Ultragauge: what are you favorite gauges to use?
Discussion in 'Performance and Tuning' started by thairannosaurus, Apr 1, 2013.
  1. Apr 1, 2013 at 8:26 PM
    thairannosaurus
    thairannosaurus [OP] Well-Known Member
    Anthony
    Texas
    18 TRD Pro
    AC drain mod, interior lights, tonneau cover, avid light bar, N2 remote start, power tailgate lock
    Just received my brand new ultragauge, had it for all of... let's see... 12 hours now :D and I love it but the amount of gauges can be pretty overwhelming. For all you guys that have had yours for a while: what are your favorite gauges (the ones that made it to your page 1) and were there any gauges that you never thought of using in the first place but ended up finding them to be super useful? So far all I have is instant MPG, avg MPG, battery volt, throttle position, air intake temp and avg rpm. definitely not what I plan on sticking with but thats all I saw that caught my eye in the 5 minutes I was tinkering around with it.
  2. Apr 9, 2013 at 8:24 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    What I have my gauge set at ! Thinking about switching some stuff like the instant mpg
  3. Feb 2, 2015 at 9:34 PM
    Tacoman503
    Tacoman503 Well-Known Member
    Just got my new Ultragauge MX 1.3 in the mail so I thought that I would BUMP this thread instead of starting a new one. Haven't installed my UG yet but some things I want displayed are:
    RPM, MPH, instant MPG, avg MPG, inside/outside air temps, coolant temp, oil temp, voltage, distance to empty.
    What other gauges are you guys finding useful?
  4. Feb 3, 2015 at 5:17 AM
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    I need help, I just had my alternator replaced and it took a few days to do and the U/G worked no problem. I checked all my lights and noticed my HID headlights was not working so I had the mechanic check for the problem but he could not find what the problem was. My problem is now my U/G will not work tried unplugging it and plugging it back in with negative results can anyone give me a starting point on what to check any suggestions would be appreciated.
  5. Feb 3, 2015 at 5:39 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Try it on another car. You may have damaged some of the pins on the OBDII port.
  6. Feb 3, 2015 at 2:56 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Intake temp, trans temp, voltage, timing, water temp
  7. Feb 5, 2015 at 11:05 PM
    Yota64
    Yota64 Professional Threadjacker
    How do you monitor trans temp? Which gauge is it?
  8. Feb 5, 2015 at 11:13 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    :goingcrazy: I WANT TRANS TEMP RIGHT MEOW
  9. Feb 6, 2015 at 12:59 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ultragauge mx
  10. Feb 6, 2015 at 12:59 PM
    Yota64
    I mean which you go to select gauges, what is its title?
  11. Feb 6, 2015 at 1:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Kerplunk foes
  12. Feb 7, 2015 at 12:10 PM
    Yota64
  13. Feb 7, 2015 at 12:25 PM
    AR15xAR10
    Pm him. Brock is very busy.
  14. Feb 7, 2015 at 11:27 PM
    Yota64
    Pmd and replied. :)
  15. Feb 8, 2015 at 12:12 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Page #1
    #1 Instaneous MPG
    #2 Water Temprature
    #3 Gallons Remaining
    #4 Short Range Trip Mileage
    #5 Distance To Empty
    #6 Average MPG
    The rest of the pages are monitoring various systems, MAF, TPS, O2, etc.
    Page 6 is all Short range trip, MPG, Time, Miles Driven, Fuel Per Hr, Avg MPH,
  16. Feb 8, 2015 at 1:25 PM
    Yota64
    What is the point of water temp, maf, o2? What would you do if one is too high?
  17. Feb 8, 2015 at 1:48 PM
    Darryle
    Darryle
    Weatherford, Texas
    Diagnosis, it gives you a base line.
    Water temp is a given, keeps you from toasting the motor.
  18. Feb 8, 2015 at 3:44 PM
    Yota64
    But what would you do if your water was reading high? Is it the radiator water? Pull over and add more? get towed?
  19. Feb 8, 2015 at 4:43 PM
    Darryle
    Darryle
    Weatherford, Texas
    As opposed to continuing driving?
    Well, I don't know what you would do, but the first thing I would do is pull over and try and find out why it is high. If I cannot figure it out fairly quickly, then I would let it cool a bit and limp it home or have it towed, depending on where I am.
    I have my alarm set for 195, it has never been over 188 since I installed the gauge.
