UN-STUCK! NO need help! (On-Road)
Discussion in 'Alabama' started by Key-Rei, Sep 2, 2020.
  1. Sep 2, 2020 at 11:17 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You got the right idea. Move the hi-lift to the drivers slider, use a really big base like you got now (cause that side looks softest), lift, then chock under the wheels with whatever you can find. Reset as needed. Top off with a maxtrax if you got any extra.
    Locker up in 4Lo and start working your way backwards.
    Should be able to start turning the wheel once you get moving too
    mjp2, Bandido, lynyrd3 and 5 others like this.
  2. Sep 2, 2020 at 11:19 AM
    Key-Rei
    Key-Rei [OP] Well-Known Member
    Key
    Florida
    Yeah that's the general plan, unfortunately I can't really get to anything on the drivers side it's nothing but fuck soup as deep as a 34" can dig.
    I even have to get in and out of the passenger side... :anonymous:
    Thatbassguy, lynyrd3, cubie and 2 others like this.
  3. Sep 2, 2020 at 11:21 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    I posted in the Alabama Tacomas and Alabama Overland Facebook groups.
  4. Sep 2, 2020 at 11:24 AM
    eon_blue
    Azusa, CA
    Subbed for result from too far away to be of any use (CA)
    STMaxx are great in every element except for mud, lol. Like most any AT tire really.
  5. Sep 2, 2020 at 11:26 AM
    Key-Rei
    Key
    Florida
    I can tell you they're a lot better than KO2's at least! :D
    Which ultimately just means you can dig yourself down faster... :bananadead:
    Thatbassguy, mjp2, tcjacado and 3 others like this.
  6. Sep 2, 2020 at 11:27 AM
    SR-71A
    Zack
    Southern Maine
    welp..
    Can you hook on the ARB in the front to lift the drivers side, one corner at a time instead of all at once?
  7. Sep 2, 2020 at 11:30 AM
    baldridge
    Bart
    Auburn, AL
    @Key-Rei PM coming your way with a number to call. Hopefully he can help. He responded on FB.
    Thatbassguy, Ghost OTC and Tacotj like this.
  8. Sep 2, 2020 at 11:31 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I've got to work tonight, so the only help I can offer is a bump. I can say guys are trying. I got a call from @baldridge asking if I could go.
  9. Sep 2, 2020 at 11:32 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I'm wondering if you can use the hi-lift like a hand winch since you have straps with you.
  10. Sep 2, 2020 at 11:32 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I’m in Birmingham and don’t get off work until 5 today. I’m guessing you’re about 1.5-2 hrs from me. I’ll keep a lookout on this thread to see how your progress is going. I’d jack up on all the sides you can and shove everything under the tires that you can. If you aren’t out by then, I’ll see what I can do.
  11. Sep 2, 2020 at 11:33 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Great idea!
    tcjacado and wilcam47 like this.
  12. Sep 2, 2020 at 11:34 AM
    baldridge
    Bart
    Auburn, AL
    @Key-Rei the guy I PMed you his info said he was close to your location.
  13. Sep 2, 2020 at 11:35 AM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Can a 3/4 ton diesel get to you?
    wilcam47 and cubie like this.
  14. Sep 2, 2020 at 11:35 AM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
  15. Sep 2, 2020 at 11:36 AM
    #35
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Who is going out there? You, Phil, and Murph are out that way right?
  16. Sep 2, 2020 at 11:36 AM
    #36
    lynyrd3
    Bill
    East Central Upstate NY
  17. Sep 2, 2020 at 11:36 AM
    #37
    eon_blue
    Azusa, CA
    That is true, I had KO2s before STmaxx and the Coopers are superior in every way. Last way longer too without chunking up on the rocks like the BFGs love to do
    lynyrd3 likes this.
  18. Sep 2, 2020 at 11:36 AM
    #38
    baldridge
    Bart
    Auburn, AL
    No. I’m about 1.2 hours away.
    wilcam47, lynyrd3 and cubie[QUOTED] like this.
  19. Sep 2, 2020 at 11:37 AM
    #39
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Im showing 2.25 hours for me from Bham.
  20. Sep 2, 2020 at 11:38 AM
    #40
    baldridge
    Bart
    Auburn, AL
    Hopefully he can connect with the guy on FB.
    cubie[QUOTED] likes this.
