Ultraguage?? Anyone used one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bookmonke, Aug 13, 2010.
  1. Aug 30, 2010 at 9:39 PM
    Spire
    Spire Member
    Kenai, AK
    '10 MGM AC Sport
    Got mine in the mail today (ordered Thursday, 2 day to Alaska is UNHEARD of).
    Thing is smaller than I thought .4" thick and maybe 3" wide and 2" tall, very nice. Feels solid, good strain reliefs on cable and high quality ODB II connector.
    Does as advertised and does it well. Updates every second (limited by the comm rate of the ODB II connector I assume).
    My 2010 V6 stick Sport reports 53 gauges available. No fuel sender so you do have to manually reset at fill up.
    The thing just looks great, blue LCD characters on a pure black background and it auto dims (user settable auto or manual) as the ambient light gets lower.
    The included windshield mount is very nice, holds the thing tight and sticks like glue the glass. I have it tucked into the lower drivers side and over the left hand upper vent.
    I have not played with a Scangauge and won't at $200.00+ but this thing is worth every bit of twice its (current) price of ~$60.00.
    Below is a picture of a quick install, I can see custom mounting this either over the Rear view mirror, or ???
    Let me know if you want some specific information...
  2. Aug 30, 2010 at 10:01 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Subscribed!
  3. Aug 30, 2010 at 10:16 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    So are the operating buttons on the bottom?
  4. Aug 30, 2010 at 10:20 PM
    JTanner
    JTanner Misplaced Texan
    Temecula, CA
    09 DC TRD OR MGM
    stock..for now
    How long is the cord (for hiding and trick mounting)?
  5. Aug 30, 2010 at 10:26 PM
    Spire
    Spire Member
    Kenai, AK
    '10 MGM AC Sport
    3 buttons on the back, "enter" on the upper left and "up/down" on right. I think they did this to keep folks from trying to do things with it while driving.
    I found no issue in working the buttons while stopped, but it does limit the stealth mounting options. Although once set up like you want it, the button pushing is not needed much, but you still have to hold the "up" button for 3 seconds every time you fill up.
    The cord is approx 6 feet. Keep in mind that the ODB II connector is above your LEFT knee (not where I am used to finding them) on a Tacoma.
    I "installed" this after work in the parking lot, plugged it in, tucked the cord in the door moulding, put the rest behind the kick panel, and stuck it to the window. Took all of 5 minutes. I do plan on working it into place above the rear view mirror somehow in the near future.
    The sensor for auto dimming is just below center line on the far right side (you can see it in my pic), don't want to cover that up either if you can help it.
  6. Aug 31, 2010 at 4:05 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    :( This makes me feel pretty lame for spending $300 on a PLX DM-100, plus whatever the steering column mount cost. And the PLX only displays 4 parameters at a time.
    Nice find :)
  7. Aug 31, 2010 at 4:20 AM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
  8. Aug 31, 2010 at 6:37 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Definitely like the display, as compared to the SGII, but what appears to be missing is the X-gauge and trip functionality of the SGII. Any sightings of trip or custom gauges on the UG? The size may also be a problem as it limits where you can place it. The UG won't fit well on top of the steering column or in the bin below my single DIN HU (where I have my SGII mounted now).
    I do hope that this causes SG to update the display to something more like this though.
  9. Aug 31, 2010 at 6:45 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    So here are a couple of pics. Just like Spire said, it is worth double the cost and works great. I'm trying to upload a video but can't get it to load up on photobucket, but here are 3 pictures with each one showing the auto default gauges. Oh, and I mounted it right above the rearview mirror for an even more stealth mode. the cable reaches perfectly
  10. Aug 31, 2010 at 6:55 AM
    pinktaco808
    pinktaco808 Hot Steppa
    nope...........
  11. Aug 31, 2010 at 6:56 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    nice Paul... you just convinced me
  12. Aug 31, 2010 at 7:15 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Subbed. May have to pick this up instead of a SG....
  13. Aug 31, 2010 at 7:17 AM
    Paul's TRD
    TX
  14. Aug 31, 2010 at 7:19 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    How did you run the cable if you mounted the UltraGauge on your mirror ?
  15. Aug 31, 2010 at 7:35 AM
    #35
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
  16. Aug 31, 2010 at 7:44 AM
    #36
    Paul's TRD
    TX
    If you look at my last post there is a video of the route i took to get to the OBD connecter, but I'll explain. I used that little plastic pc that covers up the mount on the windshield to the rearview mirror and then ran it up into the headliner it tucks up in there pretty nicely. ONce i made my way to left panel were the handle is, i just again tucked it behind that panel then ran it behind the door seal. It peels off pretty easily and wedges right back on tightly. well once you get down to the lower part you need loosen the lower kick panel to route the cable to the obd connecter and pretty much that's it.
  17. Aug 31, 2010 at 8:05 AM
    #37
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    wow! i was looking into a SC2 but idk i found them for like $180 but $60! all i really want it for is MPGs and my speedo is a little off with 31s and im about to get some 33s and i was wondering will it display the actual speed?
    im subcribing to this and keeping my eye on it
    btw i got a 1st gen so... will it work?
  18. Aug 31, 2010 at 8:14 AM
    #38
    Paul's TRD
    TX
    I have 32" tires and the MPH really didn't seem to be different from what i can tell on the dash. It will work for 1996+ with a OBD II connecter. Here is the link. sometimes it doesn't work, but if you type in the address bar it will work. weird
    WWW.ultra-gauge.com
  19. Aug 31, 2010 at 8:24 AM
    #39
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
  20. Aug 31, 2010 at 8:44 AM
    #40
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    this looks pretty sweet compared to a 180- scangauge
    I wasn't about to buy a scangauge for 180- but i'll sure as hell pick this up for a 1/3rd the price
