Ultragauge transmission temp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MyMistress, Mar 2, 2014.
  1. May 6, 2016 at 11:14 AM
    #521
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    Cool, thanks! I have the ELM bluetooth adapter but it's not really doing it for me - I think a dedicated wired-in device is the way to go.
  2. Jul 8, 2016 at 5:11 PM
    #522
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    slight revival...
    I have the EM Plus 1.2
    after actually using my eng temp reading while O/R in AL in the dead of summer and my buddies were hitting 250s *F (eng temp), I now want to add the trans temp also to it. I see the code posted on the OP, but dont know how to get tot his page to input all the data----->
    How to I get to this screen? Does anyone mind takin a second to spell out what menu items I select to get there?
    (I have a 2011 TRD Sport with tow package 4wd, if any of that matters also).
    Thanks in advance! (I did google this and didnt even see it populate for TW, but im sure its here somewhere)
  3. Jul 28, 2016 at 1:27 PM
    #523
    Dozer
    Dozer Well-Known Member
    Colorado
    13 TRD Off Road
    Another revival - can't seem to find a clear answer in any of the other threads.
    Does the manual transmission have a transmission temperature sensor?
    I'm trying to decided between the EM Plus (no trans temp) and the MX 1.3 (with trans temp). I don't want to buy the MX 1.3 if there is no temperature sensor on my manual transmission anyway.
  4. Jul 31, 2016 at 6:21 PM
    #524
    vrun22
    vrun22 Member
    Las Vegas, Nevada
    08' Toyota Tacoma TRD Off Road
    To save you the time I already went through this thread and several other threads and it does not support manual transmissions. See the quote from another user in the thread. With that said go with the EM Plus.
    Dozer[QUOTED] likes this.
  5. Aug 1, 2016 at 10:25 AM
    #525
    Dozer
    Colorado
    13 TRD Off Road
    Exactly what I was looking for - I skimmed this thread but must have missed that explanation. Thanks @vrun22 and @Jefes Taco!
  6. Aug 1, 2016 at 3:43 PM
    #526
    Skootter14
    Jeremy
    Blasphemy!
    thanks. I have yet to try it...but now I dont have to haha. oh well.
  7. Aug 30, 2016 at 8:24 PM
    #527
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I haven't had time to read through the whole thread, but I have a couple of questions. Has anyone found out for sure if you can get the UG to read both TC and pan temps? If the UG is only reading one of the two, which one is it reading?
    Also, I was gonna order the MX 1.3, but noticed that they have the Blue, now. Can the Blue read tranny temps on the Tacos?
  8. Sep 10, 2016 at 2:46 AM
    #528
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I went ahead and ordered an MX 1.3 and after a little research and some experimenting, I now have it displaying the Trans Pan and TC temps for my 2007 Tacoma. The UG as programmed only reads the TC temp. The TC will run a little higher than the Pan temp unless you are cruising down the highway with the TC locked, in which case the two temps will level off and read exactly the same. Cruising down the highway on my way home tonight I was seeing temps of about 133f with the TC locked (ambient temps ~75f) Upon acceleration from stoplights I was seeing temps at the TC of about 150f. I am seeing about a 20-30 degree (f) difference between the pan and tc temps when accelerating. I found the Scangauge II codes on an FJ Cruiser forum and was able to convert the code for the trans pan temperature reading using the instructions given in the box with the UG.
    Now.... I'm sure you're wondering, what's the coding for the pan temp?
    I went to the Mgauge settings and went to Mgauge 4, which is meant to be the trans display for Celsius temps, however the only difference between Mgauge 4 and the Fahrenheit gauge (Mgauge 5) is the output format. For F you need to have the output set to 10, and for C you set the output to 00. Go ahead and set the Mgauge 4 output to 10. Next, on Mgauge 4, change the RPos from 1810 to 0810. That's all there is to it!
    OPTIONAL: You Can change the name on the gauges to reflect the Pan or TC temp. (See Pics)
    teejnut, eherlihy, Chuy and 4 others like this.
  9. Sep 10, 2016 at 3:03 AM
    #529
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Nice write up. Can you explain how the TC Lck up 1
    Gauge works? Thanks.
    07 sport 4x4[QUOTED] likes this.
  10. Sep 10, 2016 at 3:32 AM
    #530
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    It displays a "0" when the torque converter is unlocked and a "1" when the TC is locked.
    Soul Surfer[QUOTED] likes this.
  11. Sep 10, 2016 at 5:33 AM
    #531
    Soul Surfer
    Jimi
    Very good! Thanks.
  12. Sep 10, 2016 at 8:02 AM
    #532
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Is the MX1.3 the only one that will access transmission temps or will the Blue adapter also do that?
    Soul Surfer likes this.
  13. Sep 10, 2016 at 7:01 PM
    #533
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I believe the Blue will read trans temps as well. I decided to get the mx so I wouldn't have to have an extra phone or use my primary cell to view parameters. I like to keep an eye on things as I'm driving so I chose the mx. I did think about turning my old iPhone into a gauge though, I like that you can update the Blue without sending it back in.
    tacoma04[QUOTED] and Soul Surfer like this.
  14. Sep 10, 2016 at 7:08 PM
    #534
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I'll just leave this here for anyone that wants the Pan and TC temps for their 12-15 Tacoma (may work for earlier years, not sure when the coding changed). Myself and @JD'STaco got these codes to work on his 2014. If you want the codes for the older Tacos you can see my post on the last page. (Post #557)image.jpg
    Murphinator and Soul Surfer like this.
  15. Sep 10, 2016 at 7:18 PM
    #535
    Soul Surfer
    Jimi
    Thanks again for pan codes Sir! :thumbsup: I'm light years behind with this Tech stuff!! Lol!
  16. Sep 10, 2016 at 7:20 PM
    #536
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    So I can display both the trans pan.and tc (is this torque conv.)? Temps?
  17. Sep 10, 2016 at 7:39 PM
    #537
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    That's correct!
    IronPeak[QUOTED] likes this.
  18. Sep 10, 2016 at 7:42 PM
    #538
    IronPeak
    AuggieX
    Back to Back
    I should have asked in.my original post, but why is this important, and should I use up one of my coveted front page positions to display this info(both pan and tc)?
  19. Sep 10, 2016 at 7:46 PM
    #539
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    You're welcome man! I'm glad I could help.
  20. Sep 10, 2016 at 7:51 PM
    #540
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    It's mostly only important if you tow or drive in heavy traffic with lots of stop and go driving. You want to keep the transmission at an acceptable temperature to ensure that it lasts as long as possible. If you are don't want to take up two spots on the main page, I suggest displaying the torque converter temp, it will be the hottest point in the transmission, and when you are cruising on the highway with the torque converter locked up, the TC reading will be about the same as the pan temp if not exactly the same. When the torque converter is unlocked it produces tremendous amounts of heat, especially under heavy acceleration or if you're towing a heavy load.
