" Main Tube Textured Nerf Bars (T0580CC-TX), Toyota OEM Bed Extender, Swapped Entune Plus for Entune w/ Nav, Undercover SE Tonneau, TRD Pro wheels, Falken Wildpeak AT3W's (265/70/17)
    Reading through the last few pages of this post to get codes for trans temp on a 2015. I see that the output format was listed as 10 in the newer posts, but was listed as 00 in the older posts.
    Which is correct? 10 for the output format causes my UG to display about 221 degrees right when I start the truck up. When I change the output format to 00, it displays around 110 degrees. The latter sounds more correct at startup.
  18. Jul 21, 2015 at 7:09 AM
    #418
    Yamaha_TacoR1
    Yamaha_TacoR1 Very slow racer
    NJ/NY, USA
    2015 Black TRD Sport 4x4 Limo
    - 5100/885's, 5100/Icon 3leaf progressive AAL with overload left in, 1/4" Taco lean spacer - ARE Z Series camper shell with Yakima rack system - Tepui Ayer Rooftop Tent - Prinsu Design Cabrac with heavy duty anadized bars - WeatherTech window deflectors/floor liners/bug deflector - Ultragauge MX1.3 - PopnLock codable locking tailgate handle - TRD shift knob - 3M tint - Extang solid fold2.0 tonneu cover - OEM Tacoma muffler tip - OEM Tacoma side steps - OEM Tacoma bed mat - OEM Tacoma roof rack - OEM TRD PRO front grille in matte black - OEM TRD PRO headlights - Fastway FLASH "Solid-Tow" adjustable aluminum ball mount hitch - Reese dual hitch ball covers - Masterlock locking J pin - GoPro windshield mount - Door trim protectors - Side mirror 'fish eyes' - Thule T2 hitch mount 2 bike carrier - LEDs: Map/Dome, 3rd brake, license plate, parking lights, reverse CREE's - SEMA TRD PRO 17" black matte wheels - 265/70/17 BFG A/T KO2s - Black Widow 40" x 95" 3 piece powder-coated folding bed ramp - Mobtown Offroad ribbed tailgate reinforcement skin - GRIDiT center console organizer - Salex center console organizer - Marco Extreme Blast black premium train air horn - 'ImmrYo' Rearview mirror relocate bracket - Mattgecko's Sliding window security bar - Rigid tow rear hitch shackle - Plasti-dipped gunmetal emblems - Blacked out ACEkraut's front license plate relocate bracket - De-flapped (OEM mud flaps gone) - Uniden XL520 CB Radio - Shmellmopwho's CB antenna bed mount - 3ft Firestik II CB antenna - BirdDawg Industries Tech Deck Extreme version w/ 3 Ram 1" ball mounts - Ram Mounts: iPhone6/iPad Mini4 X Grips with 1" dual ball sockets - Garmin GLO portable GPS & GLONASS receiver - Depo LED tail lights with blacked-out inner housing - Various Velcro backed patches on the headliner - 3D-Cell LED Maglite mounted to the driver seat - 4XInnovation DOM weld on sliders with kickouts (welded at 20degree angle) - 4XInnovation Hi Lift bed mounting system - Hi Lift All cast 60" jack with optional handle holder - Lotus Development Hi Lift slider adapter - Relentless Fabrifacfions dual bed rail mounts with dual Quick Fists - Salex glovebox organizer system - YETI vintage bottle opener mounted to the bed - TRD Sport style aftermarket epoxy resin decals for WT front mats - Rigid Industries LED D2 spot lights (Midnight edition) - CBI spot light hood mounts - Air on Board "Zombie Lights" switch - Rebadged WeatherTech floor liners with custom TRD Sport emblems - GoPro Hero 3+ windshield mounted - Mattgecko's cool white LED bedlight kit v2 - 1.25" Spidertrax wheel spacers - Maxsa Escaper Buddy traction boards (mounted on top of Prinsu Cabrac) - 42" Plano Weatherproof gun case (mounted on top of Prinsu Cabrac) - 2gal Rotopax gasoline can, mounting plate, DLX pack mount (mounted on top of Prinsu Cabrac) - Bestek 150W power inverter DC 12V to 110 V - DBPower 600A car jump starter/booster - SOS Off-road Concepts Factory recovery replacement mount - ARB 30' Recovery strap - ARB EZDeflator - Smittybilt receiver hitch D ring with 3/3" shackle - Bosch Icon wiper blades - RCI IFS steel skid plate - Trasharoo trash bag - mounted on tailgate - Lamin X yellow fog lamp covers - Aftermarket illuminated air conditioning/heater/vent knobs - Toyota full frame replacement - Spring 2023 ================================ Future mods: - Rear diff breather relocate - Foglights anytime - Install external speaker for CB - Install mattgecko bedlight kit
    If I recall correctly, when programming my UG for Tran temp, 00 was for Fahrenheit and 10 was for Celsius display or vise versa...don't remember exactly
  19. Jul 21, 2015 at 8:19 AM
    #419
    UoD
    Charleston, SC
    So -- if that is the case ... and, knowing that C would always be a lower number than F, there seems to be a problem with the readout.
    At 10, I get a value that seems to read in C .... but it is way too high to be the trans temp on a vehicle that was just started up after having sat in a garage for 12 hours.
    At 00, I get a more reasonable value. The problem is that this value seems to actually be C, not F. Converting this value from Celsius to Fahrenheit seems to get me the values I see at output formats 00 and 10, respectively.
    Anyone have any idea what is going on here? I'd triple-checked that everything matches as listed in the previous posts.
  20. Jul 21, 2015 at 8:37 AM
    #420
    Yamaha_TacoR1
    NJ/NY, USA
    Strange. I would shoot a email to UG support with your concern.
