un-install and re-install
Discussion in 'Lighting' started by linkfeeney, Feb 27, 2010.
  1. Feb 27, 2010 at 7:50 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    sup people
    I looked in my truck where the headlights bulbs are
    but it doesn't give me any room to pull it out
    got the windshield fluid block one and battery the other side
    anyone have any idea how to un-install them cause I'm going to put HID lights later, ONCE THE NORTHEAST gets back into the SPRING MODE!!!
  2. Feb 27, 2010 at 7:56 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    For HID's I found it easier to take them out, seal them back up properly (especially because the bulbs, wires, etc in them never are the same as the factory) and you have more room to work with. Also makes mounting ballasts much more manageable. Only four screws/bolts hold them in. Two Phillips head on the top, one phillips head screw kind-of half way under the bumper cover, and the 4th is tricky to find at first but not hard (use a ratchet and a 10mm socket) as you must access it from under the truck. Take your time with the last bolt, don't break the mount, and be sure to put it back in when you reassemble everything. Hope this helps.
  3. Feb 27, 2010 at 8:10 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    ^^^ that will make installation the easiest, but take a little longer (not a problem if you have time)
    i installed a set of hids a few nights ago. i took out the battery, and unbolted the two bolts that hold in the washer fluid holder so i could tilt it out of the way. gave me enough room to get everything installed.
  4. Feb 28, 2010 at 6:06 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    so either I have to take out the headlights or take out washer fluid and battery to get this done??!! is it worth it?! ummmm
  5. Feb 28, 2010 at 6:16 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    i was able to install unistall without taking anything apart just little tricky but it wasnt hard
  6. Feb 28, 2010 at 11:57 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    ^^^ yeah, oyu don't have to take anything out, it just mkes it easier. the uninstall and reinstall of the battery and washer fluid was abotu 5 minutes, so i think it was worth it for how much easier it was
  7. Feb 28, 2010 at 12:00 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
